    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • HornOxxH
      HornOxx
      wunderbar! 👍 👍 and still well fitting to Halloween 😄
      (could you please explain to me what the term "baked" means, I have never understood it)
      never trust a skinny cook
        It is where the hi-poly mesh details, like its normals and curvature are written out to image and used on the lo-poly mesh to fake/drive details it doesn't naturally have.
        Things like edge wear and grime position can be fiddled with if you have a good hi-poly mesh to drive your bake.
        Thibk of it as a shortcut to give lo-poly more oomph when it come to image related output.
        • panixiaP
          panixia
          Let's try to put it simple... 😄
          • tuna1957T
            tuna1957
            Herman Miller “Swoop” lounge chair. Have intended to model this up for all long time. Finally sat down and did it. SubD for the plywood shell and cushions. 😎
            • HornOxxH
              HornOxx
              @tuna1957 said:
              ...Finally sat down and did it...
              and you did it well! 😄
              • tuna1957T
                tuna1957
                Thanks HornOxx 👍
                • tuna1957T
                  tuna1957
                  Finally got around to finishing my mid mod abstract man sculpture ! 😎
                  • HornOxxH
                    HornOxx
                    @tuna1957 said:
                    ...my mid mod abstract man sculpture
                    ...which is actually 2 sculptures? - what a wonderful model that is 😮 👍
                    • tuna1957T
                      tuna1957
                      Thanks HornOxx, the best I could tell in the one reference picture I had is the sculpture is connected where the back of the hands and leg meet. For ease of modeling I did the torso and legs separately. 😎
                      • tuna1957T
                        tuna1957
                        More of my simple SubD practice. Have always liked these “wavy” art glass pieces…. Did a little experimenting on the render side. Have wanted to try getting a gradient color to the glass. Created the texture in Gimp and projected it on the bowl with ThruPaint. Cheers 😎
                          https://i.imgur.com/gtQmWFc.png
                          https://i.imgur.com/WHi6k6O.png
                          • tuna1957T
                            tuna1957
                            Thanks HornOxx 😎
                            Very cool chair Rich 👍
                            • HornOxxH
                              HornOxx
                              yes, nice!! 😄 and your render turned out really wunderbar!
                              • tuna1957T
                                tuna1957
                                Posting this for new users of SubD. Cool thing is how easy it is to go back to an older SubD model and make significant changes without having to start from scratch. Chair model originally done a number of years ago. Never quite happy with it. A little reworking with VertexTools and I have a brand new chair !
                                • alvisA
                                  alvis
                                  • tuna1957T
                                    tuna1957
                                    Thanks alvis .
                                    • BoxB
                                      laid up at the moment and can't really use my computer effectively. So a bit of fun SUbD one handed flat on my back using a touchpad. A blend of a plague mask influenced by the alien in Prometheus.
                                      • HornOxxH
                                        HornOxx
                                        so horrible these thing (but cool also) - based on the pestilence masks of the medieval doctors with this equally horrible gas mask interference - really so horrible 😄
                                        If I read correctly I wish you a good recovery Box! 👍
                                          Hope you get better soon. 👍
                                          • BoxB
                                            Thanks Gents, I'll get back to normal eventually. Just frustrating to not be able to do things you take for granted.
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 83
                                            • 84
                                            • 77 / 84
