    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.9m Views 79 Watching
    • Rich O BrienR Online
      ๐Ÿ˜„
      You're right! Where are my manners?
        I am now after a studio photo type render when the object is in the centre and the background is black and it lit to show the properties of the materials (in case of furniture) or the plasticity of the building (in case of a building on a context)...
        TwiLight, affordable, powerful and easy to use. Plus tailored to SketchUp.
        • BoxB Offline
          Not the first time this has been recommended.
          • kimgaK Offline
            kimga
            Thank you Rich for the answers and for the book - I downloaded it and it has some great tips. I wish I had it when started using SketchUp. I sent the link to someone who`s learning. It will save her so much time!
            I will give TwiLight a go. I`ve just found out - from the thread (I am still working my way through) that Box uses Twilight Hobby too.... So now, I will have to start learning to render. I am out of excuses.....
            Cheers
            • kimgaK Offline
              kimga
              @box said:
              Those are amazing figures. As you noticed I had to create a Box page so I could respond.
              Perhaps I should post a few gifs there.
              Ha..I felt like travelling back in time.
              I started to follow you a long time ago on FB - because of these handy GIFs - and just read the comment above on this thread...So this is how it started...๐Ÿ˜„
                @kimga said:
                I am out of excuses.....Cheers
                You are on an adventure....enjoy it ๐Ÿ‘
                • ely862meE Offline
                  ely862me
                  @rich o brien said:
                  Like so....
                  https://i.imgur.com/drtqZi2.png
                  I like how it cleaned the intersection, unfortunately it moved the pole in a place that is undesirable.
                  The middle one is what I ended up with-still not happy with the crowded geometry(and perhaps a little bump in the final geometry).
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                  • kimgaK Offline
                    kimga
                    @pbacot said:
                    @kimga said:
                    Is it possible to set up virtual studio in SketchUp, for example with lighting and camera and just pop in the main object and make the render quicker this way?
                    Programs like Twilight and Thea work within SketchUp, so it is an advantage in that way. You place lighting objects (provided by the renderer) in SketchUp and run the render. You can model studios and / or use image based lighting for your studio lighting and reflections. I like working this way as can work on the model over time and it's ready to render based on the scenes and settings that I have already developed, no export necessary. Blender is amazing though--it somehow does much more in terms of realtime / fast rendering on my limited system than these plugin renderers can. I suspect it helps in more advanced work, but I've not learned to use it efficiently yet.
                    Thank you for your answer. I was trying to add a "thumb up" as I did with most helpful posts in this thread, but for some reason, it doesn't work here.
                    Most people recommended Twilight, so I started down this way but I would like to know the main differences compared with Thea...
                    This is exactly what I am looking for. An easy to use render that I can pre-set and just throw in the model and hopefully spend minimal time on it. Ageing it down with textures possibly....
                    Blender would be nice, but I fear I have no time for that just now.
                    Thbank you
                      https://i.imgur.com/en1RlRS.png
                      https://i.imgur.com/dOfNElE.png
                      • HornOxxH Offline
                        HornOxx
                        wunderbar! ๐Ÿ‘ ๐Ÿ‘ and still well fitting to Halloween ๐Ÿ˜„
                        (could you please explain to me what the term "baked" means, I have never understood it)
                        never trust a skinny cook
                          It is where the hi-poly mesh details, like its normals and curvature are written out to image and used on the lo-poly mesh to fake/drive details it doesn't naturally have.
                          Things like edge wear and grime position can be fiddled with if you have a good hi-poly mesh to drive your bake.
                          Thibk of it as a shortcut to give lo-poly more oomph when it come to image related output.
                          • panixiaP Offline
                            panixia
                            Let's try to put it simple... ๐Ÿ˜„
                            • tuna1957T Offline
                              tuna1957
                              Herman Miller โ€œSwoopโ€ lounge chair. Have intended to model this up for all long time. Finally sat down and did it. SubD for the plywood shell and cushions. ๐Ÿ˜Ž
                              • HornOxxH Offline
                                HornOxx
                                @tuna1957 said:
                                ...Finally sat down and did it...
                                and you did it well! ๐Ÿ˜„
                                • tuna1957T Offline
                                  tuna1957
                                  Thanks HornOxx ๐Ÿ‘
                                  • tuna1957T Offline
                                    tuna1957
                                    Finally got around to finishing my mid mod abstract man sculpture ! ๐Ÿ˜Ž
                                    • HornOxxH Offline
                                      HornOxx
                                      @tuna1957 said:
                                      ...my mid mod abstract man sculpture
                                      ...which is actually 2 sculptures? - what a wonderful model that is ๐Ÿ˜ฎ ๐Ÿ‘
                                      • tuna1957T Offline
                                        tuna1957
                                        Thanks HornOxx, the best I could tell in the one reference picture I had is the sculpture is connected where the back of the hands and leg meet. For ease of modeling I did the torso and legs separately. ๐Ÿ˜Ž
                                        • tuna1957T Offline
                                          tuna1957
                                          More of my simple SubD practice. Have always liked these โ€œwavyโ€ art glass piecesโ€ฆ. Did a little experimenting on the render side. Have wanted to try getting a gradient color to the glass. Created the texture in Gimp and projected it on the bowl with ThruPaint. Cheers ๐Ÿ˜Ž
                                            https://i.imgur.com/gtQmWFc.png
                                            https://i.imgur.com/WHi6k6O.png
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 83
                                            • 84
                                            • 77 / 84
