[Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
Hi, I use the Lord of the toolbar program with satisfaction But since yesterday I have this error message which in any case does not prevent me from continuing to work. the error presents us at the Start of SketchUp, I would like to know what it is from and how to solve it, given the great usefulness of this program for me who are disabled.
some extensions are referenced in palettes but not loaded - unknown command sketchup
The latest version of LOTT tracks command icons of extensions which are referenced in palettes but are no longer present (for instance, when you uninstall them, or when you import configuration from another version of Sketchup. It displays a notification at startup if there are some, usually indicating the name of the command and extension.
It might be that there is a problem there. I'll have a look.
Without this plugin I can't work with skp, congratulations. how can I solve this problem? thanks, skp 2022 fredo lib updated.
It may not be a problem actually. The notification automatically disappears after a few seconds.
Do you have issue with LOTT, in particular about 'ghost icons', that is icons in palettes that would have a rounded rectangle around and are disabled?
I managed to solve the problem by uninstalling and deleting all the temporary files created by Fredo \ Users \ xxx \ AppData \ Local \ LIBFREDO6_DATA_Dir \ LOTT \ GHOST now I no longer have the error at startup
But now Fredo Corner no longer works, with a regular license. I deduce that the problem is caused by the combination of Lord of toolbars v12.5a with fredo Corner v2.5a.I await updates
NEW RELEASE: LordOfTheToolbars v2.0a - 24 Feb 22
Requirements
- LibFredo6: v12.4a or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.0a includes
- Adjustment for notification at startup of Sketchup
Home Page of LordOfTheToolbars for information and Download.
Hi fredo6,
I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars.
I have sketchup 2022 on windows 10, everytinh is up to date.
It worked before the latest update. -
Could you update to LibFredo6 v12.7a and check if you see errors displayed in the Ruby console at startup.
Hi Fredo,
Sorry I didn't answer back but it seams I don't get any emails with replays, I didn't know there is no email notifications ...
I keep all plugins up to date. Right now I have LibFredo6 12.8a the latest.
The issue is still present and I have attached what comes up in the console at startup.If you don't find anything relevant to help me fix this from what I am sending should I try a full reinstall of sketchup and see if that works?
Thank you very much for your time.
Thanks !
Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
Could you open the Ruby Console at startup to see potential errors (just open the Ruby console, quit Sketchup and restart Sketchup).
I really look forward to fixing this error.
I have been working with this problem for several months, it greatly interferes when after each launch of SU. When you first need to run Lord (so that the icons appear), and then they need to be put in their places (because after launch they appear in the center of the monitor) (( -
Hi - Thanks for the quick response! I re-started with the ruby console open, but I don't see any errors - although I'm not exactly sure what I'm looking for.
Fredo, is there any technical obstacle to show user's shortcuts in the tool tips and command search?
No vignette stripe for me either on SketchUp Pro 2020 on Windows 10, with LOTT v2.0a and LibFredo6 v12.8a.
I can make it temporarily visible via menu Tools > Fredo6 Collection > LOTT > Pop Up but then it disappears the first click anywhere in the SketchUp window. Ruby Console shows no actions or errors.
Sketchup 2022 MAC
the Pie Tool doesn't work if I press the button on Palette of LordofTheToolbars.
Is it a bug?
@digitect said:
No vignette stripe for me...
UPDATE: I position my Windows taskbar at screen top, and found LOTT beneath it. So that default needs to be adjusted. Once I found, and adjusted, several LOTT positioning options from their defaults (sticky to Sketchup window, position in Popup mode, position when cycling), it behaved as expected.
@scozzarella said:
Sketchup 2022 MAC
Is it a bug?
As far as I now the Pie tool (from Rich O Brien) is not supported on Mac.
