    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    549 Posts 101 Posters 609.9k Views 99 Watching
      resetarionut
      Hi Fredo,
      Sorry I didn't answer back but it seams I don't get any emails with replays, I didn't know there is no email notifications ...
      I keep all plugins up to date. Right now I have LibFredo6 12.8a the latest.
      The issue is still present and I have attached what comes up in the console at startup.
      If you don't find anything relevant to help me fix this from what I am sending should I try a full reinstall of sketchup and see if that works?
      Thank you very much for your time.
      Console msgs 27.03.2022.txt
        Mariotalluto
        Thanks !
          aa6
          Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
          • fredo6F
            Could you open the Ruby Console at startup to see potential errors (just open the Ruby console, quit Sketchup and restart Sketchup).
              AISmebel
              I really look forward to fixing this error.
              I have been working with this problem for several months, it greatly interferes when after each launch of SU. When you first need to run Lord (so that the icons appear), and then they need to be put in their places (because after launch they appear in the center of the monitor) 😞((
                aa6
                Hi - Thanks for the quick response! I re-started with the ruby console open, but I don't see any errors - although I'm not exactly sure what I'm looking for.
                  rv1974
                  Fredo, is there any technical obstacle to show user's shortcuts in the tool tips and command search?
                    digitect
                    No vignette stripe for me either on SketchUp Pro 2020 on Windows 10, with LOTT v2.0a and LibFredo6 v12.8a.
                    I can make it temporarily visible via menu Tools > Fredo6 Collection > LOTT > Pop Up but then it disappears the first click anywhere in the SketchUp window. Ruby Console shows no actions or errors.
                      Scozzarella
                      Sketchup 2022 MAC
                      the Pie Tool doesn't work if I press the button on Palette of LordofTheToolbars.
                      Is it a bug?
                        digitect
                        @digitect said:
                        No vignette stripe for me...
                        UPDATE: I position my Windows taskbar at screen top, and found LOTT beneath it. So that default needs to be adjusted. Once I found, and adjusted, several LOTT positioning options from their defaults (sticky to Sketchup window, position in Popup mode, position when cycling), it behaved as expected.
                        • fredo6F
                          @scozzarella said:
                          Sketchup 2022 MAC
                          Is it a bug?
                          As far as I now the Pie tool (from Rich O Brien) is not supported on Mac.
                            @scozzarella said:
                            Sketchup 2022 MAC...
                            Is it a bug?
                            No. As Fredo indicated, Pie is Windows only.
                              Scozzarella
                              /Users/angeloscozzarella/Desktop/Schermata 2022-05-12 alle 04.42.13.png
                                Scozzarella
                                • fredo6F
                                  @Scozzarella
                                  What is the problem?
                                    Scozzarella
                                    @fredo6 said:
                                    @Scozzarella
                                    If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
                                    • fredo6F
                                      Strange. On Mac, it works for SU2021, but not for SU2022
                                      Thanks for signaling the problem.
                                        Scozzarella
                                        you are welcome
                                        • fredo6F
                                          NEW RELEASE: LordOfTheToolbars v2.1a - 14 May 22
                                          Requirements
                                          • LibFredo6: v12.9a or above
                                          LordOfTheToolbars 2.1a includes
                                          • Bug fixing
                                          • Future compatibility
                                          Home Page of LordOfTheToolbars for information and Download.
                                          Main post of this LordOfTheToolbars thread.
                                            Scozzarella
                                            thank you very much
                                            • 11
                                            • 12
                                            • 27
                                            • 28
                                            • 10 / 28
