    [Plugin] LordOfTheToolbars - v3.0a - 21 Apr 26
    507 Posts 98 Posters 498.7k Views 96 Watching
      AISmebel
      @fredo6 said:
      @aismebel said:
      Again, everything stopped working after a bug in SketchUp.
      But what was this bug?
      I donโ€™t remember what error caused SketchUp to close. But that was in SU 2020. Then I installed SU 2022 and your plugin still doesn't work ๐Ÿ˜ž
      • fredo6F Offline
        Would you mind to do a Repair of SU2022 to see if this fixes the problem.
        Same for SU2020 if you still have it on your computer.
          AISmebel
          Does your plugin share a file that is referenced by SU 2020 and SU 2022?
          Maybe a settings file? Or something in the registry? Perhaps there was an error and this file needs to be updated.
          SU 2022 has already done recovery. It didn't help me.
          • fredo6F Offline
            The error is in Sketchup: some menu texts are wrongly encoded (or are read as such). I don't think this is directly related to LOTT.
            Another user has a similar problem, running a French version of Sketchup 2021, but only on one computer.
            • alexpacio2013A Offline
              alexpacio2013
              Hi, I use the Lord of the toolbar program with satisfaction But since yesterday I have this error message which in any case does not prevent me from continuing to work. the error presents us at the Start of SketchUp, I would like to know what it is from and how to solve it, given the great usefulness of this program for me who are disabled.
              some extensions are referenced in palettes but not loaded - unknown command sketchup
              • fredo6F Offline
                The latest version of LOTT tracks command icons of extensions which are referenced in palettes but are no longer present (for instance, when you uninstall them, or when you import configuration from another version of Sketchup. It displays a notification at startup if there are some, usually indicating the name of the command and extension.
                It might be that there is a problem there. I'll have a look.
                  alexpacio2013
                  AcZCw6vyeZ.pngWithout this plugin I can't work with skp, congratulations. how can I solve this problem? thanks, skp 2022 fredo lib updated.
                  • fredo6F Offline
                    It may not be a problem actually. The notification automatically disappears after a few seconds.
                    Do you have issue with LOTT, in particular about 'ghost icons', that is icons in palettes that would have a rounded rectangle around and are disabled?
                      alexpacio2013
                      I managed to solve the problem by uninstalling and deleting all the temporary files created by Fredo ๐Ÿ˜„ \ Users \ xxx \ AppData \ Local \ LIBFREDO6_DATA_Dir \ LOTT \ GHOST now I no longer have the error at startup
                      But now Fredo Corner no longer works, with a regular license. I deduce that the problem is caused by the combination of Lord of toolbars v12.5a with fredo Corner v2.5a.
                      I await updates
                      • fredo6F Offline
                        NEW RELEASE: LordOfTheToolbars v2.0a - 24 Feb 22
                        Requirements
                        • LibFredo6: v12.4a or above
                        LordOfTheToolbars 2.0a includes
                        • Adjustment for notification at startup of Sketchup
                        Home Page of LordOfTheToolbars for information and Download.
                        Main post of this LordOfTheToolbars thread.
                          resetarionut
                          Hi fredo6,
                          I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars.
                          I have sketchup 2022 on windows 10, everytinh is up to date.
                          It worked before the latest update.
                          • fredo6F Offline
                            Could you update to LibFredo6 v12.7a and check if you see errors displayed in the Ruby console at startup.
                              resetarionut
                              Hi Fredo,
                              Sorry I didn't answer back but it seams I don't get any emails with replays, I didn't know there is no email notifications ...
                              I keep all plugins up to date. Right now I have LibFredo6 12.8a the latest.
                              The issue is still present and I have attached what comes up in the console at startup.
                              If you don't find anything relevant to help me fix this from what I am sending should I try a full reinstall of sketchup and see if that works?
                              Thank you very much for your time.
                              Console msgs 27.03.2022.txt
                                Mariotalluto
                                Thanks !
                                  aa6
                                  Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
                                  • fredo6F Offline
                                    Could you open the Ruby Console at startup to see potential errors (just open the Ruby console, quit Sketchup and restart Sketchup).
                                      AISmebel
                                      I really look forward to fixing this error.
                                      I have been working with this problem for several months, it greatly interferes when after each launch of SU. When you first need to run Lord (so that the icons appear), and then they need to be put in their places (because after launch they appear in the center of the monitor) ๐Ÿ˜ž((
                                        aa6
                                        Hi - Thanks for the quick response! I re-started with the ruby console open, but I don't see any errors - although I'm not exactly sure what I'm looking for.
                                          rv1974
                                          Fredo, is there any technical obstacle to show user's shortcuts in the tool tips and command search?
                                            digitect
                                            No vignette stripe for me either on SketchUp Pro 2020 on Windows 10, with LOTT v2.0a and LibFredo6 v12.8a.
                                            I can make it temporarily visible via menu Tools > Fredo6 Collection > LOTT > Pop Up but then it disappears the first click anywhere in the SketchUp window. Ruby Console shows no actions or errors.
                                            • 11
                                            • 25
                                            • 26
                                            • 9 / 26
