    Modeling a twisted shelf
    23 Posts 7 Posters 4.7k Views 7 Watching
    • pbacotP
      @pilou said:
      FredoScale 2.0 itself is not sufficient : Slicer + Twist + Bend ? (with little sections resize)
      I tried a lot with Fredoscale. I couldn't figure out how to make it work. Then I turned to drawing rails in 3d.
      • pbacotP
        @rich o brien said:
        I would lean towards Curviloft and SUbD to arrive at the final form...
        Thanks Rich. So it seems you start with a rough profile, easier to work out, Curviloft that. How do you get the extra edges around the border? Then you texture it, how?
        I tried Artisan to smooth your model, and it did pretty well but took the texture off . With Artisan Brush I got the texture back on, and it looks OK (on the top of the model anyway--back is a mess, but you can't see it).
          Yes, CurviLoft > LoftbySpline with segments set to 1 for the main top face...
          https://i.imgur.com/DTGfaPR.png
          Next is JointPushPull to thicken and then I use QFT > Select Ring to select top ring and QFT > Connect Edges with the following for Segments/Pinch...
          https://i.imgur.com/P1OCdUV.png
          ...to add holding edges. Repeat this for the shelf edge...
          https://i.imgur.com/FClIvOh.png
          Run SUbD at 2 levels to test form...
          https://i.imgur.com/xzEOUz6.png
          When I'm happy with the form I return to the proxy and add UV seams and UV unwrap with WrapR...
          https://i.imgur.com/bX5Onlm.png
          ...and import the UVs back the SketchUp.
          https://i.imgur.com/oJOS50i.png
          You can now replace the checker texture with a seamless wood image or send the mesh the Substance Painter to texture in there.
          https://i.imgur.com/qQOOS41.png
          As a side note, SUbD has support for WrapR attributes and likewise WrapR supports SUbD attritbutes so running a subdivision on the proxy will maintain UVs. πŸ‘
          • pbacotP
            Excellent!
            I also try to do some things with QFT but I really know how to use it effectively. I don't know of any tutorials and the tool tips don't show for it, on my system at least.
              It's a particular workflow you adopt over time. To me its my most used extension for SketchUp. I forgot to mention it because I've so many functions as shortcuts I tend to forget its not in vanilla SU.
              Hope that info helps you make this model yourself at some point. It's a really good case study for anyone interested in organic form etc.
                Sorry what is "QFT" ? 😳
                • pbacotP
                  Yes I got a lot of good ideas from this!. I'd love to learn more about QFT somehow.
                  I also enjoyed using Bezier Surface and learned a lot about it--though I'm still at trial and error level with it. I used your video for pointers!
                    @Pilou
                    QFT == Quad Face Tools
                    • HornOxxH
                      HornOxx
                      πŸ‘ πŸ‘ πŸ‘ A great post overall and a beautiful and manageable model work on top of that!
                      I'd have been probably "dotting" between all the approaches shown here and probably would have tried them all side by side to see what came out.
                      Dave's suggestion with TIG's Extrude Edges by Rails is unknown to me so far - so I'll look at that tool first.
                      never trust a skinny cook
                        Ok for the QFT ! 😳
                        Other direction πŸ˜„
                        Maybe ShapeBender or FlowiFy can be used! πŸ˜‰
                        https://images2.imgbox.com/72/56/aasXdMuH_o.gif
                          C'est magnifique!
                          • 2 / 2
