    Modeling a twisted shelf
    23 Posts 7 Posters 4.4k Views 7 Watching
      Good luck.
      FWIW I find it useful to create a box or other 3D shape to "build" the 3D Bezier curve in because it gives me a better frame of reference for the shape.
      • pbacotP
        Woops I just noticed there is a twist missing from your version. It's hard to visualize, unless you open the second pdf file that has the plan view. The front edge of the shelf ends up on the inside edge against the wall. Or put another way, the top surface of the shelf ends up facing out instead of facing the wall.
          I wasn't trying to exactly reproduce the shelf you show. Just give you and idea. I didn't keep the model, either. You should be able to use the same basic idea, though.
          • pbacotP
            Thanks for the inspiration.
            Well I thought I'd try Bezier Surface and that took some learning and time. I got carried away with the polygons it seems. Still having trouble texturing this one.
            I WILL look at Bezier Spline.
            • BoxB
              Here's a very basic SUbD version.
              • pbacotP
                Thanks Box! it seems that if you know what to draw for the proxy(?), SubD would be fast. I haven't got into it. This is one of the few organic challenges I have had in work projects. I do need to do terrain modeling, however. I wonder if SubD could be used in that. Or do you use it in puffy furniture?
                  I would lean towards Curviloft and SUbD to arrive at the final form...
                  pbacot-twisted-shelf.skp
                  https://i.imgur.com/mnkcK17.png
                  To create the initial rails to loft I did use Vertex Tools with a soft falloff to pinch the rails as needed...
                  https://i.imgur.com/c6VqSxf.png
                  ...making the curved portions had identical segments counts so topology remained even.
                  With some UV mapping and 2 levels of subdivision you get somewhat close.
                  https://i.imgur.com/H4SR6Zw.png
                  Dave's version is yum!
                    Not as yummy as yours, though.
                      FredoScale 2.0 itself is not sufficient : Slicer + Twist + Bend ? (with little sections resize)
                      • pbacotP
                        I tried a lot with Fredoscale. I couldn't figure out how to make it work. Then I turned to drawing rails in 3d.
                        • pbacotP
                          Thanks Rich. So it seems you start with a rough profile, easier to work out, Curviloft that. How do you get the extra edges around the border? Then you texture it, how?
                          I tried Artisan to smooth your model, and it did pretty well but took the texture off . With Artisan Brush I got the texture back on, and it looks OK (on the top of the model anyway--back is a mess, but you can't see it).
                            Yes, CurviLoft > LoftbySpline with segments set to 1 for the main top face...
                            https://i.imgur.com/DTGfaPR.png
                            Next is JointPushPull to thicken and then I use QFT > Select Ring to select top ring and QFT > Connect Edges with the following for Segments/Pinch...
                            https://i.imgur.com/P1OCdUV.png
                            ...to add holding edges. Repeat this for the shelf edge...
                            https://i.imgur.com/FClIvOh.png
                            Run SUbD at 2 levels to test form...
                            https://i.imgur.com/xzEOUz6.png
                            When I'm happy with the form I return to the proxy and add UV seams and UV unwrap with WrapR...
                            https://i.imgur.com/bX5Onlm.png
                            ...and import the UVs back the SketchUp.
                            https://i.imgur.com/oJOS50i.png
                            You can now replace the checker texture with a seamless wood image or send the mesh the Substance Painter to texture in there.
                            https://i.imgur.com/qQOOS41.png
                            As a side note, SUbD has support for WrapR attributes and likewise WrapR supports SUbD attritbutes so running a subdivision on the proxy will maintain UVs. πŸ‘
                            • pbacotP
                              Excellent!
                              I also try to do some things with QFT but I really know how to use it effectively. I don't know of any tutorials and the tool tips don't show for it, on my system at least.
                                It's a particular workflow you adopt over time. To me its my most used extension for SketchUp. I forgot to mention it because I've so many functions as shortcuts I tend to forget its not in vanilla SU.
                                Hope that info helps you make this model yourself at some point. It's a really good case study for anyone interested in organic form etc.
                                  Sorry what is "QFT" ? 😳
                                  • pbacotP
                                    Yes I got a lot of good ideas from this!. I'd love to learn more about QFT somehow.
                                    I also enjoyed using Bezier Surface and learned a lot about it--though I'm still at trial and error level with it. I used your video for pointers!
                                      @Pilou
                                      QFT == Quad Face Tools
                                      • HornOxxH
                                        HornOxx
                                        πŸ‘ πŸ‘ πŸ‘ A great post overall and a beautiful and manageable model work on top of that!
                                        I'd have been probably "dotting" between all the approaches shown here and probably would have tried them all side by side to see what came out.
                                        Dave's suggestion with TIG's Extrude Edges by Rails is unknown to me so far - so I'll look at that tool first.
                                        never trust a skinny cook
                                          Ok for the QFT ! 😳
                                          Other direction πŸ˜„
                                          Maybe ShapeBender or FlowiFy can be used! πŸ˜‰
                                          https://images2.imgbox.com/72/56/aasXdMuH_o.gif
                                            C'est magnifique!
