    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
    • ntxdaveN
      ntxdave
      I am running SketchUcation Tools version 3.1.0. I wanted to update to the latest version but am having problems. Maybe someone can give me the proper steps for updating the tool (I have already downloaded the 4.1.3 rbz file).
      Press F1...thank me later
        You can either go to Resources at the top of the SketchUp web page, choose Plugin Store Download and download the .rbz file. Then in the Extension Manager use Install Extenstion to install it. Or you can open the Sketchucation Extension Store Tool and fine the Extension Store. Click on the Download button and it will install. The latter option would be my preference because then it will keep track and if there's an update to it later, let you know when you open the ExtensionStore panel.
        • ntxdaveN
          ntxdave
          [attachment=0:3tj1n44k]<!-- ia0 -->Screenshot - 1_8_2022 , 6_07_22 PM.png<!-- ia0 -->[/attachment:3tj1n44k]
          The download button is not showing up. 😞
            Show a screen shot of what you are seeing.
            • ntxdaveN
              ntxdave
              Will show one tomorrow. 😄
              Thanks for the follow up Dave.
                The initial default dialog size is probably too narrow to show all of the buttons.
                Drag its side out until it's wider and all 3 buttons show...
                Also adjust the dialog's height as appropriate.
                Once it's to your satisfaction SketchUp should remember its size next time...
                If it doesn't remember, then it's possible that SketchUp hasn't been installed using 'run as administrator' on it its installer's exe file - there are posts about that too...
                • ntxdaveN
                  ntxdave
                  OK I have things running but it says I have version 4.1.3. I need to get the latest version.
                    4.1.3 IS the latest version !
                    • ntxdaveN
                      ntxdave
                      Well, all of a sudden it seems to be gone and I cannot reinstall it for some silly reason.
                      Here is what I see when I try to add in using the nomal routine.
                        What is gone? The Sketchucation toolbar?
                        [attachment=1:289s9zdu]<!-- ia1 -->SkecthUpPreferences.jpg<!-- ia1 -->[/attachment:289s9zdu]
                        What do you mean by "normal routine"? There's nothing about displaying toolbars in Preferences>Workspace. The normal way to select and show toolbars in SketchUp is to go to View>Toolbars and tick the boxes for the toolbars you want to see.
                        [attachment=0:289s9zdu]<!-- ia0 -->Screenshot - 1_9_2022 , 4_41_39 PM.png<!-- ia0 -->[/attachment:289s9zdu]
                        • ntxdaveN
                          ntxdave
                          Sorry for the confusion. I was in a hurry before I left the house. I thought I Had to reinstall the SketUcations Tools because the icons were missing from the toolbar I was trying to reinstall it but as my screenshot shows, there is no Extensions option in the Windows Preferences setting. I did not stop to think about the screen for putting the tool back on my toolbar.
                          Too many things (not related to the technology) and I seem to be making one stupid mistake after another lately. I hope you guys will not give up on me.
                            @ntxdave said:
                            ...but as my screenshot shows, there is no Extensions option in the Windows Preferences setting.
                            There's not supposed to be an Extensions "option" in Preferences. Extension Warehouse and Extension Manager have been separate from Preferences for a few versions of Sketchup. You'll find them at the top of the Extensions menu.
                            So did you find the toolbar in the Toolbars list?
                            • ntxdaveN
                              ntxdave
                              Got to wait until I get back home to look at the toolbars,
                              • ntxdaveN
                                ntxdave
                                @dave r said:
                                No, here is what I did find....
                                I am having problems finding the SketchUcation stuff.........I think I clicked something that made it disappear and now I can not find the right way to get it back.
                                  Maybe disabled it in the Extension Manager?
                                  If the answer is no you're going to have to let me see your computer.
                                  • ntxdaveN
                                    ntxdave
                                    OK - I finally got things back to normal.
                                    1. I went to the Extension Manager and uninstalled SketchUcation.
                                    2. I shut dow SketchUp and then reloaded it.
                                    3. I went back to the Extension Manager and clicked on the Install Extension
                                    4. When the extension finished installing, I drug the SketchUcation toolbar back up where it used to be.
                                    So, I think I am back up and running the way it should be...........
                                    • OxerO
                                      Oxer
                                      Hi, I installed the last version 4.2.3 in Sketchup 2017 & macOS 10.13.6 and when I select Extensions Menu > SketchUcation > SFCLicence : Global Status, it appears this console message:
                                      Error; #<LoadError; dlopen(/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle, 9); no suitable image found.  Did find;
                                      	/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
                                      	/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
                                      /Applications/SketchUp 2017/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb;54;in `require'
                                      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;156;in `load_binary'
                                      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;54;in `license_dialog_global'
                                      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;2123;in `block (2 levels) in <module;SCFLicense>'
                                      SketchUp;1;in `call'
                                      This is the content of the SketchUcation folder in my computer:
                                      With ExtensionStore v4.0.0b works fine, I didn't test with other versions (v4.0.0c to 4.2.2)
                                        ramohn
                                        Hello All,
                                        I need assistance as I can't log into ExtensionStore v4.2.3 (inside Sketchup) to authenticate the FredoScale I recently purchased.
                                        I use MacOs 10.14 and Sketchup 2017 Make.
                                        Can someone help me ?
                                        Thanking you in advance.
                                        Ramon Asensi
                                          v4.2.4 is now available through the PluginStore / ExtensionStore³
                                          https://sketchucation.com/pluginstore?pln=SketchUcationTools
                                          It fixes the UNzip error reported when installing RBZ files in v2017/18...
                                            ramohn
                                            @ramohn said:
                                            Hello All,
                                            [attachment=1:5h8n8gf6]<!-- ia1 -->Captura de Tela 2022-03-08 às 01.41.54.png<!-- ia1 -->[/attachment:5h8n8gf6]
                                            Ramon Asensi
                                            Please,
                                            I beg anyone could help me with my issue or I'll request refund of plugin purchased recently
                                            [attachment=0:5h8n8gf6]<!-- ia0 -->Captura de Tela 2022-03-16 às 09.14.08.png<!-- ia0 -->[/attachment:5h8n8gf6]
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 16 / 20
