    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • C
      chalupsky
      So grateful to find this!!
      Two questions, importing a .x model from Vehicle Simulator. The model materials do not map to the model (I choose cancel each time), and the scale of the model. I'm asked the maximum height, (1800mm), I cancel, and the model comes in at about 1/18 the size.
      Any assistance appreciated!
      • E
        Ekon
        @samuel_t said:
        @paladinjnr said:
        Hi Here is a link to the model as requested.
        Filehorst wurde abgeschaltet! Filehorst has been shut down!
        (filehorst.de)
        Your model had absolute paths to textures. That's not supported by plugin.
        I converted absolute paths to relative paths with a text editor. It's OK now:
        [attachment=1:ewxujz9c]<!-- ia1 -->Fixed DirectX Model.png<!-- ia1 -->[/attachment:ewxujz9c]
        Fixed model is attached below:
        [attachment=0:ewxujz9c]<!-- ia0 -->fixed-directx-model.zip<!-- ia0 -->[/attachment:ewxujz9c]
        Hello Samuel, first off, thank you so much for this superb tool!! I have the same issue about textures. I just installed the plugin and imported and FBX file but it comes in without textures. My base model comes from Revit. How can I re-path the textures so that the plugin car read / load them into Sketchup? (Text editor, ok, but how?)
        • samuel_tS
          samuel_t
          ๐Ÿ˜‰
          You don't select materials? Can you elaborate on this?
          It's a known issue: sizing doesn't work for all models ๐Ÿ˜•
          • samuel_tS
            samuel_t
            Hello Ekon! With pleasure ๐Ÿ˜‰
            I converted absolute paths to relative paths with a text editor. It's OK now [...]
            @ekon said:
            I have the same issue about textures. I just installed the plugin and imported and FBX file but it comes in without textures. My base model comes from Revit. How can I re-path the textures so that the plugin can read / load them into Sketchup? (Text editor, ok, but how?)
            First, if you can, upgrade Revit to latest version to increase chances to have more export options.
            Then, tell me what export options Revit offers to you. Some .x (DirectX) and .fbx files are text-encoded. All .mtl files are plain text. Open exported file with a text editor to see if textures paths are editable.
            • P
              p11205
              Hi Samuel,
              Thanks for making this plug in available. I am having the same issue as others when importing a model. The model itself imports fine but without textures. I have read your response to others about the absolute path but am not sure what to do. I have attached the model file below if you have a chance to take a look and advise. thanks
              the file is here:
              https://www.dropbox.com/t/cwZOdCb32a1BrBoZ
              • samuel_tS
                samuel_t
                @p11205 said:
                Hi Samuel,
                Hi Paul ๐Ÿ˜„
                the file is here:
                I successfully imported model as is on SketchUp 2017. See screenshot below. I followed these steps:
                1. Extract whole archive.
                2. Import "12044_w_Rae_30k.OBJ" file.
                3. Cancel when plugin asks about "DefaultMaterial".
                • P
                  p11205
                  Hi Samuel,
                  Thanks for responding so quickly. I tried again as you outlined.after importing the 12044_w_Rae_30k.OBJ file I never got the message regarding default material from the plug in. The model again came in with no textures. Not sure how to proceed.
                  these are screenshots of what I did
                  • MikeG73M
                    MikeG73
                    Hello Sam,
                    Is there a recommended way to get the most out of your model as you reduce its poly count, I mean I keep getting wild responses. I have tried 20/50/70% etc... and my models look like crap up, not at all like your deer example. ๐Ÿ˜ฒ
                    Should I break down the model into groups and reduce each group at the same settings??? I hope I am making sense!
                    Cheers Sam. ๐Ÿ˜„
                    • samuel_tS
                      samuel_t
                      @Paul To import this ".OBJ" file with its textures, extract also "12044_w_Rae_30k.mtl" file and "tex" subfolder. Keep folder hierarchy.
                      @Mike Hello ๐Ÿ˜„ I suppose groups don't matter. I don't know if there's an optimal percent... Poly reduction algorithm is in MeshLab hands.
                        Moltres Rider
                        This plugin claims that it works with FBX files not it does not! ๐Ÿ˜ž
                        Every time I try to import an FBX file I ALWAYS get the following error message:
                        Universal importer failed to load file FBX-DOM unsupported format.
                        Obviously this plugin CANNOT handle FBX files
                        This shocks me that Google has no information on that specific error message since it is EVERY FBX file that results in this error
                        this plugin obviously does NOT support FBX files ๐Ÿ˜ž Please either fix this or remove the option to import FBX files because as it currently stands, Universal Importer does NOT support FBX files
                          FBX file format can be Binary or ASCII. If your file is in a format the importer doesn't support it will throw errors.
                          Similar to how an FBX export from SketchUp cannot be opened in Blender.
                          Also older FBX versions can throw up some issues as well.
                          Many things can lead to an error. It may not be Samuel's lovely extension that is at fault.
                          • samuel_tS
                            samuel_t
                            @Moltres Rider
                            Obviously, you have NO LUCK ๐Ÿ˜ฎ Universal Importer plugin works in most cases with recent versions of FBX format. Try to upgrade model with Autodesk FBX Converter then try again to import model...
                              Arakon
                              Awesome plugin, but it doesn't seem able to handle decimals on the model sizes.. i.e. I have a model that is 53.69mm tall, when importing and entering that value, I get the following error, both with a comma and a decimal point:
                                Maybe it expects 53.69 but is receiving 53,69 - so does your system use a . or a , as the decimal separator ?
                                What do you actually type in the input-box ??
                                Also it seems to expect an integer, rather than a float in any case ???
                                  Arakon
                                  I did type both 53.69 and 53,69 and both cause the error.
                                  I ended up having to import it at 100x scale and scale it back down.. it's a workaround, but not really ideal.
                                    I suspect that the default scaling factor is set as an integer, so trying to use a decimal float will cause an error in the input-box.
                                    The extension's author [samuel_t] should be able to re-code it to suit ??
                                    • samuel_tS
                                      samuel_t
                                      I locked target height to an Integer. Since scaling is hacky in this plugin, I must test Float carefully ๐Ÿ˜›
                                      • samuel_tS
                                        samuel_t
                                        1.1.7 version allows you to import in SketchUp models exported from Blender 2.80 or newer at .blend format.
                                        Expect better compatibility for many formats. Thanks again to Assimp's contributors who made this happen!
                                        Download latest Universal Importer plugin from SketchUcation PluginStore.
                                          Arakon
                                          Found an issue with "small" models.
                                          Example: I'm importing a functional model that is 95x46x75.45mm in size. The STL is 75.45 tall, however, in order for it to import semi-properly, I have to use the 46mm as height.
                                          However, the model, when imported, is actually 99.12x47.99x78.72mm in size, so it's actually 104.3261% of the original size in all directions.
                                          If I import it at a factor of 100 (telling it that the STL is 4600mm in height), then downscale it to 0.01 in Sketchup, the size is correct.
                                          Both the original model and imported model overlapped
                                          • EarthMoverE
                                            EarthMover
                                            Hi Samuel,
                                            I'm getting this error in 2017 Make (Pro trial). I've tried with a .DAE and .FBX file and get the same error. The extension is working as expected in my licensed SU 2021 version, but failing with 2017 only. Any suggestions? Thanks for all your hard work on this amazing free tool!
                                            Error
                                            Content Creator at Skapeup
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
