    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 526.6k Views 112 Watching
      Moltres Rider
      This plugin claims that it works with FBX files not it does not! ๐Ÿ˜ž
      Every time I try to import an FBX file I ALWAYS get the following error message:
      Universal importer failed to load file FBX-DOM unsupported format.
      Obviously this plugin CANNOT handle FBX files
      This shocks me that Google has no information on that specific error message since it is EVERY FBX file that results in this error
      this plugin obviously does NOT support FBX files ๐Ÿ˜ž Please either fix this or remove the option to import FBX files because as it currently stands, Universal Importer does NOT support FBX files
        FBX file format can be Binary or ASCII. If your file is in a format the importer doesn't support it will throw errors.
        Similar to how an FBX export from SketchUp cannot be opened in Blender.
        Also older FBX versions can throw up some issues as well.
        Many things can lead to an error. It may not be Samuel's lovely extension that is at fault.
        • samuel_tS Offline
          samuel_t
          @Moltres Rider
          Obviously, you have NO LUCK ๐Ÿ˜ฎ Universal Importer plugin works in most cases with recent versions of FBX format. Try to upgrade model with Autodesk FBX Converter then try again to import model...
            Arakon
            Awesome plugin, but it doesn't seem able to handle decimals on the model sizes.. i.e. I have a model that is 53.69mm tall, when importing and entering that value, I get the following error, both with a comma and a decimal point:
              Maybe it expects 53.69 but is receiving 53,69 - so does your system use a . or a , as the decimal separator ?
              What do you actually type in the input-box ??
              Also it seems to expect an integer, rather than a float in any case ???
                Arakon
                I did type both 53.69 and 53,69 and both cause the error.
                I ended up having to import it at 100x scale and scale it back down.. it's a workaround, but not really ideal.
                  I suspect that the default scaling factor is set as an integer, so trying to use a decimal float will cause an error in the input-box.
                  The extension's author [samuel_t] should be able to re-code it to suit ??
                  • samuel_tS Offline
                    samuel_t
                    I locked target height to an Integer. Since scaling is hacky in this plugin, I must test Float carefully ๐Ÿ˜›
                    • samuel_tS Offline
                      samuel_t
                      1.1.7 version allows you to import in SketchUp models exported from Blender 2.80 or newer at .blend format.
                      Expect better compatibility for many formats. Thanks again to Assimp's contributors who made this happen!
                      Download latest Universal Importer plugin from SketchUcation PluginStore.
                        Arakon
                        Found an issue with "small" models.
                        Example: I'm importing a functional model that is 95x46x75.45mm in size. The STL is 75.45 tall, however, in order for it to import semi-properly, I have to use the 46mm as height.
                        However, the model, when imported, is actually 99.12x47.99x78.72mm in size, so it's actually 104.3261% of the original size in all directions.
                        If I import it at a factor of 100 (telling it that the STL is 4600mm in height), then downscale it to 0.01 in Sketchup, the size is correct.
                        Both the original model and imported model overlapped
                        • EarthMoverE Offline
                          EarthMover
                          Hi Samuel,
                          I'm getting this error in 2017 Make (Pro trial). I've tried with a .DAE and .FBX file and get the same error. The extension is working as expected in my licensed SU 2021 version, but failing with 2017 only. Any suggestions? Thanks for all your hard work on this amazing free tool!
                          Error
                          Content Creator at Skapeup
                            I see C:\ versus C:/ in paths in the error message ?
                            Is the path inside '...' or "..." - which will give different result ?
                            Best to force the paths to use all / ??
                            • samuel_tS Offline
                              samuel_t
                              I agree, it's better to normalize dir separator but I don't think EarthMover's issue come from this...
                                Does the .mtl file exist in the special tmp folder ?
                                If that tmp file read/writeable ?
                                The error msg says it can't read it ??
                                • samuel_tS Offline
                                  samuel_t
                                  @TIG Yes, it seems plugin can't read "export.mtl" file. Normally, plugin reads "export.mtl" after conversion of input model to "export.obj". Maybe this conversion silently fails...
                                  @EarthMover Can you follow these steps, please?
                                  1. Import a model in SketchUp 2017 with Universal Importer plugin.
                                  2. When plugin error message is shown: don't click on "OK" button!
                                  3. Open "C:\ProgramData\Universal Importer\tmp" in File Explorer.
                                  4. Display files with details so we see each file present and its size...
                                  5. Send us a screenshot of File Explorer and "assimp.log" if it exists.
                                  • samuel_tS Offline
                                    samuel_t
                                    Hi EarthMover ๐Ÿ˜‰
                                    When you import a model with this extension, are SU 2017 and 2021 running in same time and OS?
                                      EarthMover
                                      @samuel_t I don't get a .log file, I get this assimp.nfo here - https://www.dropbox.com/s/wl0v2chqcap2sdz/assimp.nfo?dl=0
                                      File explorer looks like attached
                                      Also, here is the .dae file I'm trying to import if that is helpful. It's from Home Designer (Chief Architect) Again, I don't have a problem importing the file into 2021, but this is to provide an option for my students who are looking for a free solution.-
                                      Dropbox
                                      (www.dropbox.com)
                                      • samuel_tS Offline
                                        samuel_t
                                        @EarthMover I can import with my plugin your DAE model in SketchUp Make 2017 on Windows 10:
                                        In your last screenshot, there are some well written files in your "tmp" directory. I don't understand...
                                          Rick959
                                          Hi there,
                                          I have installed your plugin and when I try to import a model, I have tried several different models, I get the same error each time.
                                          Please see the image attached.
                                          Thanks in advance
                                          • samuel_tS Offline
                                            samuel_t
                                            @rick959 said:
                                            Hi there,
                                            Thanks in advance
                                            Hi Rick,
                                            (Re)install Microsoft Visual C++ library then try again.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
