    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 612.1k Views 113 Watching
      If you use the PluginStore you login, find and download an RBZ archive for an extension.
      Typically you save it in your Downloads folder.
      In SketchUp use the Extension Manager and in its dialog use the Install... button, select the RBZ and it auto-installs for you...
      Alternatively, if you have the SketchUcation Toolset installed then you find an extension's entry in its ExtensionStoreยณ dialog [red toolbar button opens that] and click the button against its entry in the dialog to install it automatically... [essentially skipping the need to manually download an RBZ file...]
      • F
        fabrice
        Hello
        Thank you very much for this plugin.
        But I also have a problem with sketchup 2017, unable to import an obj, yet I have given the permissions.
        A miracle solution ?? ๐Ÿคฃ
          Find the folder C:/ProgramData/Universal Importer/
          Select its icon - select it and right-click > context-menu > Properties > Security > Edit...
          Ensure that every entry listed has FULL permissions set...
          OK to save changes.
          Thereafter you should be able to read/write/delete files in that subfolder or its tmp folder...
          • F
            fabrice
            great, it works THANKS !!!!
            • E
              ekoek0999
              thanks a million!
              I was looking for a way to import pmx files into Sketchup, this one does the trick perfectly
              You are a lifesaver!!!
                Moltres Rider
                Plugin DOES NOT work with Sketchup 2020 ๐Ÿ˜ž STILL NO OPTION to import obj files and fbx files. In fact, it did not add a single new file format to import. Still just the usual default stuff ๐Ÿ˜ž
                  https://i.imgur.com/pTrxpA5.png
                    JArtz
                    Thank you so much. I certainly appreciate this.
                    I been wanting to use it to import my SVG vector creations - a text I made - (of which I have to export via FBX online), and it has helped a bit, only thing - I have to manually put in the lines of the text.
                    Still like the plugin.
                    Many thanks.
                    • C
                      chalupsky
                      So grateful to find this!!
                      Two questions, importing a .x model from Vehicle Simulator. The model materials do not map to the model (I choose cancel each time), and the scale of the model. I'm asked the maximum height, (1800mm), I cancel, and the model comes in at about 1/18 the size.
                      Any assistance appreciated!
                      • E
                        Ekon
                        @samuel_t said:
                        @paladinjnr said:
                        Hi Here is a link to the model as requested.
                        Filehorst wurde abgeschaltet! Filehorst has been shut down!
                        (filehorst.de)
                        Your model had absolute paths to textures. That's not supported by plugin.
                        I converted absolute paths to relative paths with a text editor. It's OK now:
                        [attachment=1:ewxujz9c]<!-- ia1 -->Fixed DirectX Model.png<!-- ia1 -->[/attachment:ewxujz9c]
                        Fixed model is attached below:
                        [attachment=0:ewxujz9c]<!-- ia0 -->fixed-directx-model.zip<!-- ia0 -->[/attachment:ewxujz9c]
                        Hello Samuel, first off, thank you so much for this superb tool!! I have the same issue about textures. I just installed the plugin and imported and FBX file but it comes in without textures. My base model comes from Revit. How can I re-path the textures so that the plugin car read / load them into Sketchup? (Text editor, ok, but how?)
                        • samuel_tS
                          samuel_t
                          ๐Ÿ˜‰
                          You don't select materials? Can you elaborate on this?
                          It's a known issue: sizing doesn't work for all models ๐Ÿ˜•
                          • samuel_tS
                            samuel_t
                            Hello Ekon! With pleasure ๐Ÿ˜‰
                            I converted absolute paths to relative paths with a text editor. It's OK now [...]
                            @ekon said:
                            I have the same issue about textures. I just installed the plugin and imported and FBX file but it comes in without textures. My base model comes from Revit. How can I re-path the textures so that the plugin can read / load them into Sketchup? (Text editor, ok, but how?)
                            First, if you can, upgrade Revit to latest version to increase chances to have more export options.
                            Then, tell me what export options Revit offers to you. Some .x (DirectX) and .fbx files are text-encoded. All .mtl files are plain text. Open exported file with a text editor to see if textures paths are editable.
                            • P
                              p11205
                              Hi Samuel,
                              Thanks for making this plug in available. I am having the same issue as others when importing a model. The model itself imports fine but without textures. I have read your response to others about the absolute path but am not sure what to do. I have attached the model file below if you have a chance to take a look and advise. thanks
                              the file is here:
                              https://www.dropbox.com/t/cwZOdCb32a1BrBoZ
                              • samuel_tS
                                samuel_t
                                @p11205 said:
                                Hi Samuel,
                                Hi Paul ๐Ÿ˜„
                                the file is here:
                                I successfully imported model as is on SketchUp 2017. See screenshot below. I followed these steps:
                                1. Extract whole archive.
                                2. Import "12044_w_Rae_30k.OBJ" file.
                                3. Cancel when plugin asks about "DefaultMaterial".
                                • P
                                  p11205
                                  Hi Samuel,
                                  Thanks for responding so quickly. I tried again as you outlined.after importing the 12044_w_Rae_30k.OBJ file I never got the message regarding default material from the plug in. The model again came in with no textures. Not sure how to proceed.
                                  these are screenshots of what I did
                                  • MikeG73M
                                    MikeG73
                                    Hello Sam,
                                    Is there a recommended way to get the most out of your model as you reduce its poly count, I mean I keep getting wild responses. I have tried 20/50/70% etc... and my models look like crap up, not at all like your deer example. ๐Ÿ˜ฒ
                                    Should I break down the model into groups and reduce each group at the same settings??? I hope I am making sense!
                                    Cheers Sam. ๐Ÿ˜„
                                    • samuel_tS
                                      samuel_t
                                      @Paul To import this ".OBJ" file with its textures, extract also "12044_w_Rae_30k.mtl" file and "tex" subfolder. Keep folder hierarchy.
                                      @Mike Hello ๐Ÿ˜„ I suppose groups don't matter. I don't know if there's an optimal percent... Poly reduction algorithm is in MeshLab hands.
                                        Moltres Rider
                                        This plugin claims that it works with FBX files not it does not! ๐Ÿ˜ž
                                        Every time I try to import an FBX file I ALWAYS get the following error message:
                                        Universal importer failed to load file FBX-DOM unsupported format.
                                        Obviously this plugin CANNOT handle FBX files
                                        This shocks me that Google has no information on that specific error message since it is EVERY FBX file that results in this error
                                        this plugin obviously does NOT support FBX files ๐Ÿ˜ž Please either fix this or remove the option to import FBX files because as it currently stands, Universal Importer does NOT support FBX files
                                          FBX file format can be Binary or ASCII. If your file is in a format the importer doesn't support it will throw errors.
                                          Similar to how an FBX export from SketchUp cannot be opened in Blender.
                                          Also older FBX versions can throw up some issues as well.
                                          Many things can lead to an error. It may not be Samuel's lovely extension that is at fault.
                                          • samuel_tS
                                            samuel_t
                                            @Moltres Rider
                                            Obviously, you have NO LUCK ๐Ÿ˜ฎ Universal Importer plugin works in most cases with recent versions of FBX format. Try to upgrade model with Autodesk FBX Converter then try again to import model...
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
