    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    447 Posts 110 Posters 490.2k Views 110 Watching
      autumnwind
      Hello Samuel,
      First, thanks for the plugin, the idea is very cool.
      The only problem I encountered is that when I try to reduce the polygon count, instead they will increase (together with the size of the 3D model) and it's the opposite result of what I'm trying to achieve. What do you suggest?
      Face count before reduction: 261609
      Face count after reduction: 4544015
      My target was 80000
        rv1974
        Samuel, thanks for creating and sharing this plugin.
        Question: is it possible to to implement the original scale, units and origin respect (in fbx at least)?
        • samuel_tS Offline
          samuel_t
          @autumnwind said:
          Hello Samuel,
          My target was 80000
          Hello Autumn Wind,
          Try to start with a greater target (eg. 200000) then decrease...
          • samuel_tS Offline
            samuel_t
            I don't think so... 😕 The scale is lost during model conversion. I'd study the question if I find the time 😉
              coro28
              How do I install your Universal Importer plugin in Sketchup 2021 Pro?
              • samuel_tS Offline
                samuel_t
                Follow instructions given in Universal Importer plugin documentation.
                  If you use the PluginStore you login, find and download an RBZ archive for an extension.
                  Typically you save it in your Downloads folder.
                  In SketchUp use the Extension Manager and in its dialog use the Install... button, select the RBZ and it auto-installs for you...
                  Alternatively, if you have the SketchUcation Toolset installed then you find an extension's entry in its ExtensionStore³ dialog [red toolbar button opens that] and click the button against its entry in the dialog to install it automatically... [essentially skipping the need to manually download an RBZ file...]
                  • F Offline
                    fabrice
                    Hello
                    Thank you very much for this plugin.
                    But I also have a problem with sketchup 2017, unable to import an obj, yet I have given the permissions.
                    A miracle solution ?? 🤣
                      Find the folder C:/ProgramData/Universal Importer/
                      Select its icon - select it and right-click > context-menu > Properties > Security > Edit...
                      Ensure that every entry listed has FULL permissions set...
                      OK to save changes.
                      Thereafter you should be able to read/write/delete files in that subfolder or its tmp folder...
                      • F Offline
                        fabrice
                        great, it works THANKS !!!!
                        • E Offline
                          ekoek0999
                          thanks a million!
                          I was looking for a way to import pmx files into Sketchup, this one does the trick perfectly
                          You are a lifesaver!!!
                            Moltres Rider
                            Plugin DOES NOT work with Sketchup 2020 😞 STILL NO OPTION to import obj files and fbx files. In fact, it did not add a single new file format to import. Still just the usual default stuff 😞
                            • Rich O BrienR Online
                              https://i.imgur.com/pTrxpA5.png
                                JArtz
                                Thank you so much. I certainly appreciate this.
                                I been wanting to use it to import my SVG vector creations - a text I made - (of which I have to export via FBX online), and it has helped a bit, only thing - I have to manually put in the lines of the text.
                                Still like the plugin.
                                Many thanks.
                                  chalupsky
                                  So grateful to find this!!
                                  Two questions, importing a .x model from Vehicle Simulator. The model materials do not map to the model (I choose cancel each time), and the scale of the model. I'm asked the maximum height, (1800mm), I cancel, and the model comes in at about 1/18 the size.
                                  Any assistance appreciated!
                                  • E Offline
                                    Ekon
                                    @samuel_t said:
                                    @paladinjnr said:
                                    Hi Here is a link to the model as requested.
                                    Filehorst wurde abgeschaltet! Filehorst has been shut down!
                                    (filehorst.de)
                                    Your model had absolute paths to textures. That's not supported by plugin.
                                    I converted absolute paths to relative paths with a text editor. It's OK now:
                                    [attachment=1:ewxujz9c]<!-- ia1 -->Fixed DirectX Model.png<!-- ia1 -->[/attachment:ewxujz9c]
                                    Fixed model is attached below:
                                    [attachment=0:ewxujz9c]<!-- ia0 -->fixed-directx-model.zip<!-- ia0 -->[/attachment:ewxujz9c]
                                    Hello Samuel, first off, thank you so much for this superb tool!! I have the same issue about textures. I just installed the plugin and imported and FBX file but it comes in without textures. My base model comes from Revit. How can I re-path the textures so that the plugin car read / load them into Sketchup? (Text editor, ok, but how?)
                                    • samuel_tS Offline
                                      samuel_t
                                      You don't select materials? Can you elaborate on this?
                                      It's a known issue: sizing doesn't work for all models 😕
                                      • samuel_tS Offline
                                        samuel_t
                                        Hello Ekon! With pleasure 😉
                                        I converted absolute paths to relative paths with a text editor. It's OK now [...]
                                        @ekon said:
                                        I have the same issue about textures. I just installed the plugin and imported and FBX file but it comes in without textures. My base model comes from Revit. How can I re-path the textures so that the plugin can read / load them into Sketchup? (Text editor, ok, but how?)
                                        First, if you can, upgrade Revit to latest version to increase chances to have more export options.
                                        Then, tell me what export options Revit offers to you. Some .x (DirectX) and .fbx files are text-encoded. All .mtl files are plain text. Open exported file with a text editor to see if textures paths are editable.
                                          p11205
                                          Hi Samuel,
                                          Thanks for making this plug in available. I am having the same issue as others when importing a model. The model itself imports fine but without textures. I have read your response to others about the absolute path but am not sure what to do. I have attached the model file below if you have a chance to take a look and advise. thanks
                                          the file is here:
                                          https://www.dropbox.com/t/cwZOdCb32a1BrBoZ
                                          • samuel_tS Offline
                                            samuel_t
                                            @p11205 said:
                                            Hi Samuel,
                                            Hi Paul 😄
                                            the file is here:
                                            I successfully imported model as is on SketchUp 2017. See screenshot below. I followed these steps:
                                            1. Extract whole archive.
                                            2. Import "12044_w_Rae_30k.OBJ" file.
                                            3. Cancel when plugin asks about "DefaultMaterial".
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
