[Plugin Library] LibFredo6 - v14.5b - 24 May 24
Thanks I had not noticed the ">" which shows the version. All is good!
NEW RELEASE: LibFredo6 v11.8a - 02 Jun 21
LibFredo6 11.8a includes
- bug fixing and various technical adjustments
- Support of the new extension LordOfTheToolbars v1.3a
HI Fredo ,
Have not been able to run the libfredo6 plugin successfully on Pro 2021
, tried reinstalling sketchup and re-down loading the plugin as per all the post feedback i could find on the web . Ps also no security access issues just to mention .I receive the following error message .
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:inprocess' C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in
module:LibFredo6_Loader'
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'Any assistance would be appreciated .
I think you have a wrong installation of LibFredo6.
Can you check you have a subfolder Fredo6_!LibFredo6 in your plugin directory, with a size of around 7 Mb.
NEW RELEASE: LibFredo6 v11.9a - 06 Jul 21
- Evolutions for LordOfTheToolbars v1.4a
NEW RELEASE: LibFredo6 v11.9b - 08 Jul 21
LibFredo6 11.9b includes
- Evolutions for LordOfTheToolbars v1.4c
NEW RELEASE: LibFredo6 v11.9c - 10 Jul 21
LibFredo6 11.9c includes
- Evolutions for LordOfTheToolbars v1.4d
NEW RELEASE: LibFredo6 v12.0a - 17 Sep 21
LibFredo6 12.0a includes
- Bug fixing and evolutions for LordOfTheToolbars v1.5a
NEW RELEASE: LibFredo6 v12.0b - 30 Sep 21
- Bug fixing for calculation of volumes in several plugins
- Other fixes
NEW RELEASE: LibFredo6 v12.1a - 23 Oct 21
LibFredo6 12.1a is mainly dedicated to the new plugin MoveAlignMe
I need some help. I am running SU 15.3.330 32 bit for now.
I'm getting a new 64 bit PC in a month or so and will upgrade to SU latest.Why is irrelevant at this time, but if you need to know, ask me.
I ran SU 15 from my old installation but the Fredo Lib was partially corrupted and many tools do not work. I lived with it till now when a tool I really needed was not working.
I want to reload Fredo Lib but the only one I can find is for SU 17+.Where can I find a copy of Fredo Lib for SU 15 32 bit?
If you'd search in the Sketchucation PluginStore--link at the top right of the forum page--you could find the older version for pre-2017 versions of SketchUp. Same with other extensions that Fredo6 offers for the older versions of SketchUp.
https://sketchucation.com/pluginstore?pln=PRIOR_SU2017_LibFredo6
Would you please update the installation video? Some changes have taken place between that and SketchUp2021, and I am unable to follow the instructions as given...and am still stuck and unable to install and use your plugins. Thank you.
NEW RELEASE: LibFredo6 v12.2a - 01 Nov 21
LibFredo6 12.2a includes
- Evolutions for FredoSpline v2.3a
- Technical adjustments
Bonjour je n'arrive pas à télécharger libfredo6 pouvez m'aider ?
Télécharger ou installer ?
NEW RELEASE: LibFredo6 v12.3a - 27 Dec 21
LibFredo6 12.3a includes
- Evolutions for LOTT v1.6a
- Technical adjustments for future compatibility
NEW RELEASE: LibFredo6 v12.4a - 09 Jan 22
LibFredo6 12.4a includes
- Evolutions for LOTT v1.7a
I have installed free Fredo6 V12.4a in SketchUp Pro 2018 on a Macbook. However, there are no toolbars. How does it work without toolbars? Is it because I use a free version? which version of Fredo6 can provide toolbars of animation on a Macbook?
LibFredo is a shared dependency/library that many tools Fredo publishes use. On its own it does nothing. Without it any tools that depend on it will not work.
