    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 581 Posters 6.7m Views 583 Watching
    • fredo6F Offline
      Since this thread is about LibFredo6, I created a dedicated thread here.
        Tibonator
        Very efficient plugin thank you.
        The only issue is that the colour of action icons are extremely difficult to read against the white background.
        I am using SUP2021 on a MacBoo pro 2018 running under MacOS Mojave.
        Is it just me or a common issue that could be resolved easily on the developer's end?
        Thank you.
        T
        Icons colour (dotted in red) unreadable against white background.
        • fredo6F Offline
          This will be fixed in the next version of LibFredo6. This seems to happen for some Mac configurations.
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v11.7a - 12 May 21
            LibFredo6 11.7a includes
            • bug fixing and various technical adjustments
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v11.7c - 16 May 21
              LibFredo6 11.7c includes
              • bug fixing and various technical adjustments, mainly for Mac
                GregorS
                I get no confirmation that my installation of updates (through the Extension Manager) does anything.
                Is this to be expected?
                SU Make 2017
                  What are you expecting to see? Extension Manager will show you the currently installed version of LibFredo6.
                  Fredo6's own Check for Updates will show you the currently installed version, too.
                  If you were using the Sketchucation tool to install it, you would get a notification through the tool that there is an update to be installed when there is.
                  @gregors said:
                  SU Make 2017
                  Your profile says you are using SketchUp 2015. Perhaps you would take a moment to update it?
                    GregorS
                    Thanks I had not noticed the ">" which shows the version. All is good!
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v11.8a - 02 Jun 21
                      LibFredo6 11.8a includes
                      • Support of the new extension LordOfTheToolbars v1.3a
                        CTruter
                        HI Fredo ,
                        Have not been able to run the libfredo6 plugin successfully on Pro 2021
                        , tried reinstalling sketchup and re-down loading the plugin as per all the post feedback i could find on the web . Ps also no security access issues just to mention .
                        I receive the following error message .
                        Error Loading File Fredo6_!LibFredo6.rb
                        Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                        C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in process' C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in module:LibFredo6_Loader'
                        C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                        Any assistance would be appreciated .
                        • fredo6F Offline
                          @CTruter,
                          I think you have a wrong installation of LibFredo6.
                          Can you check you have a subfolder Fredo6_!LibFredo6 in your plugin directory, with a size of around 7 Mb.
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v11.9a - 06 Jul 21
                            • Evolutions for LordOfTheToolbars v1.4a
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v11.9b - 08 Jul 21
                              LibFredo6 11.9b includes
                              • Evolutions for LordOfTheToolbars v1.4c
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v11.9c - 10 Jul 21
                                LibFredo6 11.9c includes
                                • Evolutions for LordOfTheToolbars v1.4d
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v12.0a - 17 Sep 21
                                  LibFredo6 12.0a includes
                                  • Bug fixing and evolutions for LordOfTheToolbars v1.5a
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v12.0b - 30 Sep 21
                                    • Bug fixing for calculation of volumes in several plugins
                                    • Other fixes
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v12.1a - 23 Oct 21
                                      LibFredo6 12.1a is mainly dedicated to the new plugin MoveAlignMe
                                      • jgbJ Offline
                                        jgb
                                        I need some help. I am running SU 15.3.330 32 bit for now.
                                        I'm getting a new 64 bit PC in a month or so and will upgrade to SU latest.
                                        Why is irrelevant at this time, but if you need to know, ask me.
                                        I ran SU 15 from my old installation but the Fredo Lib was partially corrupted and many tools do not work. I lived with it till now when a tool I really needed was not working.
                                        I want to reload Fredo Lib but the only one I can find is for SU 17+.
                                        Where can I find a copy of Fredo Lib for SU 15 32 bit?
                                        jgb
                                          If you'd search in the Sketchucation PluginStore--link at the top right of the forum page--you could find the older version for pre-2017 versions of SketchUp. Same with other extensions that Fredo6 offers for the older versions of SketchUp.
                                          SketchUp Plugins | PluginStore | SketchUcation
                                          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                          (sketchucation.com)
                                          • I Offline
                                            ia enstera
                                            Would you please update the installation video? Some changes have taken place between that and SketchUp2021, and I am unable to follow the instructions as given...and am still stuck and unable to install and use your plugins. Thank you.
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 91
                                            • 111
                                            • 112
                                            • 89 / 112
