    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
      @rodman
      Looks like it. The logs show this as what the user requested as address to send license to. Explains why it wasn't received.... 😐
      https://i.imgur.com/2hUOT9w.png
      • H
        hydboxhydbox
        Hi there,
        I have another technical question.
        If I want to draw a model of an inflated object without air ( only small bulbs left inside), like the ones in the picture. It’s much thinner comparing to the pillow example in instruction.
        So which ones of the parameters do I have to adjust?
        the Thickness of the object (Cloth tab —Thickness)
        the bubble inside (?)
        the slightly puffy edge (?)
        I have only used SketchUp for 3 months. And I was recommended Clothworks for this particular purpose. Or maybe it is not the best solution?
        Please help.
        Much appreciated.
        Yida
        • H
          hydboxhydbox
          @hydboxhydbox said:
          Hi there,
          Please help.
          Much appreciated.
          Yida
          This is what I get...never be able to get it quite even
          Or should I do the other way around, like draw a rectangle with thickness and then make the bubles separately? Use sandbox? But I tried sandbox, it can only create rectangle face not some puffy effect. I still want the most part of the object to look slightly puffy so it can be recognized as a flattened inflated object.
          • G
            gazzato70
            @rich o brien said:
            @gazzato70 said:
            Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
            The license logs show 3 devices in use with the most recent validation occurring 8 days ago...
            https://i.imgur.com/QgKtExV.png
            Thanks for the reply, so since I don't have release the licenses before formatting, nothing can be done? Did I get it right ? If this works I will be careful with the latest license actually in use (2021-10-08). However, the license of 2020-02-16 was of the old Laptop that I sold with only Windows 10 and the drivers installed while the license of 2021-05-25 is of the current Laptop that I purchased at the end of May 2021.
            One last question, in case of hard disk failure or computer theft (I hope it never happens !!) I would also lose the last available license and I would be forced to buy it again ??? Many thanks for the help even if I think there must be a solution, you should be able to see if the license is actually in use on some pc and not rely on the installation. Only in this way do I consider it right to impose such a strict rule. Thanks
            • ArisA
              Aris
              Hello,
              I bought clothworks some time ago but at some point I started having a problem with the license. I cannot find who to contact to solve this problem. Does anybody know?
              thanks!
              Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                Firstly install the latest version of the SketchUcation Toolset from the PluginStore.
                Restart SketchUp... any better ? ...
                If not, then someone more experienced will post what to try next........
                • ArisA
                  Aris
                  Yes, that was the first thing I did.
                    Did you try the steps in this parallel thread ?
                    https://sketchucation.com/forums/viewtopic.php?p=675083#p675083
                      So running the latest SketchUcation Tools and removing the signature from...
                      C;\Users\[YOURNAME]\AppData\Local\SCF Licenses
                      ...still results in this error?
                      What does querying your license allocation return?
                      https://i.imgur.com/0cNYZwL.png
                      https://i.imgur.com/aBEgf6O.png
                      Is it the error message you get when you query?
                      The A-0C error means your computer name and the computer name in your signature file are not the same. So the license cannot be validated.
                      • ArisA
                        Aris
                        Ok, it is now active.The steps I followed:
                        1. uninstall clothworks
                        2. manually removed everything in SCF licenses folder
                        3. reinstaled clothworks and validated license.
                        The only problem is that two of the 3 seats are taken when I only have one pc. (It's not actually a problem but I fear I'm going to have issues again and the seats will run out...
                          What would be good for us to know is how you arrived at this error?
                          It would seem you changed devices since the .scflicense file for FredoCorner detected that something changed.
                          Do you know what changed recently?
                          Also it is easy to release a license from a device to free up seats. You just need access to that device.
                          • ArisA
                            Aris
                            tbh I'm not sure but most probably it is the same pc that got upgraded. I don't remember ever installing it on a different device.
                            • jujuJ
                              juju
                              IIRC installations on the same hardware but for different versions of SketchUp is also counted.
                              • G
                                gazzato70
                                I haven't received any answers or solutions yet. Thanks.
                                  The license system philosophy is that no internet queries are needed to use a licensed plugin.
                                  That means the user needs to be aware of license allocation. Of course hardware failure happens and in this instance we release further seats.
                                  Just contact the extension dev. They can do it.
                                  Future license system updates are planned to allow online license releases etc.
                                  • E
                                    emmearch
                                    Hi, I wonder if anyone can help me: I have been using Clothworks paid version until today with no problem.
                                    Today I tried it and as soon as I start the simulation, Sketchup become unresponsive and I have to force close.
                                    It was working perfectly prior to today, I have already tried to delete it and reinstall, but to no avail. Any help would be appreciated.
                                    I'm on windows 10, did a system update yesterday (could it be that?), working with Xeon processor and a 1070ti GPU.
                                      Looking at what has changed on your computer since you last used it is a good idea. Clothworks didn't change. According to your profile you are using SketchUp 2017 Make and that hasn't changed in around 4 years. A Windows update might be the cause. Maybe a bad graphics driver that was included with the update?
                                      Have you tried it with a very simple model? Few subdivisions of the cloth component and a simple shape as a collider?
                                      • E
                                        emmearch
                                        Thanks for your reply, I should update my profile: I'm using the latest update of Sketchup (licensed of course), and it stops working when I try the simplest geometry.
                                        I'll try to update my graphics drivers..
                                          Can you share the .skp file you're trying to use Clothworks on? It would be interesting to also compare with another computer.
                                          • GD3DesignG
                                            GD3Design
                                            Hey Michael,
                                            Windows update's cause me all kinds of trouble. I have no idea if it will help with this situation or not, but after Windows updates I often need to uninstall & reinstall 'Microsoft C++ Distributables' to get my programs functioning again. If Clothworks uses C++ it could be ​affected...?
                                            (After last months update, I lost one of my NVMe drives from showing up in BIOS...and I still havent' got it working again.... (thanks MS)) 😞
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 35
                                            • 36
                                            • 29 / 36
