    Tax_Engineering v10.1 [plugin update]
    extensions
    43 Posts 8 Posters 27.4k Views 8 Watching
    • L
      LeoHominis
      Uau, por mais ferramentas assim no SketchUp. Parabéns mesmo. Espero que a trimble um dia se toque e de uma olhada para nós da impressão 3D e modeladores de mecânica. Nem todo mundo usa o SU para Arquitetura. Obrigado
      • TaxT
        Tax
        Hey Leo, thanks! I appreciate it.
        On 3d printing matter, theres the "SketchUp for 3D Printing" category:
        https://sketchucation.com/forums/viewforum.php?f=388
        As far as I know, SU still missing advanced 3d printing features. But its worthy to keep in tune on that, theres already some functions like import/export stl and slice. May be more.
        About mechanics.. theres some great old options
        mostly for bolts/screws and gears, such as Bolt maker (by Sam D Mitch):
        https://sketchucation.com/pluginstore?pln=Bolt_Maker
        There is much more possibilities (like hinges, pistons & structures)
        I'm trying to fill some of these blind spots. SU still has a great potential.
        Feel free to give some suggestions.
        Thanks again 😛
        "Between cause and consequence, lots of connivance."
        "Never felt being on same level as others; just bc Ive never been."
        • ntxdaveN
          ntxdave
          How about some documentation with some more detailed info about the tools and how to use them.
          Press F1...thank me later
          • TaxT
            Tax
            Sure! I may also post a video about it.
            Adding it on next updates.
            Thanks.
            • ntxdaveN
              ntxdave
              Thanks.
              Looking forward to it. Showing some examples (more than just a picture) would be good. As I have looked at your pictures (I.e. the chain links and springs), I wondered how you did it (what did the tool do to accomplish the model).
              • TaxT
                Tax
                Thanks.
                What about that?
                For more complex ones I may show some examples variations.
                Documentation concept idea
                • ntxdaveN
                  ntxdave
                  Ok, how do you make the chain follow a path (like around an object)?
                  • TaxT
                    Tax
                    Ok, not all fair advertising.
                    For physically realistic placed chains I used 6 other extensions:
                    1. Convexify (by: Fredo6): https://sketchucation.com/forums/viewtopic.php?f=323&t=61145
                    2. Curvizard (by: Fredo6): https://sketchucation.com/plugin/804-curvizard
                    3. BezierSpline (by: Fredo6): https://sketchucation.com/forums/viewtopic.php?f=323&t=13563
                    4. MSPhysics (by: Anton_S): http://sketchucation.com/forums/viewtopic.php?f=323&t=56852
                    5. ClothWorks (by: Anton_S): https://sketchucation.com/plugin/2053-clothworks
                    6. JHS Powerbar (by: CadFather, R Wilson, SD Mitch & others): https://sketchucation.com/pluginstore?pln=JHS_Powerbar_2019
                    Rendering/Composing: Vray + Photoshop.
                    Usage:
                    Mariner chains:
                    Step 1: Make a low poly mesh with same dimensions of final model.
                    Step 2: Convexify for solid slicing/decomposing, in order to allow MSPhysics to work properly.
                    Step 3: MSPhysics for physically realistic placing.
                    Roller chains:
                    Step 1: Make a line path.
                    Step 2: ClothWorks for physically realistic placing. (yes, it also works with lines)
                    Step 3: Curvizard for path smoothing.
                    Step 4: BezierSpline for equalizing path edges length, matching chain link length.
                    Step 5: JHS Powerbar for disposing chain link component along line path.
                    Resum:
                    Currently (for chains) Tax Tools only creates links mesh and displace them in line.
                    Maybe I add an auto "path placing" feature, but it wouldn't be as much realistic as this method.
                    • ntxdaveN
                      ntxdave
                      So, if I interpret correctly, your tool just draws the basic shape. We will the need to use other tools to supply them appropriately,
                      Just trying to clarify. 😄
                      • TaxT
                        Tax
                        Thats correct for now.
                        These are the current outputs for mariner and roller chains (using default values):Mariner chain output (v7.0)
                        Roller chain output (v7.0)
                        But I'm planning for that auto follow path feature, would save a lot of time.
                        obs: "Railroad along" already does that by default, it needs a selected path.
                        Railway along output (v7.0)
                        • ntxdaveN
                          ntxdave
                          I think that will make the tools far more attractive/useful. 👍
                          Hope I am not being a PITA. 😄
                          • TaxT
                            Tax
                            Thats great to know! thanks.
                            Then gonna focus on improving them.
                            Your being great, we all need feedback for the things we do.
                            Otherwise how could we learn anything 💚
                            • TaxT
                              Tax
                              Mariner chain done!
                              Recommendation: avoid sharp turns and check last/first chain link attaching.
                              Tell me if you guys find anything wrong.
                              Coming soon:
                              • Roller Chain Along (improvement)
                              • Selection counter (simple one)
                              • Follow & Rotate (Theres an old one but it doesnt work on newer SU versions)
                              • TaxT
                                Tax
                                "Roller chain along" done!
                                Also added "Selection report" and "SU links".
                                Enjoy.
                                obs: If you use it, feel free to share some images here.
                                "Follow and Rotate" may be comming next.
                                • TaxT
                                  Tax
                                  Base Modus UI implemented.
                                  • TutorialsUpT
                                    TutorialsUp
                                    Hi, Thank you so much for this great extension.
                                    I just stat creating a tutorial on this extension for my yt channel.
                                    I have a few questions
                                    • in Follow Rotate Scale what is the difference between Truncate and Always Z
                                      and
                                    • in Make Roller Chain it's "Roller Tickness" & "Plate Tickness" please review the names I think it should be "Thickness"?
                                    maybe I ask some more questions hope you will answer me.
                                    Thanks again.
                                      This is a very interesting set of tools. I could have used the roller chaiin tool some years ago for some projects.
                                      I wonder if I could make a couple of requests.
                                      1. It would be nice if there were no exposed back faces. In these examples the green color is my default back face color.
                                      Compared to the time it would take to model these things from scratch, correcting face orientations manually is fairly trivial but it could be nice to not have to worry about that.
                                      1. Would it be possible to do something about the definition scale? As it is now, at least with objects like the adjustable sprint and bicycle wheel, the objects are scaled but the definition isn't. That means that you can get clipping and the object will disappear if you open it for editing. Perhaps creating all of the objects as components and scaling their definitions after creation would be a good option. At least in my work flow I would prefer to use components throughout because that makes later edits to things easier.
                                      Thanks again for the tools.
                                      • C
                                        chapalee
                                        Hi how are you.
                                        Thanks for your plugin, it's very good.
                                        I wanted to ask you if you have any tutorial to create a cable.
                                        When trying to do so, many straight sections are visible.
                                        In what you can help me, I appreciate it.
                                        Thank you.
                                          You are using a Sketchy line style which makes the short segments visible. Either don't use a sketchy line style or weld all of the segments together and use a sketchy style that has long strokes or edit the style and turn off the edges altogether.
                                          • C
                                            chapalee
                                            Hello, thank you for your prompt help.
                                            I am working with the BZ_Tools.
                                            I don't know if I'm doing something wrong.
                                            But it shouldn't be, because I also have to do it with straight lines and it also looks segmented.
                                            The problem is that those segments are noticeable when rendering.
                                            As far as you can help me, I appreciate it.
                                            I am attaching the file where I am doing the tests.
                                            Cable.skp
                                            • 1 / 3
