    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • fredo6F Offline
      @drobble said:
      I have the plugin Fredo Corner vers. 1.9a installed on Sketchup 2017 (windows).
      When I seleect this plugin it pops up a message saying
      " This version of Fredo Corner has been expired. Please upgrade to the latest version."
      Well, as the message says, just upgrade to FredoCorner 2.0a.
      Do not forget to also upgrade to the most recent of LibFredo6. This is always good to keep my plugins up to date.
      • V Offline
        Vot_Blin
        How do I round an edge with full offset at one end and with zero offset at another?
        I saw the plug-in did it several times but I have no idea how to make it do. Green border lines are not parallel to the edge in this case.
        And one more question: how do I round just a corner not including its edges?
        • fredo6F Offline
          Mouse over the corner with no offset. When you see a purple dot, click on it and type 0.
          • E Offline
            el_feuro
            Hello,
            I have a weird problem.
            All controls are mirrored.
            http://sketchucation.com/forums/download/file.php?mode=view&id=162558&sid=5d0ac7a2415ecbdc19ff5940a78598d7
            How canunmirror it?
            Regards
            El
            • fredo6F Offline
              I guess you are on Mac Big Sur. It is a general problem on this platform (text labels should also be mirrored), not specific to my plugins.
              I don't know if there is a fix for that, from Apple or from Sketchup.
                DEICIDER78
                Hi, why in version 3.3a does not appear the repair command?
                  The Reapir command is a feature of FredoCorner, not RoundCorner. You can get FredoCorner here: https://sketchucation.com/pluginstore?pln=FredoCorner
                    mrjumpmanv2
                    V3.3a is showing it's expired even after downloading the latest one (3.3a is what the link it takes me to so i assume it's the most recent)
                    On a side note having it expire every month or two is very annoying. I can get why it might prevent people from complaining about older version but it causes more problems than it solves.
                    %(#000040)["Anyone who has never made a mistake has never tried anything new."
                    Albert Einstein]
                      Can you show what you are seeing that indicates that RoundCorner has expired? There's never been an expiration on RoundCorner. Fredo has done frequent updates on his extensions over the years although Round Corner hasn't had one since December of 2018. Is it possible you also have FredoCorner and you are seeing that its trial period has expired? If that's the case you can purchase a license for it and continue using it. Fredo6 has a sale going on right now, too.
                      What version of SketchUp are you using? Please complete your profile.
                        Kabayashi_san
                        Не работает на последних версиях скеча((( Что делать? 😢 😢 😢 😢
                        Doesn't work on latest sketch versions (((What to do? 😢 😢 😢 😢
                          It works fine in the latest versions. Here it is in SketchUp 2021.
                          Click on the picture
                          Maybe it's your model or your settings. Or maybe you need to install or update LibFredo6. You could also use FredoCorner.
                          Give specific information about what isn't working.
                          • E Offline
                            Einstein
                            Hello,
                            In SketchUp 2021 I got this error after installing Round Corner (see the attached screenshot).
                            The plugin seems to be working just fine, despite the error.
                            I just thought you might want to know about it. I was actually advised to report it to you anyway.
                              We need to wait for @Fredo's reply...
                              But before that.. do you have the latest LibFredo installed ?
                                Wasn't there an issue with the User name being "user" because of the \u thing?
                                • E Offline
                                  Einstein
                                  Yes, I had the latest LibFredo installed first.
                                  And indeed, my system username is "User". I don't know about any issue related to that, but maybe there is one.
                                  • fredo6F Offline
                                    I don't think this is related to username 'user'.
                                    I would suggest that you clean up LibFredo6 and RoundCorner and reinstall. Never seen this issue reported by other users. So, there must be something specific in your environment.
                                    • E Offline
                                      Einstein
                                      Actually, I'm now quite sure that this "something specific in my environment" is my system username starting with capital "U" letter, which causes an issue of Ruby interpreter. Here you can read more from smarter people than me:
                                      SketchUp keeps crashing when installing plugins
                                      Hello, I recently reinstalled the newest version of SketchUp and started installing my dozens of plugins from scratch. That’s what I was advised to do. I found time to manually install them one by one instead of just …
                                      SketchUp Community (forums.sketchup.com)
                                        szabgergo
                                        Hello there,
                                        I have some problems with the round corner plugin so I would like to ask for your help.
                                        There is a drawer front model and I would like to round the corners but it has some overlaps.
                                        How can I fix that issue in a way that it would look like it does on the attached photo.
                                        Thank you very much!
                                          Reduce the radius a bit. Or use FredoCorner. it seems to handle that better than Round Corner. Or use the Dave Method. Here I've created a component, copied it, scaled the copy up by 1000, run Round Corner on the big one, exited edit mode, deleted the giant copy and went back to the original.
                                            rv1974
                                            Variable radius fillets would look wonderful inside SU..
                                            https://www.youtube.com/watch?v=MGaZZ4frjLQ
                                            • 73
                                            • 74
                                            • 2 / 74
