    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • V
      Vot_Blin
      How do I round an edge with full offset at one end and with zero offset at another?
      I saw the plug-in did it several times but I have no idea how to make it do. Green border lines are not parallel to the edge in this case.
      And one more question: how do I round just a corner not including its edges?
      • fredo6F
        Mouse over the corner with no offset. When you see a purple dot, click on it and type 0.
        • E
          el_feuro
          Hello,
          I have a weird problem.
          All controls are mirrored.
          http://sketchucation.com/forums/download/file.php?mode=view&id=162558&sid=5d0ac7a2415ecbdc19ff5940a78598d7
          How canunmirror it?
          Regards
          El
          • fredo6F
            I guess you are on Mac Big Sur. It is a general problem on this platform (text labels should also be mirrored), not specific to my plugins.
            I don't know if there is a fix for that, from Apple or from Sketchup.
              DEICIDER78
              Hi, why in version 3.3a does not appear the repair command?
                The Reapir command is a feature of FredoCorner, not RoundCorner. You can get FredoCorner here: https://sketchucation.com/pluginstore?pln=FredoCorner
                  mrjumpmanv2
                  V3.3a is showing it's expired even after downloading the latest one (3.3a is what the link it takes me to so i assume it's the most recent)
                  On a side note having it expire every month or two is very annoying. I can get why it might prevent people from complaining about older version but it causes more problems than it solves.
                  %(#000040)["Anyone who has never made a mistake has never tried anything new."
                  Albert Einstein]
                    Can you show what you are seeing that indicates that RoundCorner has expired? There's never been an expiration on RoundCorner. Fredo has done frequent updates on his extensions over the years although Round Corner hasn't had one since December of 2018. Is it possible you also have FredoCorner and you are seeing that its trial period has expired? If that's the case you can purchase a license for it and continue using it. Fredo6 has a sale going on right now, too.
                    What version of SketchUp are you using? Please complete your profile.
                    • K
                      Kabayashi_san
                      Не работает на последних версиях скеча((( Что делать? 😢 😢 😢 😢
                      Doesn't work on latest sketch versions (((What to do? 😢 😢 😢 😢
                        It works fine in the latest versions. Here it is in SketchUp 2021.
                        Click on the picture
                        Maybe it's your model or your settings. Or maybe you need to install or update LibFredo6. You could also use FredoCorner.
                        Give specific information about what isn't working.
                        • E
                          Einstein
                          Hello,
                          In SketchUp 2021 I got this error after installing Round Corner (see the attached screenshot).
                          The plugin seems to be working just fine, despite the error.
                          I just thought you might want to know about it. I was actually advised to report it to you anyway.
                            We need to wait for @Fredo's reply...
                            But before that.. do you have the latest LibFredo installed ?
                              Wasn't there an issue with the User name being "user" because of the \u thing?
                              • E
                                Einstein
                                Yes, I had the latest LibFredo installed first.
                                And indeed, my system username is "User". I don't know about any issue related to that, but maybe there is one.
                                • fredo6F
                                  I don't think this is related to username 'user'.
                                  I would suggest that you clean up LibFredo6 and RoundCorner and reinstall. Never seen this issue reported by other users. So, there must be something specific in your environment.
                                  • E
                                    Einstein
                                    Actually, I'm now quite sure that this "something specific in my environment" is my system username starting with capital "U" letter, which causes an issue of Ruby interpreter. Here you can read more from smarter people than me:
                                    SketchUp keeps crashing when installing plugins
                                    Hello, I recently reinstalled the newest version of SketchUp and started installing my dozens of plugins from scratch. That’s what I was advised to do. I found time to manually install them one by one instead of just …
                                    SketchUp Community (forums.sketchup.com)
                                      szabgergo
                                      Hello there,
                                      I have some problems with the round corner plugin so I would like to ask for your help.
                                      There is a drawer front model and I would like to round the corners but it has some overlaps.
                                      How can I fix that issue in a way that it would look like it does on the attached photo.
                                      Thank you very much!
                                        Reduce the radius a bit. Or use FredoCorner. it seems to handle that better than Round Corner. Or use the Dave Method. Here I've created a component, copied it, scaled the copy up by 1000, run Round Corner on the big one, exited edit mode, deleted the giant copy and went back to the original.
                                          rv1974
                                          Variable radius fillets would look wonderful inside SU..
                                          https://www.youtube.com/watch?v=MGaZZ4frjLQ
                                            rosto
                                            Is it exist RoundCorner version for SU 2016 ?
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 74
                                            • 75
                                            • 67 / 75
