    1.5k Posts 477 Posters 4.1m Views 477 Watching
    • F
      fpsnyder
      Receiving an error message when trying to run FredoCorner after updating SketchUp Pro 2020 to version 20.2.172. Message reads "This version of FredoCorner has expired. Please upgrade to latest version. Currently have version 3.3a of FredoCorner installed and it was working fine just prior to the SketchUp update. I tried re-installing FredoCorner multiple time without avail...any suggestions?
      Apprecaited,
      Frank
      • Gus RG
        Gus R
        What's the scoop on FredoCorner?
        I just got a window to update and I went to the Pluginstore and downloaded RoundCorner_v3.3a.rbz and that was the wrong one so I found another page and downloaded FredoCorner_v2.0a.rbz which seems to be the right one.
        Checking for updates didn't indicate anything other than the library.
        It works now.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • Gus RG
          Gus R
          It works now.
          Not enough sleep.
          • O
            oszinapsugarbasel
            Hello.
            I have a Pro trial version
            I installed the plugin
            the plugin is in the extension manager. is enabled!
            but I can't find it anywhere in the program ... Not in the tools menu either!
            Where to find?
            how can i bring it up
              Did you also install the required LibFredo6 files?
                drobble
                Hiya,
                I have the plugin Fredo Corner vers. 1.9a installed on Sketchup 2017 (windows).
                When I seleect this plugin it pops up a message saying
                " This version of Fredo Corner has been expired. Please upgrade to the latest version."
                What do I'm doing wrong or what goes wrong here?
                Any hint is much appreciated.
                <<<see attached screenshot?>>>
                • fredo6F
                  Well, as the message says, just upgrade to FredoCorner 2.0a.
                  Do not forget to also upgrade to the most recent of LibFredo6. This is always good to keep my plugins up to date.
                  • V
                    Vot_Blin
                    How do I round an edge with full offset at one end and with zero offset at another?
                    I saw the plug-in did it several times but I have no idea how to make it do. Green border lines are not parallel to the edge in this case.
                    And one more question: how do I round just a corner not including its edges?
                    • fredo6F
                      Mouse over the corner with no offset. When you see a purple dot, click on it and type 0.
                      • E
                        el_feuro
                        Hello,
                        I have a weird problem.
                        All controls are mirrored.
                        http://sketchucation.com/forums/download/file.php?mode=view&id=162558&sid=5d0ac7a2415ecbdc19ff5940a78598d7
                        How canunmirror it?
                        Regards
                        El
                        • fredo6F
                          I guess you are on Mac Big Sur. It is a general problem on this platform (text labels should also be mirrored), not specific to my plugins.
                          I don't know if there is a fix for that, from Apple or from Sketchup.
                            DEICIDER78
                            Hi, why in version 3.3a does not appear the repair command?
                              The Reapir command is a feature of FredoCorner, not RoundCorner. You can get FredoCorner here: https://sketchucation.com/pluginstore?pln=FredoCorner
                                mrjumpmanv2
                                V3.3a is showing it's expired even after downloading the latest one (3.3a is what the link it takes me to so i assume it's the most recent)
                                On a side note having it expire every month or two is very annoying. I can get why it might prevent people from complaining about older version but it causes more problems than it solves.
                                %(#000040)["Anyone who has never made a mistake has never tried anything new."
                                Albert Einstein]
                                  Can you show what you are seeing that indicates that RoundCorner has expired? There's never been an expiration on RoundCorner. Fredo has done frequent updates on his extensions over the years although Round Corner hasn't had one since December of 2018. Is it possible you also have FredoCorner and you are seeing that its trial period has expired? If that's the case you can purchase a license for it and continue using it. Fredo6 has a sale going on right now, too.
                                  What version of SketchUp are you using? Please complete your profile.
                                  • K
                                    Kabayashi_san
                                    Не работает на последних версиях скеча((( Что делать? 😢 😢 😢 😢
                                    Doesn't work on latest sketch versions (((What to do? 😢 😢 😢 😢
                                      It works fine in the latest versions. Here it is in SketchUp 2021.
                                      Click on the picture
                                      Maybe it's your model or your settings. Or maybe you need to install or update LibFredo6. You could also use FredoCorner.
                                      Give specific information about what isn't working.
                                      • E
                                        Einstein
                                        Hello,
                                        In SketchUp 2021 I got this error after installing Round Corner (see the attached screenshot).
                                        The plugin seems to be working just fine, despite the error.
                                        I just thought you might want to know about it. I was actually advised to report it to you anyway.
                                          We need to wait for @Fredo's reply...
                                          But before that.. do you have the latest LibFredo installed ?
                                            Wasn't there an issue with the User name being "user" because of the \u thing?
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 74
                                            • 75
                                            • 67 / 75
