    [Plugin] QuadFaceTools
    680 Posts 116 Posters 713.8k Views 116 Watching
    • panixiaP Offline
      panixia
      @teknoel said:
      Has anybody had any luck transforming terrain imported through Trimbel's native location importer into quads?
      I do this all the times. That's not about luck.. All you need are a couple of selection filters and a little bit of reasoning ๐Ÿ˜›
      • E Offline
        Einstein
        Is this normal? When I use Offset Loop tool I cannot type offset value in VCB. I can only use graphic inferencing.
          kat_m
          I canโ€™t divide it into the required number of segments. There is a number 1, which I canโ€™t change. What is the reason for this?
            Can't divide what? Provide an example .skp file so we can see what you are talking about.
            What version of SketchUp are you using. Your profile says "2020 Free/Make" but there is no such version. Please correct your profile.
            • E Offline
              Einstein
              I can see there is a new version. What has changed? There is no changelog.
                Builder54
                This is a recent error I'm getting. I can reliably reproduce this
                Offset Loop Error
                "Don't be afraid of working hard. There are No shortcuts to mastering something."
                Robh Ruppel
                  Builder54
                  So after a little troubleshooting, I discovered that the error only occurs when a single line is selected. For example, selecting a series of lines on a sphere, the offset loop worked properly. Also selecting 2 connected lines on a flat rectangular surface works fine as well. Selecting a single line as in the above example I posted, produces the error. My question: Is this normal? I know this is not a licensed plugin. I just want to know if its working as it should.
                  Robh Ruppel
                    Builder54
                    Best kept secret
                    Poles present a challenge to anyone modelling in quads.
                    Types of poles as described by **Thomas Thomassen
                    These appear when you enable the "Highlight Poles" option from the QFT Selection tool's context menu.
                    These refer to how menu (many) edges a vertex connect to:
                    • N poles: 3
                    • E poles: 5
                    • X poles: more than 5
                      It's there to visualize where the mesh isn't a regular grid pattern. Typically where the flow of the topology changes.**
                    QuadFace Tools has an option to see the poles in your model. Watch the Gif to see how.
                    Robh Ruppel
                    • E Offline
                      Einstein
                      I have a little suggestion.
                      Currently the color live mesh analysis uses real sketchup materials and thus is destrudtive. Any materials that were already applied to faces, get wiped away. I don't think there is any way to restore them. Is there?
                      So I was thinking,
                      Maybe this tool could work non-destructively, by overlaying the topology-indicating colors on top of the screen, instead of painting faces. This would protect any materials that are already applied to faces. That would be a much welcome change.
                        rv1974
                        @panixia I saw offset loop icon in your video. How did you get it?
                        P.S. Too bad it doesn't respect VCB inputs ๐Ÿ˜•
                        • panixiaP Offline
                          panixia
                          The icon is available in the plugin icon folder, and the tool itself is still present in the sub-menu of quadface tools, but it's turned off from the toolbar in the current build.
                          I built that button myself using the "Toolbar Editor" plugin and the existing icon.
                          Same for the "convert to plain mesh button", and tons of other custom buttons I created for other stuff.
                          Sometimes I create the icons for them, sometimes I borrow from other plugins and/or modify them.
                            rv1974
                            hmm its strange why TT turned off this icon
                            • panixiaP Offline
                              panixia
                              As far as I remenber, this was intentional, because that's a bit of a beta/buggy tools and you should "use at your own risk".
                              However, I have to say that I use it a lot as it is and that works perfect in 95% of cases for me.
                              • O Offline
                                optimaforever
                                Hi thom!
                                Is it possible to have 4K screen compliant icons?
                                On my laptop it's nearly impossible to see the values of the connect edges tools window...
                                  chapalee
                                  Hi Tom, how are you?
                                  Thanks for your help as always.
                                  I want to show you some examples of meshes that I use.
                                  I never manage to convert them completely to quadface.
                                  I don't know if I'm doing something wrong.
                                  Or is there some way to do it completely.
                                  When there are many meshes, it is a very laborious job.
                                  Thank you.
                                  Convert.skp
                                    Looks like your mesh was generated with SSB. The border polygon's is too much to ask QFT.
                                    QFT expects a certain mesh input. SSB doesn't generated a compliant mesh. More planning, or manual fixing, is needed on your end I'm afraid.
                                    • V Offline
                                      Vizan
                                      @thomthom said:
                                      I'm not sure what I'm looking at there...
                                      I sounds like this is an issue that relate particularly to rizomUV. Though I can't really tell exactly what is going on. But I can verify that QFT exports OBJs in such a manner that the faces share vertices.
                                      If you could find out more what is happening on the rizomUV side then I could look into whether there are some tweaks that can be done on the side of QFT.
                                      Perhaps, do you have a model where exported from another app into OBJ works fine for rizomUV - but doesn't work when exported from QFT?
                                      You have done a good export to obj format, but it is not perfect, it needs some work...
                                      https://youtu.be/MkuSQ3oERcg
                                      https://youtu.be/-IMeyyvWEEc
                                      • O Offline
                                        optimaforever
                                        Hello Thom
                                        I have a bug I think.
                                        When I try to remove loops QFT leaves hidden vertex that produces unwanted ngons when Subded.
                                          chrisprattguys
                                          The last couple of times I've used this plugin I have been unable to key in numbers using the Connect Edges Tool. It had worked perfectly until recently, so I'm not sure what to do. It is stuck on 2/0 respectively. I have uninstalled and reinstalled the plugin, and have made sure my Sketchup and Windows are up to date. I'm using Sketchup Pro 21.1.332 64 Bit. Any help would be appreciated, as I use this function often in my workflow.
                                            Just click in the input box then type
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
