    [Plugin] QuadFaceTools
    680 Posts 116 Posters 699.2k Views 116 Watching
    • panixiaP Offline
      panixia
      @einstein said:
      If I export a model with quad topology using QuadFace Tools' OBJ Exporter and import it to Blender, it should theoretically import with quads retained. In fact, the mesh imports triangulated, as in the screenshot.
      Did you try to do what I described above about 3dsmax? It could be basically the same in blender..
      • F Offline
        Forrest09
        Hello, is there a way I can hover over an edge and choose where to place the loop instead of inserting it in the middle ? (using Quadface tools)
        • panixiaP Offline
          panixia
          try offset loop.
          • E Offline
            Einstein
            Hi!
            Do you know any trick to quickly inset a quad, like in the picture?
            The one on the right I did with Fredo's Offset on surface (Tools on surface) but as you can see, it didn't do good job.
            The one on the left I made manually but that takes time when I want to make more individual insets.
            • panixiaP Offline
              panixia
              A proper inset function would be great..
              Meanwhile the best workaround I've found is to perform a small joint push pull with maximum molding amount and then refine with vertex tools. See what I do in this video.
              How did you obtain that beautiful dark interface? I need one myself. β˜€
              • E Offline
                Einstein
                Right, this is quite good workaround πŸ˜„
                As for dark interface: gotta admit I waited for the day somebody would ask about that haha πŸ˜„
                I use Windows 7 and I installed an external system theme that was designed to look like Steam gaming platform. It affected SketchUp appearance. I had to first patch system settings to allow installing external themes but it was easy. Note that the changed theme will affect some other program interfaces too, e.g. ArchiCAD, CorelDRAW, Notepad but not: Blender, Unity, MS Office, Autodesk programs.
                If you write me a private message, I'll give you more precise instructions cuz it's an offtop now πŸ˜„
                • panixiaP Offline
                  panixia
                  Thank you, but unfortunately I'm forced to use windows 10.. πŸ˜•
                    TeKnoel
                    that's some next level quad stuff!! Has anybody had any luck transforming terrain imported through Trimbel's native location importer into quads? It seems like it should be straight forward but it doesn't seem to work well. There seems to be something odd about the exterior edge that causes quadface to ignore it. I'd love some imput on this. I'm trying to figure out a work flow that would alow me to drop a hi rez terrain generated by toposhaper (which works well with quads) into a mesh imported from trimble. the ultimate idea is to bring it into blender to sculpt and paint and the back into sketchup. Its mostly working but the flow is a little janky. If you have any thoughts i'd love to hear them.
                    • panixiaP Offline
                      panixia
                      I do this all the times. That's not about luck.. All you need are a couple of selection filters and a little bit of reasoning πŸ˜›
                      • E Offline
                        Einstein
                        Is this normal? When I use Offset Loop tool I cannot type offset value in VCB. I can only use graphic inferencing.
                          kat_m
                          I can’t divide it into the required number of segments. There is a number 1, which I can’t change. What is the reason for this?
                            Can't divide what? Provide an example .skp file so we can see what you are talking about.
                            What version of SketchUp are you using. Your profile says "2020 Free/Make" but there is no such version. Please correct your profile.
                            • E Offline
                              Einstein
                              I can see there is a new version. What has changed? There is no changelog.
                                Builder54
                                This is a recent error I'm getting. I can reliably reproduce this
                                Offset Loop Error
                                "Don't be afraid of working hard. There are No shortcuts to mastering something."
                                Robh Ruppel
                                  Builder54
                                  So after a little troubleshooting, I discovered that the error only occurs when a single line is selected. For example, selecting a series of lines on a sphere, the offset loop worked properly. Also selecting 2 connected lines on a flat rectangular surface works fine as well. Selecting a single line as in the above example I posted, produces the error. My question: Is this normal? I know this is not a licensed plugin. I just want to know if its working as it should.
                                  Robh Ruppel
                                    Builder54
                                    Best kept secret
                                    Poles present a challenge to anyone modelling in quads.
                                    Types of poles as described by **Thomas Thomassen
                                    These appear when you enable the "Highlight Poles" option from the QFT Selection tool's context menu.
                                    These refer to how menu (many) edges a vertex connect to:
                                    • N poles: 3
                                    • E poles: 5
                                    • X poles: more than 5
                                      It's there to visualize where the mesh isn't a regular grid pattern. Typically where the flow of the topology changes.**
                                    QuadFace Tools has an option to see the poles in your model. Watch the Gif to see how.
                                    Robh Ruppel
                                    • E Offline
                                      Einstein
                                      I have a little suggestion.
                                      Currently the color live mesh analysis uses real sketchup materials and thus is destrudtive. Any materials that were already applied to faces, get wiped away. I don't think there is any way to restore them. Is there?
                                      So I was thinking,
                                      Maybe this tool could work non-destructively, by overlaying the topology-indicating colors on top of the screen, instead of painting faces. This would protect any materials that are already applied to faces. That would be a much welcome change.
                                        rv1974
                                        @panixia I saw offset loop icon in your video. How did you get it?
                                        P.S. Too bad it doesn't respect VCB inputs πŸ˜•
                                        • panixiaP Offline
                                          panixia
                                          The icon is available in the plugin icon folder, and the tool itself is still present in the sub-menu of quadface tools, but it's turned off from the toolbar in the current build.
                                          I built that button myself using the "Toolbar Editor" plugin and the existing icon.
                                          Same for the "convert to plain mesh button", and tons of other custom buttons I created for other stuff.
                                          Sometimes I create the icons for them, sometimes I borrow from other plugins and/or modify them.
                                            rv1974
                                            hmm its strange why TT turned off this icon
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
