    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 686.2k Views 39 Watching
    • G
      GalvinHRO
      with the AMS library i can get the name of the default tray but not the object itself or the child dialogs like "Materials" or "Entity Info" anybody knows if this feature exist or a workaround. If not is it possible to make one with the win32API?
        Anton_S
        Galvin,
        The Tray window structure in SU2018 is as follows:
        Provided that you have the handle of the tray, you can then obtain the first two levels of child windows, and then iterate through all windows of that child window to get all the dialogs.
        With AMS Library, you can use the following function to get all trays:
        trays = AMS;;Sketchup.get_active_dialogs.find_all { |handle|
          AMS;;Window.get_class_name(handle) =~ /Afx;MiniFrame/i
        # => [133134]
        Then once you have the trays, you can get the first two levels of child windows:
        trays.each { |tray|
          c1 = AMS;;Window.get_related(tray, 5) # GW_CHILD
          next unless c1
          c2 = AMS;;Window.get_related(c1, 5) # GW_CHILD
          next unless c2
          dialogs = AMS;;Window.get_child_windows(c2, false, false)
          panes = dialogs.find_all { |dialog|
            AMS;;Window.get_class_name(dialog) =~ /CPanelHeader/i
          panes.each { |pane|
            # First child window contains pane caption
            c3 = AMS;;Window.get_related(pane, 5) # GW_CHILD
            next unless c3
            puts AMS;;Window.get_caption(c3)
        # => Layers
        # => Shadows
        # => Fog
        # => Materials
        # => Soften Edges
        # => Styles
        # => Entity Info
        Note that this will not work with sketchup versions prior to 14.
        Anton
        • H
          Headcase6969
          Mac=NOPE!
            April Zylith
            MSPhysics_v1.0.3 does not work on SU 2019.
            What should I do?
            System:
            OS: Windows 10 Pro 64 bit.
            App: Sketchup Pro 2019 64 bit.
            When open SU 2019, Showing These errors.
              What should I do?
              You're right. It doesn't work. What can you do? Be patient. The author has been working on an update and will release it when it is ready.
              • Y
                young77
                Hi...
                I just want to make sure is this plugin doesnt work for sketchup 2021 ?
                is there any possible way to make this enable to run in skp 2021 ?
                thanks,
                Hp
                • P
                  pipinek
                  @young77 said:
                  Hi...
                  thanks,
                  Hp
                  Splendid plugin,
                  any updates for SSU 2021. Even paid?
                  Thank you in advance if any
                  • Q
                    qifu123
                    I need some help, AMS Library 3.6.0h In sketchup 2021 error
                    载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb 时出错
                    Error: #<IOError: The required, staged c extension file, "C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.7/ams_lib.so", is missing!>
                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb:148:in <top (required)>'
                    C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in load'
                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in module:Lib'
                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:7:in <module:AMS>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:5:in <top (required)>'
                    • P
                      pibuz
                      Same here. AMS lib is not compatible with SU2021, or so it seems..
                      It's a pity.. 😞
                      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                      • W
                        wikii
                        AMS lib is not compatible with SU2021.
                          Anton_S
                          Updated for 2021
                          • F
                            Francis sket master
                            Dear Anton_S
                            After installation of MSPhysics & AMS Library by sketchUcation extensionstore v4.1.0 following is the error message keep pops up as I start sketchup pro 2021. Anticipating your answer with solutions. Thank you very much in advance.
                            C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb file load error
                            Error: #<IOError: The required, staged c extension file, "C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.7/msp_lib.so", is missing!>
                            C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:219:in block in require_all' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in each'
                            C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in require_all' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                            C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                            C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in require'
                            C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in load' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                            C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                              DeKlusser
                              I am only getting a lot of errors like:
                              Error Loading File C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb
                              Error: #<IOError: The required, staged c extension file, "C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.7/msp_lib.so", is missing!>
                              C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:219:in block in require_all' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in each'
                              C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in require_all' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                              C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in require'
                              C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in load' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                              C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                                Your load errors come from MSPhysics which does not work in SketchUp 2021. Anton has indicated he's working on an update but he hasn't released it yet.
                                Your profile says you are still using Sketchup 2018. Please update that information. Thanks.
                                • B
                                  Beltrama01
                                  I'm looking forward to an update to run MSPhysics in sketchup 2021
                                  • X
                                    xaliuyi Newcomers
                                    this plugin is very good:thumb:
                                      rcatedra
                                      Hello all. I'm using this plugins since 2015 and it's amazing. Now i'm learning an advanced programming features, and I noticed when I uses for instance the key ('a') function into an slider controller, I have the following error (ruby console): "Nomethoderror: undefined method 'key' for AMS::Keyboard:Module"
                                      I attach a picture to see my settings. Any clue about this? I've tried to uninstall and install the AMS library and msphysics several times. I have Sketchup 2016 version and the 3.7.1b AMS version
                                      Thanks on advance!
                                      • W
                                        wikii @Anton_S
                                        @Anton_S
                                        AMS lib is not compatible with SU2024.
                                        Will you update it?
                                        K 1 Reply Last reply
                                        • K
                                          kuikeil @wikii
                                          @wikii My extension also uses this lib, and I urge the author to make it compatible with 2024.
                                            Rich O Brien Moderator @kuikeil
                                            @kuikeil Anton is aware that some of his tools need updating.
                                            • 5 / 6
