    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 686.2k Views 39 Watching
    • W
      wikii
      How to get the version number?
      AMS.ver ?
        Anton_S
        Use AMS::Lib::VERSION It returns a string like "3.3.0".
        • Bryan KB
          @anton_s said:
          Bryan, in case you're wondering if it's a plugin, well it's not. AMS library is more of a dependency for a few of my other plugins.
          Thanks Anton, but what I'm looking for is how to use it. It's installed without a problem but I need some kind of instructions or tutorial on how to use the controls.
          Thanks.
            Anton_S
            The first post contains a link to the library's documentation. I not particularly sure if that's what you desire though.
            • Bryan KB
              Anton, thanks. I found some great video tutorials. https://www.youtube.com/user/samketner/videos?sort=dd%26amp;view=0%26amp;shelf_id=0
              My new problem is that the UI menu is not displaying correctly nor or the contents.. There are no tabs and the menu window is not resizable so I cannot access the contents at the bottom of the screen.
              Here is a screen shot.
              Any ideas?
              • L
                ladyquestio
                I keep getting this error. What is happening?
                http://tanyaloser.tripod.com/loaderror10.JPG
                  Anton_S
                  Hmm. I'm not getting any errors in my SU8. Are you using the latest versions of both plugins? If not, try completely removing both and installing once again.
                  Edit: Actually I'm getting a similar error when I attempt to start MSPhysics simulation in SU8. I haven't been able to determine the cause, so try sticking to SU2013+.
                  Edit: I will ensure the compatibility with SU version prior to 2013 at some point.
                  • L
                    ladyquestio
                    Anton:
                    I removed all the files as per instruction. Defragged the HD. then reloaded SU8 . I have a video of what happens.
                    Watch and see. then Tell me what I did wrong.
                    https://youtu.be/nUL87J2N79A
                      Anton_S
                      Sorry, I forgot to test it on Windows XP. It should be fixed now. Upgrade to AMS Library, version 3.5.2.
                      • G
                        GalvinHRO
                        with the AMS library i can get the name of the default tray but not the object itself or the child dialogs like "Materials" or "Entity Info" anybody knows if this feature exist or a workaround. If not is it possible to make one with the win32API?
                          Anton_S
                          Galvin,
                          The Tray window structure in SU2018 is as follows:
                          Provided that you have the handle of the tray, you can then obtain the first two levels of child windows, and then iterate through all windows of that child window to get all the dialogs.
                          With AMS Library, you can use the following function to get all trays:
                          trays = AMS;;Sketchup.get_active_dialogs.find_all { |handle|
                            AMS;;Window.get_class_name(handle) =~ /Afx;MiniFrame/i
                          # => [133134]
                          Then once you have the trays, you can get the first two levels of child windows:
                          trays.each { |tray|
                            c1 = AMS;;Window.get_related(tray, 5) # GW_CHILD
                            next unless c1
                            c2 = AMS;;Window.get_related(c1, 5) # GW_CHILD
                            next unless c2
                            dialogs = AMS;;Window.get_child_windows(c2, false, false)
                            panes = dialogs.find_all { |dialog|
                              AMS;;Window.get_class_name(dialog) =~ /CPanelHeader/i
                            panes.each { |pane|
                              # First child window contains pane caption
                              c3 = AMS;;Window.get_related(pane, 5) # GW_CHILD
                              next unless c3
                              puts AMS;;Window.get_caption(c3)
                          # => Layers
                          # => Shadows
                          # => Fog
                          # => Materials
                          # => Soften Edges
                          # => Styles
                          # => Entity Info
                          Note that this will not work with sketchup versions prior to 14.
                          Anton
                          • H
                            Headcase6969
                            Mac=NOPE!
                              April Zylith
                              MSPhysics_v1.0.3 does not work on SU 2019.
                              What should I do?
                              System:
                              OS: Windows 10 Pro 64 bit.
                              App: Sketchup Pro 2019 64 bit.
                              When open SU 2019, Showing These errors.
                                What should I do?
                                You're right. It doesn't work. What can you do? Be patient. The author has been working on an update and will release it when it is ready.
                                • Y
                                  young77
                                  Hi...
                                  I just want to make sure is this plugin doesnt work for sketchup 2021 ?
                                  is there any possible way to make this enable to run in skp 2021 ?
                                  thanks,
                                  Hp
                                  • P
                                    pipinek
                                    @young77 said:
                                    Hi...
                                    thanks,
                                    Hp
                                    Splendid plugin,
                                    any updates for SSU 2021. Even paid?
                                    Thank you in advance if any
                                    • Q
                                      qifu123
                                      I need some help, AMS Library 3.6.0h In sketchup 2021 error
                                      载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb 时出错
                                      Error: #<IOError: The required, staged c extension file, "C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.7/ams_lib.so", is missing!>
                                      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
                                      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb:148:in <top (required)>'
                                      C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in load'
                                      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in module:Lib'
                                      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:7:in <module:AMS>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:5:in <top (required)>'
                                      • P
                                        pibuz
                                        Same here. AMS lib is not compatible with SU2021, or so it seems..
                                        It's a pity.. 😞
                                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                        • W
                                          wikii
                                          AMS lib is not compatible with SU2021.
                                            Anton_S
                                            Updated for 2021
                                            • 4 / 6
