    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.6k Views 92 Watching
      Builder54
      Feature request
      I would love to be able to achieve smooth curves
      A work around I'm using is Shape Bender by Chris Fulmer
      "Don't be afraid of working hard. There are No shortcuts to mastering something."
      Robh Ruppel
        Are you looking for something other than what Shape Bender offers?
          Builder54
          Since Vertex Tools already has multi-plane rotation capabilities, I was asking if options could be added that would allow for the bending of a given series of vertices and faces into a smooth arc form. As you noted it is not essential since there already exists plugins such as Shape Bender. When I wrote the post, I was experimenting with "primitives", ie box, spheres, cylnders etc. So being able to "pull/stretch" a cylinder out to a point in an arc form from within Vertex Tools would I think be very helpful.
          Edit
          I also have True Bend which works really well. I'm probably just spoiled 😐
          Robh Ruppel
          • E Offline
            Einstein
            Hello Thom Thom,
            Sorry I am responding back to your post so late, but lately I was the one to have rather hard (busy) time πŸ˜‰
            You asked me to specify exactly what I meant by that request:
            "bevel vertices with more segments (like Fredo Corner, but Fredo Corner doesn't work with flat faces)"
            My suggestion was to enable not only bevelling vertices but also rounding them. So let's say bevelling means that you add one edge at a vertex between two existing edges and rounding means that you add more edges and create an arc between them. Like in Blender - you bevel a vertex and use mouse scroll to add more segments. This is the feature I pursue. There are several corner-rounding tools for SketchUp but none of them allows manipulating vertices directly, like your plugin does. That's why I believe my suggestion makes sense πŸ˜‰
              Gotcha. Yea, I have it on my list of ideas already. Rounding, or profiled, bevels are however much more complicated. I need to do more research for that.
              • E Offline
                Einstein
                I've got one more feature suggestion.
                Merge close vertices "through groups", so if many groups/ components are selected, instead of raw geometry, vertice merge can also be performed. Currently it seems that we can only work on raw geometry. Merging vertices is sometimes a crucial fixing/ optimization algorithm and it's good if it can process many objects at once.
                I recently worked with a model - bunch of people, hundreds of thousands of faces altogether and it got imported so bad that every single face was separate, can you imagine that... I mean, I know you can. I worked around by exploding all the groups, merging the vertices and regrouping with "Loose to groups" plugin, but I would rather not repeat that in SketchUp anymore...
                  hmm... main challenge here is that VT doesn't have any way to select anything other than vertices... Will have to think about this one.
                  • FletchF Offline
                    Fletch
                    Hi ThomThom, your website says to post here, so... please forgive me if this is not the right place.
                    I purchased VT in Jan 2020.
                    The version I had downloaded in Jan 2020 throws an error when I try to install.
                    Must I now buy a whole new version just so that it will work in SU2021? Or do you have a version I can continue to use even in SU2021?
                    Fletch
                    • E Offline
                      Einstein
                      I'd like to say something more about vertex bevel here (I hope you don't have enough of me yet πŸ˜› ).
                      I was able to reproduce the bug I once had when bevelling vertices of a face and I noticed two undesired things happening:
                      1. After selecting all verts of the Y letter and bevelling them a little the face gets removed, leaving only the edges. That I find a bug.
                      2. Bevel widths are uneven and these bevel are unsymmetrical. I guess that's because bevel values here are not absolute but relative to the length of bevelled edges. This surely makes sense, but it would also be very nice having another option for symmetrical bevels with absolute offset. Perhaps this could be performed by simply adding a unit following a typed value, just like in native SketchUp. For example, type "0.1m" instead of "0.1" in the VDB to get the absolute value.
                      Y.skp
                      • E Offline
                        Einstein
                        Version 2.0.5 - again: what is new?
                        • jo-keJ Offline
                          jo-ke
                          I have updated SU2021 to 21.1.299 64 bits and vertextools disappeared.
                          I tried to reinstall, but it doesn't show it.
                          It is shown in extension manager but not shown in Menubar to select
                          What can I do?
                          http://www.zz7.de
                            I see it in the latest release of 2021 on my machine.
                            Is it shown as Enabled in the Extension Manager?
                            • jo-keJ Offline
                              jo-ke
                              yes, it is
                              http://www.zz7.de
                                Latest version of both TT_Lib2 and Vertex Tools installed?
                                • N Offline
                                  numerobis
                                  I don't know, if this has been discussed before, but Vertex Tools 2 is crashing a lot for me (SU 2021). Sometimes every few minutes. Not the whole plugin or SU, but the gizmo disappears and i have to restart SU to get it back. It's possible that it is related to the SU autosave, since i see the windows "wait cursor" and the program is freezing for a short time, just before the operation is canceled and the gizmo disappears forever. πŸ˜•
                                    arxitekt
                                    @thomthom said:
                                    @rv1974 said:
                                    TT could you add 'lock perimeter' feature please?
                                    I have a feature request logged named "Lock Vertices". Would this be the same thing?
                                    Hello ThomThom πŸ˜„ Fellow Norwegian here.
                                    I am in need of a way to lock a set of terrain mesh vertices(property boundaries), from a larger landscape terrain. I want to do this to be able to manipulate only the terrain with this property line, without affecting the mesh beyond, leaving the correct elevations for the surrounding properties.
                                    I have experimented with:
                                    • Grouping a set of "border" faces and edges and then locking these. This kinda works, leaving the surrounding mesh as-is, but it detaches the property mesh from this group and gaps in the faces between are introduced when manipulating the mesh. (This could be corrected by manually adding new faces to close the gap, after the terrain is finsished, but does not cater well for effectively reworking this terrain later)
                                    • Artisan crease, but this locking of edges/vertices does not support vertex editing tools, only smoothing and sculpting
                                    • I like your Vertex Tools2 for manipulating mesh, but locking vertices is sorely missing.
                                    Is this feature on still in your backlog or in development now?
                                    Thank you for great tools!
                                    /arxitekt
                                    • O Offline
                                      optimaforever
                                      Hello Thomthom
                                      I have a question / bug about Bridge.
                                      When I select 2 vertices and ask for Bridge, VT2 generates 2 quads, surimposed.
                                      Example:
                                      I select vertices (1) and (2) and launch bridge
                                      Then VT generates a double quad (3)
                                      How to avoid this?
                                      • panixiaP Offline
                                        panixia
                                        I confirm this happens when you try to bridge 2 edges which are not coplanar.
                                        doesn't happen if they are more than 2 or if they are 2 but still coplnar.
                                        • O Offline
                                          optimaforever
                                          Ok, so a workaround would be to break/divide the vertices before doing bridge?
                                          • panixiaP Offline
                                            panixia
                                            Honestly I wasn't trying to propose a workaround, just trying to better "isolate" the problem to give some more clue to Thomas. πŸ˜›
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
