    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.6k Views 92 Watching
      Builder54
      Bug Splat
      Bug Splat
      "Don't be afraid of working hard. There are No shortcuts to mastering something."
      Robh Ruppel
        @builder54 said:
        Bug Splat
        Oh - you mean that dialog? That is not a BugSplat. BugSplat is a dialog from SketchUp when it crashes. It says BugSplat in the dialog.
        That error dialog is from Vertex Tools itself - catching bugs in Vertex Tools. I know they might feel much the same, but the distinction is important. You only see BugSplats when SketchUp crashes (exits).
        Can you reliably reproduce the error? If so, can you send me the model and step by step instructions?
          @builder54 said:
          I do encounter Bug Splats frequently. I sent off a few of them, and recently with my name and email address. It appears to me that they happen most often when I hold down the CTRL key to create new vertices. The next time it happens I'll record the movement that's causing the bug splat before I get out of it.
          I'm not finding any error reports for VT2 coming from SketchUp 17 users the last month that has any name or email attached.
          Did you in this case really mean the SketchUp BugSplat dialog? Not the Vertex Tools error dialog?
            Builder54
            @thomthom said:
            @builder54 said:
            Bug Splat
            Up to now I have not been developing a single model, rather gaining experience with organic modelling tools. So I will take on a small project and see if I can reproduce the error messages. On a side note, I know that Quad Face Tools was recently updated. I was attempting to use the offset loop option but kept getting the same error message that VT2 is giving me. I've used to offset loop in the past without any problems. I thought I would mention it because they are both your plugins. I'll send you what you need as soon as I can reproduce the problem in VT2.
            Robh Ruppel
              Builder54
              I can't be sure. I do remember Sketchup shutting down suddenly and giving me a Bug Splat recently, but I don't remember how I handled it.
              Robh Ruppel
                Can you post back what that error message was?
                  Builder54
                  I was referring to the Error Report Box. I posted the gif in Quadface Tools thread. Sorry I don't know how to reference the post.
                  Robh Ruppel
                    Builder54
                    Feature request
                    I would love to be able to achieve smooth curves
                    A work around I'm using is Shape Bender by Chris Fulmer
                    Robh Ruppel
                      Are you looking for something other than what Shape Bender offers?
                        Builder54
                        Since Vertex Tools already has multi-plane rotation capabilities, I was asking if options could be added that would allow for the bending of a given series of vertices and faces into a smooth arc form. As you noted it is not essential since there already exists plugins such as Shape Bender. When I wrote the post, I was experimenting with "primitives", ie box, spheres, cylnders etc. So being able to "pull/stretch" a cylinder out to a point in an arc form from within Vertex Tools would I think be very helpful.
                        Edit
                        I also have True Bend which works really well. I'm probably just spoiled 😐
                        Robh Ruppel
                        • E Offline
                          Einstein
                          Hello Thom Thom,
                          Sorry I am responding back to your post so late, but lately I was the one to have rather hard (busy) time 😉
                          You asked me to specify exactly what I meant by that request:
                          "bevel vertices with more segments (like Fredo Corner, but Fredo Corner doesn't work with flat faces)"
                          My suggestion was to enable not only bevelling vertices but also rounding them. So let's say bevelling means that you add one edge at a vertex between two existing edges and rounding means that you add more edges and create an arc between them. Like in Blender - you bevel a vertex and use mouse scroll to add more segments. This is the feature I pursue. There are several corner-rounding tools for SketchUp but none of them allows manipulating vertices directly, like your plugin does. That's why I believe my suggestion makes sense 😉
                            Gotcha. Yea, I have it on my list of ideas already. Rounding, or profiled, bevels are however much more complicated. I need to do more research for that.
                            • E Offline
                              Einstein
                              I've got one more feature suggestion.
                              Merge close vertices "through groups", so if many groups/ components are selected, instead of raw geometry, vertice merge can also be performed. Currently it seems that we can only work on raw geometry. Merging vertices is sometimes a crucial fixing/ optimization algorithm and it's good if it can process many objects at once.
                              I recently worked with a model - bunch of people, hundreds of thousands of faces altogether and it got imported so bad that every single face was separate, can you imagine that... I mean, I know you can. I worked around by exploding all the groups, merging the vertices and regrouping with "Loose to groups" plugin, but I would rather not repeat that in SketchUp anymore...
                                hmm... main challenge here is that VT doesn't have any way to select anything other than vertices... Will have to think about this one.
                                • FletchF Offline
                                  Fletch
                                  Hi ThomThom, your website says to post here, so... please forgive me if this is not the right place.
                                  I purchased VT in Jan 2020.
                                  The version I had downloaded in Jan 2020 throws an error when I try to install.
                                  Must I now buy a whole new version just so that it will work in SU2021? Or do you have a version I can continue to use even in SU2021?
                                  Fletch
                                  • E Offline
                                    Einstein
                                    I'd like to say something more about vertex bevel here (I hope you don't have enough of me yet 😛 ).
                                    I was able to reproduce the bug I once had when bevelling vertices of a face and I noticed two undesired things happening:
                                    1. After selecting all verts of the Y letter and bevelling them a little the face gets removed, leaving only the edges. That I find a bug.
                                    2. Bevel widths are uneven and these bevel are unsymmetrical. I guess that's because bevel values here are not absolute but relative to the length of bevelled edges. This surely makes sense, but it would also be very nice having another option for symmetrical bevels with absolute offset. Perhaps this could be performed by simply adding a unit following a typed value, just like in native SketchUp. For example, type "0.1m" instead of "0.1" in the VDB to get the absolute value.
                                    Y.skp
                                    • E Offline
                                      Einstein
                                      Version 2.0.5 - again: what is new?
                                      • jo-keJ Offline
                                        jo-ke
                                        I have updated SU2021 to 21.1.299 64 bits and vertextools disappeared.
                                        I tried to reinstall, but it doesn't show it.
                                        It is shown in extension manager but not shown in Menubar to select
                                        What can I do?
                                        http://www.zz7.de
                                          I see it in the latest release of 2021 on my machine.
                                          Is it shown as Enabled in the Extension Manager?
                                          • jo-keJ Offline
                                            jo-ke
                                            yes, it is
                                            http://www.zz7.de
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 32 / 34
