    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      Aiden900
      Okay SO i took screenshots of my sketchup and the file properties from the new user account i created and i must say without any troubles the plugins were installed and everything was working very smooth,
      how ever since most of my work is here on my regular account and i have my own setup i still can't get to work here. And i've been waiting for almost 6 hours and i haven't had any help from the MS agents, Still waiting though, Attaching screenshots. If any suggestions or fix do come up, let me know.
      Kind regards
      A.F
      • fredo6F Offline
        As TIG indicated, you may try to tick the Unblock checkbox.
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v11.5b - 18 Jan 21
          LibFredo6 11.5b includes
          • Fix for a conflict with Profile Builder 3
          • Gus RG Offline
            Gus R
            Thanks Fredo!
            www.instagram.com/gusrobatto/
            www.facebook.com/gusrobatto
            • W Offline
              Whaat
              Hello Fredo6, may I ask what the conflict was and what the symptoms are? It will help with our customer support. Thanks!
              • Gus RG Offline
                Gus R
                I noted my symptoms here.
                I don't know any technical specifics.
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v11.6a - 23 Jan 21
                  LibFredo6 11.6a includes
                  • bug fixing and technical adjustments
                    msf8585
                    çok iyi
                      carolmonaco96
                      Oi! Alguem poderia me ajudar?
                      Fui usar o plugin e atestou como desatualizado.
                      Atualizei as versões, instalei na ordem certa e agora está falando que tenho que comprar! O que eu posso fazer?
                        @carolmonaco96
                        Hi! Can anybody help me?
                        I went to use the plugin and attested it as outdated.
                        I updated the versions, installed it in the right order and now it's saying that I have to buy! What can I do?
                        The subject of this thread is "LibFredo", which is a free set of helper tools needed by Fredo's extensions.
                        So what was the actual 'plugin' you were trying to install / use ?
                        Please note that recently Fredo has decided to sell licenses for a few of his excellent extensions [with a time-limited trial-period].
                        If you post relates to one of those, then you will need to buy a license - it's an inexpensive and perpetual set up.
                        So please explain your problem better, so that we can advise you better...
                          ARCFORMS
                          I am attempting to download LibFredo06 and every time I click download Sketch Up loads up and an error message appears "This does not appear to be a sketchUp Model" can you please assist with what is going wrong?
                            Evidently you have set up your computer to automatically open downloads. Change that. Then, after you have downloaded an extension, go to Window>Extension Manager and click on Install Extension, navigate to your Downloads folder, select the extension and choose Open.
                            Better, download the SketchUcation Plugin Store tool under Resources at the top of this page. Install it as above. Then use it to find and install extensions. You won't have to go through the Install Extension steps from above every time but it will help you keep your extensions up to date and give you some other tools for managing and organizing extensions. You'll need that anyway if you are going to use any of Fredo6's [$] extensions.
                            • I Offline
                              ironjenn
                              Hi everyone, I'm an amateur sketchup user, so apologies in advance for not knowing what I'm talking about... I have been using FredoCorner and recently purchased a license, but I have been experiencing issues with functionality. This is the error that most recently popped up in Rubyconsole when I tried to apply round to edges of a fairly simple face. Some version of this happens almost every time I try to use the extension, no matter what the shape. I also encountered an issue where it seemed to be finally working, and the preview looked ok, but when I generated the geometry it deleted the top face and created another crazy face shooting out into the abyss. (I tried to recreate the problem just now so I could take a screen shot, but now of course it isn't happening anymore - also, the forum won't let me upload my screenshots anyway bc they are too small? soooo...) Any ideas what could be going on here and/or how to fix it?
                              Date: 09-Mar-21 20:00:04
                              An error occurred in FredoCorner
                              An error occured in the Ruby code
                              undefined method `edges' for nil:NilClass
                              fredocornerchemin.rbe:: 430 -- next_face_direction
                              fredocorneralgo.rbe:: 2317 -- brane_free_chemin
                              fredocorneralgo.rbe:: 2057 -- block in catena_process_branes_protected
                              fredocorneralgo.rbe:: 2047 -- each
                              fredocorneralgo.rbe:: 2047 -- catena_process_branes_protected
                              fredocorneralgo.rbe:: 2009 -- block in catena_process_branes
                              fredocorneralgo.rbe:: 2008 -- catch
                              fredocorneralgo.rbe:: 2008 -- catena_process_branes
                              fredocorneralgo.rbe:: 965 -- block in solid_construct_branes
                              fredocorneralgo.rbe:: 964 -- each
                              fredocorneralgo.rbe:: 964 -- solid_construct_branes
                              fredocorneralgo.rbe:: 919 -- block in solid_reconstruction
                              fredocorneralgo.rbe:: 918 -- each
                              fredocorneralgo.rbe:: 918 -- solid_reconstruction
                              fredocorneralgo.rbe:: 883 -- solid_add_remove_edges
                              fredocornertool.rbe:: 1845 -- selection_change
                              fredocornertool.rbe:: 1833 -- selection_add_remove_edges
                              fredocornertool.rbe:: 1856 -- selection_set
                              fredocornertool.rbe:: 1538 -- block in preselection_instantiate
                              fredocornertool.rbe:: 1535 -- each
                              fredocornertool.rbe:: 1535 -- preselection_instantiate
                              fredocornertool.rbe:: 1530 -- preselection_analyze
                              fredocornertool.rbe:: 766 -- true_activate
                              fredocornertool.rbe:: 751 -- block in activate
                              lib6plugin.rbe:: 1568 -- tem_context
                              fredocornertool.rbe:: 751 -- activate
                              fredocornertool.rbe:: 194 -- select_tool
                              fredocornertool.rbe:: 194 -- launch
                              fredocornertool.rbe:: 176 -- action__mapping
                              lib6plugin.rbe:: 129 -- call
                              lib6plugin.rbe:: 129 -- launch_action
                              lib6plugin.rbe:: 227 -- launch_action
                              bootstrap_fredocorner.rbe:: 103 -- launch_action
                              bootstrap_fredocorner.rbe:: 118 -- block in startup
                              lib6plugin.rbe:: 1347 -- command_invoke
                              lib6plugin.rbe:: 1328 -- block (2 levels) in build_config_commands
                              lib6traductor.rbe:: 1377 -- block in add_command
                                Which version of SketchUp are you actually using? Your profile says you are using 2021 Make which doesn't exist.
                                Can you share the .skp file where this problem occurs?
                                • tlehman914T Offline
                                  tlehman914
                                  Looking for help..!? When loading any Fredo plugin, I can not see the dialog box(s).
                                  SketchUp Pro 2021
                                  iMac (Retina 5K, 27-inch, 2019) macOS Big Sur
                                  Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
                                  /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:1768:in draw'
                                  • fredo6F Offline
                                    Could you check the version of LibFredo6 you have installed.
                                    Did you play with FredoTools ColorPaint?
                                      Ski_Bird
                                      Hello,
                                      I may have found a bug in your DrawAlong tool. I have a JPG image that I'm adding countours to. I'm drawing them in the negative direction or below the image. When I type 6' .8", it draws a line not on the blue axis and at an angle towards the corner of the image. Trying to narrow down the error, 6' 1.8" works fine as does 6' 0.8". Very minor and easy to workaround but thought I'd share.
                                      Amazing work!
                                      • fredo6F Offline
                                        @ski_bird said:
                                        Hello,
                                        Amazing work!
                                        I did not know that 6' .8" would be valid. Surprises everyday with these imperial units...!
                                        I will fix that in a next release.
                                          If you type 6'.8 and hit Enter or type 6'.8" and hit Enter you'll get a line that is 72.8 inches long. It's correct and expected behavior as far as I am seeing here. Fredo, I don't see that any change is needed.
                                          Units set to decimal inches to show the .8.
                                          Click on the picture
                                            tlehman914
                                            Screen Shot 2021-03-23 at 2.36.33 PM.jpgLibFredo6
                                            11.6a
                                            23 Jan 21
                                            ColorPaint will not open.
                                            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:256:in color_palette_init' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:456:in prepare_html'
                                            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:404:in reload_html' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:361:in dialog_create'
                                            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:337:in dialog_invoke' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:98:in dialog_launch'
                                            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:87:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in new'
                                            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in new'
                                            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in _execution' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:187:in execute_command'
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 109
                                            • 110
                                            • 82 / 110
