    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • kenK
      ken
      Fredo6
      Just a note. I had checked and updated all of your plugins on my 2021 SKP last Friday. The plugin, LibFredo6 was 11.4f and your check plugins Fredo Tools indicated that 11.4f was the correct version. This morning, I find there is an update, 11.5a. So I opened Ver 2021, used your Fredo Tools and still 11.4f was indicated as the correct version.
      I installed version 11.5a. Now Fredo Tools was still 11.4f. Shut down ver 2021, reopened, and went to Fredo Tools. Now it indicated that I had ver 11.5a.
      Everything else seems to be working. Just informing you what happened. Could be it takes some time to get all the info correct.
        Aiden900
        Hey TIG,
        I tried that as well, and I don't know why it's still showing me as version 1.0 for some reason. followed exactly as you said without a hustle and still dosen't seem to catch the new version and it's still showing version 1.0
        find the attachment below.
        A.F
          So manually installing the RBZ's contents failed to improve things !
          Perhaps Fredo has some more ideas about his 'hidden-settings' files which could be changed or deleted to try to reset things ?
          e.g. the subfolder C:\Users\Afara\AppData\Local\LIBFREDO6_DATA_Dir
          Could you check that its Properties > Security permissions are all ticked as 'full' [as you did for somethings earlier]
          Alternatively, the whole folder could be deleted and all of its saved data removed...
          BUT please wait for Fredo to comment on this before this drastic step...........
            Aiden900
            Hey guys i came to know the problem, so out of curiosity what i did is that i created a new user account and i tried Libfredo and worked flawlessly so which indicates that i am having some issues with the current user account and it's attributes. So I am going to fix it asap. Actually i am in the midst of it.. as it's denying my access to apply the attributes so waiting for agent to help me out with that 😄 😄
              Aiden900
              Okay SO i took screenshots of my sketchup and the file properties from the new user account i created and i must say without any troubles the plugins were installed and everything was working very smooth,
              how ever since most of my work is here on my regular account and i have my own setup i still can't get to work here. And i've been waiting for almost 6 hours and i haven't had any help from the MS agents, Still waiting though, Attaching screenshots. If any suggestions or fix do come up, let me know.
              Kind regards
              A.F
              • fredo6F
                As TIG indicated, you may try to tick the Unblock checkbox.
                • fredo6F
                  NEW RELEASE: LibFredo6 v11.5b - 18 Jan 21
                  LibFredo6 11.5b includes
                  • Fix for a conflict with Profile Builder 3
                  • Gus RG
                    Gus R
                    Thanks Fredo!
                    www.instagram.com/gusrobatto/
                    www.facebook.com/gusrobatto
                    • W
                      Whaat
                      Hello Fredo6, may I ask what the conflict was and what the symptoms are? It will help with our customer support. Thanks!
                      • Gus RG
                        Gus R
                        I noted my symptoms here.
                        I don't know any technical specifics.
                        • fredo6F
                          NEW RELEASE: LibFredo6 v11.6a - 23 Jan 21
                          LibFredo6 11.6a includes
                          • bug fixing and technical adjustments
                            msf8585
                            çok iyi
                            • C
                              carolmonaco96
                              Oi! Alguem poderia me ajudar?
                              Fui usar o plugin e atestou como desatualizado.
                              Atualizei as versões, instalei na ordem certa e agora está falando que tenho que comprar! O que eu posso fazer?
                                @carolmonaco96
                                Hi! Can anybody help me?
                                I went to use the plugin and attested it as outdated.
                                I updated the versions, installed it in the right order and now it's saying that I have to buy! What can I do?
                                The subject of this thread is "LibFredo", which is a free set of helper tools needed by Fredo's extensions.
                                So what was the actual 'plugin' you were trying to install / use ?
                                Please note that recently Fredo has decided to sell licenses for a few of his excellent extensions [with a time-limited trial-period].
                                If you post relates to one of those, then you will need to buy a license - it's an inexpensive and perpetual set up.
                                So please explain your problem better, so that we can advise you better...
                                  ARCFORMS
                                  I am attempting to download LibFredo06 and every time I click download Sketch Up loads up and an error message appears "This does not appear to be a sketchUp Model" can you please assist with what is going wrong?
                                    Evidently you have set up your computer to automatically open downloads. Change that. Then, after you have downloaded an extension, go to Window>Extension Manager and click on Install Extension, navigate to your Downloads folder, select the extension and choose Open.
                                    Better, download the SketchUcation Plugin Store tool under Resources at the top of this page. Install it as above. Then use it to find and install extensions. You won't have to go through the Install Extension steps from above every time but it will help you keep your extensions up to date and give you some other tools for managing and organizing extensions. You'll need that anyway if you are going to use any of Fredo6's [$] extensions.
                                    • I
                                      ironjenn
                                      Hi everyone, I'm an amateur sketchup user, so apologies in advance for not knowing what I'm talking about... I have been using FredoCorner and recently purchased a license, but I have been experiencing issues with functionality. This is the error that most recently popped up in Rubyconsole when I tried to apply round to edges of a fairly simple face. Some version of this happens almost every time I try to use the extension, no matter what the shape. I also encountered an issue where it seemed to be finally working, and the preview looked ok, but when I generated the geometry it deleted the top face and created another crazy face shooting out into the abyss. (I tried to recreate the problem just now so I could take a screen shot, but now of course it isn't happening anymore - also, the forum won't let me upload my screenshots anyway bc they are too small? soooo...) Any ideas what could be going on here and/or how to fix it?
                                      Date: 09-Mar-21 20:00:04
                                      An error occurred in FredoCorner
                                      An error occured in the Ruby code
                                      undefined method `edges' for nil:NilClass
                                      fredocornerchemin.rbe:: 430 -- next_face_direction
                                      fredocorneralgo.rbe:: 2317 -- brane_free_chemin
                                      fredocorneralgo.rbe:: 2057 -- block in catena_process_branes_protected
                                      fredocorneralgo.rbe:: 2047 -- each
                                      fredocorneralgo.rbe:: 2047 -- catena_process_branes_protected
                                      fredocorneralgo.rbe:: 2009 -- block in catena_process_branes
                                      fredocorneralgo.rbe:: 2008 -- catch
                                      fredocorneralgo.rbe:: 2008 -- catena_process_branes
                                      fredocorneralgo.rbe:: 965 -- block in solid_construct_branes
                                      fredocorneralgo.rbe:: 964 -- each
                                      fredocorneralgo.rbe:: 964 -- solid_construct_branes
                                      fredocorneralgo.rbe:: 919 -- block in solid_reconstruction
                                      fredocorneralgo.rbe:: 918 -- each
                                      fredocorneralgo.rbe:: 918 -- solid_reconstruction
                                      fredocorneralgo.rbe:: 883 -- solid_add_remove_edges
                                      fredocornertool.rbe:: 1845 -- selection_change
                                      fredocornertool.rbe:: 1833 -- selection_add_remove_edges
                                      fredocornertool.rbe:: 1856 -- selection_set
                                      fredocornertool.rbe:: 1538 -- block in preselection_instantiate
                                      fredocornertool.rbe:: 1535 -- each
                                      fredocornertool.rbe:: 1535 -- preselection_instantiate
                                      fredocornertool.rbe:: 1530 -- preselection_analyze
                                      fredocornertool.rbe:: 766 -- true_activate
                                      fredocornertool.rbe:: 751 -- block in activate
                                      lib6plugin.rbe:: 1568 -- tem_context
                                      fredocornertool.rbe:: 751 -- activate
                                      fredocornertool.rbe:: 194 -- select_tool
                                      fredocornertool.rbe:: 194 -- launch
                                      fredocornertool.rbe:: 176 -- action__mapping
                                      lib6plugin.rbe:: 129 -- call
                                      lib6plugin.rbe:: 129 -- launch_action
                                      lib6plugin.rbe:: 227 -- launch_action
                                      bootstrap_fredocorner.rbe:: 103 -- launch_action
                                      bootstrap_fredocorner.rbe:: 118 -- block in startup
                                      lib6plugin.rbe:: 1347 -- command_invoke
                                      lib6plugin.rbe:: 1328 -- block (2 levels) in build_config_commands
                                      lib6traductor.rbe:: 1377 -- block in add_command
                                        Which version of SketchUp are you actually using? Your profile says you are using 2021 Make which doesn't exist.
                                        Can you share the .skp file where this problem occurs?
                                        • tlehman914T
                                          tlehman914
                                          Looking for help..!? When loading any Fredo plugin, I can not see the dialog box(s).
                                          SketchUp Pro 2021
                                          iMac (Retina 5K, 27-inch, 2019) macOS Big Sur
                                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
                                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:1768:in draw'
                                          • fredo6F
                                            Could you check the version of LibFredo6 you have installed.
                                            Did you play with FredoTools ColorPaint?
                                            • 85
                                            • 86
                                            • 87
                                            • 88
                                            • 89
                                            • 115
                                            • 116
                                            • 87 / 116
