    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 170 Watching
    • OxerO
      Oxer
      You can see this video in previous posts:
      @paul russam said:
      I saw this tutorial this morning:
      https://youtu.be/QGlrqRP7-Z8
      and whilst I have the Cloth plugin I haven't used it much beyond curtains etc.
      Sooooo, I thought I'd have a go, this is an idea for a social media push with each of the videos being released a few days apart. The results below are just a test, If the client was interested then a bit more thought would be put into the model/materials etc.
      TutorialsUp has some really good tuts on their channel, well worth a look.
      • V
        Vimsy
        Kindly update its version!! I use sketchup 2016 and i installed this plugin but it is not working, there is no simulation happening.
          It should work fine in 2016 if you've set up the file correctly and purchased the license. How about sharing your file so we can see what you are working with?
            Anton_S
            Hello,
            Which operating version are you using with SU2016, e.g. Windows XP/7 or OS X? This will help me verify if this is working.
            Thanks,
            Anton
            • Gus RG
              Gus R
              Works great on SketchUp Pro 2021 and updated on SketchUp 2017. Not getting those weird temp files anymore in 2017. Trying to practice with the gift wrap tutorial from above which is probably a skip and a jump on the learning curve.
              www.instagram.com/gusrobatto/
              www.facebook.com/gusrobatto
                mbieniu1
                Hello,
                I bought full version of your plugin, but I have 2 issue:
                • it doesnt save presets after I close SU and open again (I use "save us" button)
                • it is very slow when I tries to copy your setup from youtube (on empty file and no plugins workin, it has 5 FPS for 100 frames, than 1-2 FPS)
                My Sketchup v. 2021 Clothwork v.1.7.4c, comp spec Windows 10 pro, AMD Ryzen 9 3950X, 64 GB Ram, NVIDIA GeForce RTX 2080 Ti
                Do you have any tips to fix it? Or should I change Sketchup preferences?
                @anton_s said:
                Hello everyone,
                ClothWorks is updated: https://sketchucation.com/plugin/2053-clothworks
                Happy holidays!
                Best regards,
                Anton
                  Anton will reply...
                  BUT when you installed SketchUp was it done correctly ?
                  You can always try the following method - it will do no harm to your current setup [except for perhaps fixing preferences !]
                  Whilst you are logged into Windows using your normal user-account.
                  Ensure SketchUp is closed.
                  Find the SketchUp installer's exe file - usually in your Downloads folder...
                  Select its icon and right-click > context-menu > "Run as administrator"
                  When prompted choose "Repair" [for a brand-new installation it's "Install"]
                  When it completes restart SketchUp and see if your tools' preferences/setting are now saved across sessions...
                    mbieniu1
                    thank you for replay
                    before you post your comment I try not to use Polish font in name and that solve the problem
                    I did as you mentioned and make Repair Sketchup as Admin but FPS it still poor
                    Maybe it is like Cyberpunk2077, with Intel it works better than AMD πŸ˜‰
                      Anton_S
                      ClothWorks simulation is purely based on CPU power for now.
                      Unless already, can you ensure that Multi-threaded and Draw with OpenGL API is enabled? This should help with simulation performance.
                        mbieniu1
                        Hello,
                        I ensure that Multi-threaded and Draw with OpenGL API is enabled. Would it help if I record performance?
                        Does cloth presets are store in skp files? Should one preset should be enable in all files?
                        Happy 2021 year πŸ˜„
                          Anton_S
                          @mbieniu1 said:
                          Hello,
                          I that case, it looks like that's the best performance you can get from ClothWorks. Although it might help if you send a screenshot (a private message also works).
                          A few presets are persisted globally (like multithreaded and drawing with opengl), while other options, like simulation wind and cloth material properties, are local to the file.
                          • K
                            knryder
                            sketchup 2021, clothworks v1.7.4
                            i tried to do the cussion example from your manual. after pushing play sketchup closes.
                            tips ?
                              Anton_S
                              tips ?
                              Does sketchup close for any model you press play with or with this particular one? Try opening a blank Sketchup template model and try pressing play.
                              • kaluK
                                kalu
                                Hi Do this program works on Sketchup 2021? I purchase the license in 2020 and I try to use it in 2021 and the plugin is not work They ask me for the license. Any Ideas?
                                Thanks for any Feedback. I got this message:
                                THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                • fredo6F
                                  @kalu
                                  Please install the latest version of the Sketchucation toolset, v4.0b.
                                  It is required for compatibility with SU2021.
                                  Thanks to advise if this works.
                                    JohnWoodGarden
                                    ClothWorks. Can anyone help please.
                                    All has been working perfectly. Now it suddenly won't let me 'apply a quadrilateral grid' to the cloth. I click and get the message: Purge the selected grid of coplaner geometry. But there is no complex geometry! It's just a simple rectangle just like I've always done before! I've unistalled and re-installed. I've switched off and switched on again. Still nothing. Still the same block.
                                    I'm writing as someone who's used Clothworks a lot and never had the slightest problem with it.
                                    Any help v greatly received. Thank you
                                    John
                                      Anton_S
                                      John
                                      The message you're getting is "Purge the selected cloth of coplanar geometry, prior to generating a grid?" -- a question. You should click YES and it will proceed with generating the grid, and will do so successfully if your geometry turns out to be a quadrilateral or two triangles linked by an edge.
                                        JohnWoodGarden
                                        Hi Anton, please help
                                        Your brilliant plugin has always worked perfectly for me. Suddenly the usual menu has disappeared! Instead of 'make cloth' and 'make collider' I get a long menu I've not seen before which reads:
                                        Toggle UI
                                        Toggle Play
                                        Stop
                                        Reset
                                        Toggle Drape
                                        Add pin
                                        etc etc and so it goes on, but nowhere can I make a cloth or make a collider, so suddenly I can't use your plugin at all!
                                        How do I get it working properly again?! I've tried uninstalling and reinstalling, but still exactly the same problem persists!
                                        Do hope you can help me to sort this out
                                        Thank you
                                        Best regards
                                        John
                                          Suddenly the usual menu has disappeared! Instead of 'make cloth' and 'make collider'...
                                          Is this what you see when you context (right) click on a group or component?
                                          I only see the menu items you list under Extensions>Clothworks
                                          Are you still using SketchUp 2013? If not, please update your profile.
                                            Anton_S
                                            Toggle UI
                                            Toggle Play
                                            Stop
                                            Reset
                                            Toggle Drape
                                            Add pin
                                            Thank you
                                            Best regards
                                            John
                                            Hey, the Make Cloth and rgw Make Collider options are only available in the Context Menu. You can access the context menu by right-clicking on a top-level group or a component.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 36
                                            • 37
                                            • 26 / 37
