    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 843.6k Views 165 Watching
      Mariotalluto
      This plugin is really impressive ! Thank you
      2 Questions for you :
      -First : ❗ ❗ After a few try of this plug on sketch2018, Sketchup Crashed on Startup everytime. I had to uninstall clothworks to be able to use sketchup again. What's wrong ?
      -Second : i'm trying to do a thick bed sheet (exactly like this https://ak1.ostkcdn.com/wp-content/uploads/2019/01/11620191-how-to-buy-bed-sheets-facebook.jpg)
      But i don't know how to make a right thikness with a good selfcolission . I tried to simulate a plan and then apply a thickness with the plugin 'shell' but the result isn't good
      Any idea ?
      • W Offline
        Winston1
        Does anyone know when the update will be ready for SU 2021? I would really love to have this extension! πŸ˜„πŸ™‚
        Thank you
        Jay
          Thank you
          Jay
          A couple of posts up:
          @anton_s said:
          Hello everyone,
          ClothWorks is not compatible with SU2021 yet. Update is in progress.
          Thanks,
          Anton
          As I told you in the other forum, only Anton will know when it'll be available.
            Anton_S
            Hello everyone,
            ClothWorks is updated: https://sketchucation.com/plugin/2053-clothworks
            Happy holidays!
            Best regards,
            Anton
              Thanks for posting that Anoton.
              It works perfectly!
              https://live.staticflickr.com/65535/50710737546_b358b58093.jpg
                db11
                Can ClothWorks be used to simulate shrink wrap? (I'm looking to shrink wrap glass bottles in cardboard trays, then stack the trays on a pallet and wrap the pallet)
                I have read through the entire thread and the tent examples seem close to what I would need, and there was talk of an impending tent tutorial β€” but I don't think it has been released yet.
                Anybody have experience trying out stretched materials over colliders? Any thoughts on how to proceed?
                • OxerO Offline
                  Oxer
                  You can see this video in previous posts:
                  @paul russam said:
                  I saw this tutorial this morning:
                  https://youtu.be/QGlrqRP7-Z8
                  and whilst I have the Cloth plugin I haven't used it much beyond curtains etc.
                  Sooooo, I thought I'd have a go, this is an idea for a social media push with each of the videos being released a few days apart. The results below are just a test, If the client was interested then a bit more thought would be put into the model/materials etc.
                  TutorialsUp has some really good tuts on their channel, well worth a look.
                  • V Offline
                    Vimsy
                    Kindly update its version!! I use sketchup 2016 and i installed this plugin but it is not working, there is no simulation happening.
                      It should work fine in 2016 if you've set up the file correctly and purchased the license. How about sharing your file so we can see what you are working with?
                        Anton_S
                        Hello,
                        Which operating version are you using with SU2016, e.g. Windows XP/7 or OS X? This will help me verify if this is working.
                        Thanks,
                        Anton
                        • Gus RG Offline
                          Gus R
                          Works great on SketchUp Pro 2021 and updated on SketchUp 2017. Not getting those weird temp files anymore in 2017. Trying to practice with the gift wrap tutorial from above which is probably a skip and a jump on the learning curve.
                          www.instagram.com/gusrobatto/
                          www.facebook.com/gusrobatto
                            mbieniu1
                            Hello,
                            I bought full version of your plugin, but I have 2 issue:
                            • it doesnt save presets after I close SU and open again (I use "save us" button)
                            • it is very slow when I tries to copy your setup from youtube (on empty file and no plugins workin, it has 5 FPS for 100 frames, than 1-2 FPS)
                            My Sketchup v. 2021 Clothwork v.1.7.4c, comp spec Windows 10 pro, AMD Ryzen 9 3950X, 64 GB Ram, NVIDIA GeForce RTX 2080 Ti
                            Do you have any tips to fix it? Or should I change Sketchup preferences?
                            @anton_s said:
                            Hello everyone,
                            Happy holidays!
                            Best regards,
                            Anton
                              Anton will reply...
                              BUT when you installed SketchUp was it done correctly ?
                              You can always try the following method - it will do no harm to your current setup [except for perhaps fixing preferences !]
                              Whilst you are logged into Windows using your normal user-account.
                              Ensure SketchUp is closed.
                              Find the SketchUp installer's exe file - usually in your Downloads folder...
                              Select its icon and right-click > context-menu > "Run as administrator"
                              When prompted choose "Repair" [for a brand-new installation it's "Install"]
                              When it completes restart SketchUp and see if your tools' preferences/setting are now saved across sessions...
                                mbieniu1
                                thank you for replay
                                before you post your comment I try not to use Polish font in name and that solve the problem
                                I did as you mentioned and make Repair Sketchup as Admin but FPS it still poor
                                Maybe it is like Cyberpunk2077, with Intel it works better than AMD πŸ˜‰
                                  Anton_S
                                  ClothWorks simulation is purely based on CPU power for now.
                                  Unless already, can you ensure that Multi-threaded and Draw with OpenGL API is enabled? This should help with simulation performance.
                                    mbieniu1
                                    Hello,
                                    I ensure that Multi-threaded and Draw with OpenGL API is enabled. Would it help if I record performance?
                                    Does cloth presets are store in skp files? Should one preset should be enable in all files?
                                    Happy 2021 year πŸ˜„
                                      Anton_S
                                      @mbieniu1 said:
                                      Hello,
                                      I that case, it looks like that's the best performance you can get from ClothWorks. Although it might help if you send a screenshot (a private message also works).
                                      A few presets are persisted globally (like multithreaded and drawing with opengl), while other options, like simulation wind and cloth material properties, are local to the file.
                                        knryder
                                        sketchup 2021, clothworks v1.7.4
                                        i tried to do the cussion example from your manual. after pushing play sketchup closes.
                                        tips ?
                                          Anton_S
                                          tips ?
                                          Does sketchup close for any model you press play with or with this particular one? Try opening a blank Sketchup template model and try pressing play.
                                          • kaluK Offline
                                            kalu
                                            Hi Do this program works on Sketchup 2021? I purchase the license in 2020 and I try to use it in 2021 and the plugin is not work They ask me for the license. Any Ideas?
                                            Thanks for any Feedback. I got this message:
                                            THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 35
                                            • 36
                                            • 26 / 36
