    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 857.0k Views 165 Watching
      mbieniu1
      thank you for replay
      before you post your comment I try not to use Polish font in name and that solve the problem
      I did as you mentioned and make Repair Sketchup as Admin but FPS it still poor
      Maybe it is like Cyberpunk2077, with Intel it works better than AMD πŸ˜‰
        Anton_S
        ClothWorks simulation is purely based on CPU power for now.
        Unless already, can you ensure that Multi-threaded and Draw with OpenGL API is enabled? This should help with simulation performance.
          mbieniu1
          Hello,
          I ensure that Multi-threaded and Draw with OpenGL API is enabled. Would it help if I record performance?
          Does cloth presets are store in skp files? Should one preset should be enable in all files?
          Happy 2021 year πŸ˜„
            Anton_S
            @mbieniu1 said:
            Hello,
            I that case, it looks like that's the best performance you can get from ClothWorks. Although it might help if you send a screenshot (a private message also works).
            A few presets are persisted globally (like multithreaded and drawing with opengl), while other options, like simulation wind and cloth material properties, are local to the file.
              knryder
              sketchup 2021, clothworks v1.7.4
              i tried to do the cussion example from your manual. after pushing play sketchup closes.
              tips ?
                Anton_S
                tips ?
                Does sketchup close for any model you press play with or with this particular one? Try opening a blank Sketchup template model and try pressing play.
                • kaluK Offline
                  kalu
                  Hi Do this program works on Sketchup 2021? I purchase the license in 2020 and I try to use it in 2021 and the plugin is not work They ask me for the license. Any Ideas?
                  Thanks for any Feedback. I got this message:
                  THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                  • fredo6F Offline
                    @kalu
                    Please install the latest version of the Sketchucation toolset, v4.0b.
                    It is required for compatibility with SU2021.
                    Thanks to advise if this works.
                      JohnWoodGarden
                      ClothWorks. Can anyone help please.
                      All has been working perfectly. Now it suddenly won't let me 'apply a quadrilateral grid' to the cloth. I click and get the message: Purge the selected grid of coplaner geometry. But there is no complex geometry! It's just a simple rectangle just like I've always done before! I've unistalled and re-installed. I've switched off and switched on again. Still nothing. Still the same block.
                      I'm writing as someone who's used Clothworks a lot and never had the slightest problem with it.
                      Any help v greatly received. Thank you
                      John
                        Anton_S
                        John
                        The message you're getting is "Purge the selected cloth of coplanar geometry, prior to generating a grid?" -- a question. You should click YES and it will proceed with generating the grid, and will do so successfully if your geometry turns out to be a quadrilateral or two triangles linked by an edge.
                          JohnWoodGarden
                          Hi Anton, please help
                          Your brilliant plugin has always worked perfectly for me. Suddenly the usual menu has disappeared! Instead of 'make cloth' and 'make collider' I get a long menu I've not seen before which reads:
                          Toggle UI
                          Toggle Play
                          Stop
                          Reset
                          Toggle Drape
                          Add pin
                          etc etc and so it goes on, but nowhere can I make a cloth or make a collider, so suddenly I can't use your plugin at all!
                          How do I get it working properly again?! I've tried uninstalling and reinstalling, but still exactly the same problem persists!
                          Do hope you can help me to sort this out
                          Thank you
                          Best regards
                          John
                            Suddenly the usual menu has disappeared! Instead of 'make cloth' and 'make collider'...
                            Is this what you see when you context (right) click on a group or component?
                            I only see the menu items you list under Extensions>Clothworks
                            Are you still using SketchUp 2013? If not, please update your profile.
                              Anton_S
                              Toggle UI
                              Toggle Play
                              Stop
                              Reset
                              Toggle Drape
                              Add pin
                              Thank you
                              Best regards
                              John
                              Hey, the Make Cloth and rgw Make Collider options are only available in the Context Menu. You can access the context menu by right-clicking on a top-level group or a component.
                                svanholm
                                Will Sketchup 2021-compability come soon?
                                  It's already compatible with SketchUp 2021.
                                  Click on the picture.
                                    gaelhietin
                                    Dear Anton,
                                    Thanks a lot for your Cloth Work Plugin.
                                    It's great and I'm having lot of fun with it.
                                    One question :
                                    Do you think Cloth Work will be the good plugin to simulate this pendant mobile ?
                                    Please see attached picture.
                                    If yes, could you give me the main keys to do it ?
                                    Best
                                    GaΓ«l
                                      alcoritolus
                                      Hi Anton,
                                      I've downloaded the plugin but I cannot use it.
                                      I'm able to click on the toggle play button when there's no object in the SketchUp, but after I drew something there's no response after I click the button.
                                      How can I solve this?
                                        It sounds like you are missing some steps. Go back through the instructions and make sure you are following all of the steps correctly. Have you created a group or component and assigned it to be cloth? Have you applied the subdivision to the face?
                                        Which version of SketchUp are you actually using? Your profile indicates 2020 Free/Make which does not exist.
                                          alcoritolus
                                          I've followed every step in your videos, but nothing happened when I click the button that transforming the cloth into grids.
                                          I'm using 2020 version of Sketchup.
                                            Upload your model so we can see how you have your model set up.
                                            So Pro, not the Free/Make. Please correct your profile.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 35
                                            • 36
                                            • 27 / 36
