    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.3k Views 135 Watching
    • E Offline
      Ecuadorian
      Hey, everyone! I just downloaded the book. Thank you for the good memories! ๐Ÿ˜ƒ
      -Miguel Lescano
      • GarethG Offline
        Gareth
        Great book....love it....!!
        Well done.
        • genki.ttG Offline
          genki.tt
          I found a small miss type on The D'oh! Book P61(ver.1.0) P63(ver.1.1)
          [20mm, 10mm, 30mm] absolute move -> <20mm, 10mm, 30mm> relative move
          By the way I could find Doh about Array Command, we can change operation 'x' to '/' with using 'x1' , or we can change '/' to 'x' with using '/1'.
          copy(move + 'alt') some object and type VCB
          <1000,,>
          x4
          10000
          x1
          /4
          20000
          /1
          <1000, 1000, 1000>
          x10
          .... we can continue 'x', '/', distance value, relative vertics, absolute vertics.
          'x1' or '/1' is important.
          Thank you for GREAT BOOK!!
            Doh of the day! Surely trivial but never remarked! ๐Ÿ’š
            Saving a file with objects who are not Components and Groups
            New File
            Import this file : it's converted in a Component! ๐Ÿ˜ฎ
              New File
              And if you create a component and save it using File>Save as... and then import it, it'll be double wrapped.
                And Making a Component creates a new context menu on the Right Click Menu!
                "Save As" (+ "Reload" + "Detach")
                So more speed than the menu "File Save as" ! ๐Ÿ˜‰
                • E Offline
                  Ecuadorian
                  I've just spent one hour asking myself why I could not copy-paste from an old SKP file to a new SKP file with a newly imported AutoCAD drawing. I run SketchUp's checkup, GPU-Z, Repaired SketchUp, reinstalled SketchUp... Nothing. Until I remembered these guys send me the AutoCAD drawings in milimeters instead of meters, but I imported it as meters... So the new drawing was gigantic and anything I copy-pasted from the old file was just too tiny to be seen.
                  -Miguel Lescano
                    Why not use the "Zoom Extended" in a new file ? ๐Ÿ˜ฎ ๐Ÿ˜„
                      rv1974
                      Today Penny has Dropped:
                      XnView is way better BP2 library explorer then a built-in one.
                      As well I use XnView as Component explorer for years now. Excellent with 2nd disply + drag'n'drop.
                        Sleipnir
                        New to this program, looking for a good extension for cabinet building and or wood working draw up.
                        Odin's Favorite Eight Legged Horse'
                          Super Doh of the day! Thanks Dave! ๐Ÿ‘
                          The arc Circle "Knife"! Make a Double Click at the end of the Arc Drawing! ๐Ÿค“
                          Excellent! ๐Ÿ˜Ž โ˜€
                          Never made the Double Click! (just simple click: as it was not writed on the bottom help line! ๐Ÿ˜ณ
                          And I surrely missed it on the manual! ๐Ÿ˜ณ
                          Animation by Dave
                          https://sketchucation.com/forums/download/file.php?id=148790&mode=view/rokbox.jpg
                            You probably missed this, too. If you want to place the same radius on other corners, double click near them.
                            Click on pic if it doesn't move.
                              Very cool! โ˜€ ๐Ÿ‘
                              I suppose I am not the only one! ๐Ÿ’š
                                kaas
                                I don't know if this is a new feature but I was pleasantly surprised to learn about it:
                                In the 3dWarehouse, select a model, look at the statistics in the panel on the right, if you hover / click on a tag (materials/components) you can import just one of those elements instead of the whole model.
                                Great feature if you just need 1 material of 1 element from a collection.
                                • boofredlayB Offline
                                  boofredlay
                                  https://media.giphy.com/media/EldfH1VJdbrwY/giphy.gif
                                  • HornOxxH Offline
                                    HornOxx
                                    @pilou said:
                                    ...I suppose I am not the only one! ๐Ÿ’š
                                    ๐Ÿ˜„ ๐Ÿ˜„ I'm also a member of this unsuspecting club...
                                    never trust a skinny cook
                                      rv1974
                                      At last we have a fastest\easiest tool for ramps/stairs/roads!
                                      Check s4u Stair() in Plugin Store.
                                      Absolutely worth every penny.
                                      โ˜€
                                      • L Online
                                        Thank you, thank you, thank you!
                                        • david_hD Offline
                                          david_h
                                          I know I should know this (being a top sketchukator and all--- ๐Ÿ’š Yeah, I am having a hard time containing my laughter too. . .)but as I said. .I know I should know this but I don't:
                                          as I go between scenes with sections how can I toggle between them and keep the section plane window off so I dont have to manually turn them off each time? I have always found the scene menu in SU very confusing and conveluted and I can't seem to get this to work as I want. Help please? Thanks.
                                          David_H
                                            David, you can access them in the Outliner. Right click on the desired section cut in Outliner and activate it or deactivate as needed.
                                            • 34
                                            • 35
                                            • 8 / 35
