    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
      jonorman
      Are there any known issues with Twinmotion and its sync plugin ??? Each time I reload the models after saving, i have to retexture in Twinmotion.
        Sorry no problem for me : with ThruPaint or Not!
        The Sync works like a charm! 😎
        (Su 2017 Make --> TwinMotion 2019 free )
        I believe that we must have the SU Pro for Sync with free TwinMotion 2020 ?
        When you say "reload" what is exactly ?
        Direct from SU with the Twin Sync plugin or a simple reload inside Twin after saved a SU FIle ?
          jonorman
          Ok, a bit short explanation πŸ˜„
          Example.
          I model a pipe, steel pipe. Create a material in SU and load a albedo image. Then i use Fredos Thru paint (latest version) and i texture it using Quadmesh UV mapping. The texture adds nicely in SU and I`m all happy to send it to TM using the sync tool (No merging, keeping all objects)
          When the model shows up in TM, i load the rest of the textures, roughness, metallic and bump.
          The model looks good in TM.
          Now I save the model in SU and TM and shut down for the day.
          Next day: Open SU model, open Twinmotion model.. Maybe I add somthing in SU, maybe a second pipe, using the same workflow as described above, and syncing with TM The material i added on the first pipe the day before are gone and replaced with the one from SU.
          I have to reload all the other maps. Rough, metallic and bump..
          This happens every time. I found another comment on this issue in the TM forums, saying it had to do with our favorite mapping tools, Thrupaint.. πŸ˜• (I don't belivee it πŸ˜„)
          Hope this makes sense πŸ˜„
            misticalages
            Hello dear Fredo,
            I come across a problem regarding ThruPaint, makeing it exporting separate material for each face, which i don't want it to happen. πŸ€“ Final model exports and it has for like 238 materials and so...
            I encountered and found out when i was changing the material and deleting it, the error it never happens. 😐
            Using Sketchup 2020 and the last FredoTools on the sketchUcation.
            https://discourse-cloud-file-uploads.s3.dualstack.us-west-2.amazonaws.com/sketchup/original/3X/c/c/ccaa7394f365bbd6c76312fcda8d503ecfef5377.png
            Thank you.
            Misticalages
              suprachs
              I am using sketchup pro 2020, installed ThruPhaint, does not show buttons, images cannot be used.
              icon visible
              • fredo6F
                @suprachs said:
                I am using sketchup pro 2020, installed ThruPaint, does not show buttons, images cannot be used.
                Are you on Sketchup 2016?
                If so, you need to take the legacy version of LibFredo6 and the legacy version of FredoTools.
                  rv1974
                  Fredo may I ask some childish question?
                  Is there any fundamental difficulty to implement Natural UV mode that is aligned to longes edges of the tube-like surfaces? Just like QuadMesh UV mode but without distortions?
                  Legend:
                  1- QuadMesh UV mode (almost OK except distortions)
                  2- Current Natural UV mode (messy)
                  3- The desired one- every segment of the tube gets aligned to direction distortion-free UV mapping. I can achieve it with a current Natural UV mode (clicking segment by segment) but is it possible to get it with single click?
                  • T
                    tomaszdrgas
                    ​It doesn't crush ENScape or something so don't worry..
                    Enscape is a render plugin for sketchup and few other like Rhino, Vectorworks..
                    I found that if I set up an ENS material and "Save As" it to some library, Fredo6 ThruPaint (which I use actually instead of native paint bucket) doesn't see ENS specific settings when introducing new material to the model.. It works with no problem when material is already one of the materials.
                    So if You have created a library of ENS setted up materials and want to use them in Your model, than when You pick the material from that library and paint it in Your model for the first time do it with native sKetchup Paint Tool. ThruPaint will make it a 'flat' sKetchup material loosing any links to bump, roughness etc. and mixing Tint Color and Color settings into texture image..
                    I don't really know who should fix what in order to make it work so I let know to both. I love ThruPaint and I have to use ENS.
                    • T
                      tomaszdrgas
                      I guess that main problem is that plugin doesn't really know which direction is prefered one,. maybe we could assume the red 'U' direction..
                      Second problem ThruPaint tries very hard to make texturing continues.. As far as I have seen Your desired result it has breakes on every bend of tube.. So I guess You want some mix of 'quad' abd 'natural uv' modes.. Just select and paint each segment seperatly with 'natural uv'.. As You did I guess..
                      • P
                        peerapat
                        Thanks Fredo
                          rv1974
                          Second problem ThruPaint tries very hard to make texturing continues.. As far as I have seen Your desired result it has breakes on every bend of tube.. So I guess You want some mix of 'quad' abd 'natural uv' modes.. Just select and paint each segment separately with 'natural uv'.. As You did I guess..
                          But somehow it does know the preferred dimension when applying "Quad" UV". Plus, tools like Profile Builder manage to apply UVs correctly when generating new geometry. Indeed, essentially I'm asking is a hybrid of quad + natural modes. I think it's the most preferred mode for architects. It'd be nice to hear from Fredo if this hybrid mode is theoretically possible.
                          Right, manual clicking segment by segment is the current solution, but in many cases it's too laborious..
                          • K
                            kevvv
                            where can i get this?
                              If you look at the first post in this thread you will see it's part of FredoTools and the link for it.
                              By the way, your profile says you are using SketchUp 2019 Free/Make but that's impossible. Please update your profile with the correct version.
                              • K
                                kingfisher13
                                I don't know what is going on, but Thrupaint is giving me so many issues right now. Its frustrating me to the point where I don't even want to use Sketchup anymore. I created a geometrically perfect onion dome, made of ENTIRELY quads, with no issues or errors in the construction.
                                When I try to use the Quad UV wrap to wrap a mosaic tile texture around the dome, it gives me errors every time. I get the yellow errors, and I get red errors, where it says the faces don't have 3 or 4 vertices, when they all do. I've been unable to texture this thrice d**ned dome because of it. Its ruining my project, and I really don't want to have to export the dome to 3ds Max to wrap the texture, because then it will need to be triangulated, which will completely mess it up when I import it back into Sketchup.
                                Does anyone have a solution for this stupid bug I keep experiencing?
                                  What version of SketchUp are you using? What operating system? That information is important. Please complete your profile.
                                  If you share your SketchUp model file so we can see exactly what you have, we can give you some guidance.
                                  • fredo6F
                                    A dome is typically not suitable for QuadUV. QuadUV is for a grid, with rows and columns, where it is possible for ThruPaint to follow the shape.
                                    Now, it would be useful to have your model [or part of it] to advise on what you could do for texturing.
                                    • B
                                      bsfranza
                                      hi there,
                                      is it possible to turn off that sound when "picking" materials from the scene?
                                      i have looked inside the pluginfolder if maybe i find a sound file that i coud just delete πŸ˜„?
                                      best, franz
                                      • fredo6F
                                        The file is in folder Fredo6_!LibFredo6/IMAGES_Standard, with name Camera_click.wav.
                                        If you rename it or remove it, it should not play the sound.
                                        • E
                                          Einstein
                                          I think it would be cool to have one more selection option - all selected groups. With it we could paint all selected groups through with a single click (even if they had materials applied to faces), possibly without changing their UVs.
                                          What do you think about this idea?
                                          • W
                                            williamhhf
                                            hi there, i can't download it, just showed blank pop up window after click download
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
