    SketchUp 2021 release
    17 Posts 12 Posters 5.1k Views 12 Watching
    • andybotA Offline
      andybot
      @rogalxxx said:
      Of all the new features the tag grouping is the only one I find useful. The PreDesign thingy is a toy. The logos still have to grow on me. I rooted for some substantial speeding up of the 3d engine. 😞
      same. One year. One new welcome feature. Oh joy. Innovating bigly.
        rv1974
        I never saw so many crucial plugins get broken 😑
        How am I supposed to work without PB or all(?) TT's tools for instance..
        During last decade they completely ceased development of new tools, and with v2021 they decided to ruin 3rd party plugins.
          Which tools are broken - it might be more helpful to list them...
          Just because an extension's entry in the EWH or the PluginStore doesn't say it's v2021 compatible doesn't mean it's not.
          Individual authors need to update their entries, and so a lot are out of step.
          The PluginStore only added a v2021 check box in its entries text today, so it'd be surprising if many extensions are currently flagged as compatible.
          The API changes between v2020 and v2021 are relatively unimportant, so I'd expect most tools that worked in v2020 to be OK in v2021 !!
            rv1974
            I guess those of TT won't work:
            QuadFaceTools, Architect tools,tt_axes, tt_guide_tools, superglue, UV_Toolkit, vertex tools, Subd, text tools,Groups to component etc.. Maybe this is related to TT's Lib?
            Plus.. Profile Builder, curic extend, clothwoks
            P.S. From TT's arsenal Only Truebend and SolidInspector do work.
              rv1974
              Sure, but I just copy-pasted Plugins folder from v20. Then I tried to reinstall the plugins that were reported as broken- no luck.
                When you say they 'reported as broken', please explain fully...
                How were you informed of the issues ?
                I see no major issues with the changeover...
                Are you using the latest TT Lib ?
                With licensed tools like ClothWorks, in v2021 you need an updated SCF-license installed - get the latest SketchUcation Toolset v4.0.0 here https://sketchucation.com/pluginstore?pln=SketchUcationTools
                With a new SketchUp version it's always wise to reinstall all extensions from scratch - authors might have made 'behind-the-scenes' tweaks to their tools to maintain compatibility, thus requiring a fresh install...
                  kaas
                  v2021 - my 2 cnts - will test more when starting up a new project next week
                  • layer groups - why not implement scene groups at the same time?!
                  • smaller file size
                  • layout bug where SketchUp dimensions were 'cut' depending on the position on the paper seems fixed - hurrai
                  • prefer the old logo
                  • wishlist of 2015 (or earlier) can be copy-pasted again
                  ...back to work
                  • N Offline
                    numerobis
                    Layer groups as the only "major" new feature...?!?
                    I mean, yes, this looks like a great improvement after last years "features" of renaming layers to tags and groups/components to objects.
                    Unbelievable...
                      slbaumgartner
                      ThomThom released new versions for 2021 compatibility. You need to install the new ones, not copy the old ones.
                      • jujuJ Offline
                        juju
                        They sure don't show up on the EW as fresh releases yet.
                        • kenK Offline
                          ken
                          Well loaded up 2021. Found some plugins that would not load.
                          List:
                          curic_dio2
                          curic_drawing_Tools
                          curic_extend
                          curic_oi
                          curic_section_views
                          curic_streth
                          Note, all of the above plugins were listed as working with 2019. So I am not surprised.
                          The "Load Error" box that tells you what plugins will not load has an "Error:" at the beginning, and on these lines, you will find the offending "rb" plugin.
                          I just add the following to the plugin's name, ie. curic_dio2.rb-ken That way they will not load. And then I monitor the website to determine if and when the plugin is ready to re-install.
                          Note, what I am showing are plugins that would not install, not plugins that may not work.
                          I do like the capability to add a tag folder. before I would put the different named tags I wanted to close all at once in a group. However, that became cumbersome, as sometimes I would have to drill down through groups to modify the object.
                          Yes, each upgrade seems to be small, but I just plug along, because I make illustrations for PPP for pre-bid or pre-job meetings.
                          I hope they didn't spend a lot of good money on the 4 icons listing the 3d Warehouse, Extensions Warehouse, Layout, and Extension Manager. Just poking the designers.
                          • GD3DesignG Offline
                            GD3Design
                            CURIC 2021 compatible plugins were just released this morning. πŸŽ‰
                            (edit: nevermind - i just installed and they are not working....all kinds of load errors)
                            (edited edit: I emailed Curic the errors and updated package was promptly uploaded. All good now. πŸ‘
                            Tag folders - I have been dying for this feature for a while...now if they could just switch the name 'tag' back to 'layer'.... 😞
                            As far as the new logos.....see pic below... 🀣
