    Animator and VRay
    renderpluginsextensions
    45 Posts 23 Posters 101.9k Views 23 Watching
      Sidneysalmeronborrell
      Hello, a pleasure
      I have a problem and that is when I tell Animator to do the animation through VRAY it does not work. It stays stuck in the render when it finishes and does not advance. If I put it other than Vray if it works. It is not interact
      • C
        cyrilc
        Hello Fredo,
        For some reasons, Vray only renders the first frame of the animation many times, while I see animator running properly.
        I am using Sketchup 2020 and Vray 4.20.01
        I have checked everything I could find on forums and youtube. I saw that other users seem to have the same problem.
        Any idea why ?
        Best regards, and congrats for all the work,
        Cyril
          safak
          I am having the same problem.
          I can create videos with animator, which means I have got working "films" in the animator. I can render my scenes in Vray. When I open the generator tab of the animator, I am able to see the Vray option and I can do my settings accordingly. So everything is fine so far. However, when I generate a video I get an 18 seconds video of the very first image. Nothing is moving. Does anyone happen to know why?
          Thanks in advance.
          Edit: Actually I tried it with another model file, which is very basic, and it worked. But still can't make it on my real file.
            Serge73
            Cyril
            Similar issue.
            The animator does not transmit frames, all png images are from the first frame only.
            • C
              Calcifer
              Hello Fredo,
              First, thank you very much for your fantastic plugin. I have been using it extensively for the past 18 months.
              I also have the same problem described in previous posts when using V-Ray with Animator. It only renders the first frame. I thought my project was too complex so I tried with a very simple one: a moving cube. Still did not work. I use SU 2020 and V-Ray 4.20.01
              However, I tried on my laptop with SU 2017 and V-Ray 4.10.01 and it surprisingly works wonderfully. I don't know anything about technical stuff but I thought it was worth mentionning that.
              Thank you very much again!
              • P
                PopBen
                Again, thank you for your fantastic plugins. They've revolutionised the way I produce my models.
                I too am having the same issues. I'm running SketchUp 2017 with V-Ray for SketchUp 4.20.02 on a Mac.
                When trying to render the animation only the 1st frame is repeatedly rendered.
                When I process without VRay it works fine and also the preview in SketchUp displays fines.
                Thanks you in advance.
                • C
                  changh198
                  Hi Fredo,
                  Thank you for the amazing plugin.
                  However i am having the same issue on sketchup 2020 with Vray 4.2002.
                  It keeps rendering the first frame.
                  How can i fix this?
                  Thank you for your effort!
                  • fredo6F
                    The problem with VRay 4.2 rendering should be fixed with LibFredo6 v10.9a.
                      aenc_randyc
                      only scratched Animator's surface, so far I've noticed one issue:
                      Somehow when render with VRAY, the object in the scene is small, but when render with Natural, the object is correct (nice and big).
                      Not sure where can I change in setup where what I see is what I get?the object is nice and bigthe object is small
                      • fredo6F
                        Could you send me the model so that I try to reproduce.
                        It might be that VRay is configured to change the view camera.
                          aenc_randyc
                          Thanks Fredo, here is my Vray setting for your review. I don't see anything that could suggest changing the view camera.
                          Vray setting
                          • fredo6F
                            As of Animator v2.9a and LibFredo6 11.4a, VRay 5 is supported (in addition to previous versions of VRay).
                            • K
                              kennedyAZ
                              Hi there!
                              I'm just wondering if I'm saving as image sequence, can I control the format of the frames? I'm rendering with V-ray 5 on Sketchup 2020 and the result I'm getting is in .png and our preferred format is jpg.
                              How can I do this?
                              • fredo6F
                                You cannot....
                                What is the problem to have PNG images?
                                • 3 / 3
