    Animator and VRay
    renderpluginsextensions
    45 Posts 23 Posters 99.9k Views 23 Watching
      Serge73
      @cyrilc said:
      For some reasons, Vray only renders the first frame of the animation many times, while I see animator running properly.
      I am using Sketchup 2020 and Vray 4.20.01
      Cyril
      Similar issue.
      The animator does not transmit frames, all png images are from the first frame only.
        Calcifer
        Hello Fredo,
        First, thank you very much for your fantastic plugin. I have been using it extensively for the past 18 months.
        I also have the same problem described in previous posts when using V-Ray with Animator. It only renders the first frame. I thought my project was too complex so I tried with a very simple one: a moving cube. Still did not work. I use SU 2020 and V-Ray 4.20.01
        However, I tried on my laptop with SU 2017 and V-Ray 4.10.01 and it surprisingly works wonderfully. I don't know anything about technical stuff but I thought it was worth mentionning that.
        Thank you very much again!
          PopBen
          Again, thank you for your fantastic plugins. They've revolutionised the way I produce my models.
          I too am having the same issues. I'm running SketchUp 2017 with V-Ray for SketchUp 4.20.02 on a Mac.
          When trying to render the animation only the 1st frame is repeatedly rendered.
          When I process without VRay it works fine and also the preview in SketchUp displays fines.
          Thanks you in advance.
            changh198
            Hi Fredo,
            Thank you for the amazing plugin.
            However i am having the same issue on sketchup 2020 with Vray 4.2002.
            It keeps rendering the first frame.
            How can i fix this?
            Thank you for your effort!
            • fredo6F Offline
              The problem with VRay 4.2 rendering should be fixed with LibFredo6 v10.9a.
                aenc_randyc
                only scratched Animator's surface, so far I've noticed one issue:
                Somehow when render with VRAY, the object in the scene is small, but when render with Natural, the object is correct (nice and big).
                Not sure where can I change in setup where what I see is what I get?the object is nice and bigthe object is small
                • fredo6F Offline
                  Could you send me the model so that I try to reproduce.
                  It might be that VRay is configured to change the view camera.
                    aenc_randyc
                    Thanks Fredo, here is my Vray setting for your review. I don't see anything that could suggest changing the view camera.
                    Vray setting
                    • fredo6F Offline
                      As of Animator v2.9a and LibFredo6 11.4a, VRay 5 is supported (in addition to previous versions of VRay).
                        kennedyAZ
                        Hi there!
                        I'm just wondering if I'm saving as image sequence, can I control the format of the frames? I'm rendering with V-ray 5 on Sketchup 2020 and the result I'm getting is in .png and our preferred format is jpg.
                        How can I do this?
                        • fredo6F Offline
                          You cannot....
                          What is the problem to have PNG images?
                          • 3 / 3
