[Plugin Library] LibFredo6 - v14.4c - 18 May 24
LibFredo is signed.
You haven't clearly explained how you installed it or the other two Fredo extensions.
Let's start again from the beginning.
You will have downloaded three RBZ files for these extensions.
Use the red-button on the bottom-left of the Extension Manager dialog - visible in your screenshot -
to 'Install Extension'.
Navigate to, and select an RBZ and it'll be auto-installed.
Repeat for the remaining RBZ files.
Restart SketchUp and sync everything.
What does the Extension Manager dialog say now ?
Expand the LibFredo item to see its details... is it the same version as my screenshot ?
It you have incorrectly manually placed files into a location other than your Users/.../Plugins folder it might be causing issues and these should be removed too... -
NEW RELEASE: LibFredo6 v10.9a - 02 Jul 20
LibFredo6 10.9a fixes a problem with the animation rendering of VRay 4.2 and Animator
NEW RELEASE: LibFredo6 v10.8a - 20 Jun 20
LibFredo6 10.8a is a maintenance release, with bug fixing and adjustments mostly for Mac (dialogs)
today I regognised that all Fredo6-Plugins are in english (dont know since when).
When open the language it is set to German and all translation Fields are empty.
After changing to another language (e.g. English), and switching back to German, most of the Fields are with german translation (Left to translate: 201 / 605).
But unfortunately all Plugins still in english, even after restarting Sketchup.I'm using Sketchup2019 Pro.
All Fredo-Plugins are up to date. -
Perhaps you could update your profile?
I'm just guessing that you haven't made the correct setting in LibFredo6 yet.
-> Done
The config setting of LibFredo6 is "German". But there are no translations...
-> see also bottom line counter
When I switch to english it looks like:
After switching back to german it looks like:
After pressing "Save changes" and restart of Sketchup there are still no translations
-> looks like first attachment -
Did you set the language with the menu Window > LibFredo6 Settings... > Set Preferred Language
The Translation dialog boxes for LibFredo6 and my other plugins are to be used only by translators.
[attachment=0:3amq512s]<!-- ia0 -->LibFredo6 Set Language.png<!-- ia0 -->[/attachment:3amq512s]
Thanks Fredo6! That's fixing my problem
Looks like that I was working with your tools in english since switching to the "pro" Version of Sketchup.
By the way: You are doing a great job. Thanks a lot. -
Why don't you just keep it to one version? Why do you keep updating forever? It's the same tool.
There are periodic changes to Ruby, additional extensions that require additional or modified support files, and bug fixes. Fredo6 is pretty good about explaining why he updates when he does. You aren't forced to install these updates, however. You can ignore them.
Hi Tig,
Sorry it's taken me a while to look at this and come back to you.
I removed everything and started again (and re-watched your install tutorial).
But I'm still having the same problem.
I download the .rbz files onto my desktop, use the Extension Manager to install the files. This part seems to work fine.
I checked my Plug-Ins folder and the Fredo folders appear to be there (see screenshot).
I quit out of SketchUp and when I reopen it, I get this message that the LibFredo6 folder is not in the Plug-Ins folder (see second screenshot).
In the Extension Manager, it's saying your signature is invalid and I notice there are no details for the extensions (version etc).
I'm on a Mac so not sure if that makes a difference?
I am sure I'm following your instructions, but am not sure what to do now?
Thanks in advance for your help.
Victoria
This is weird.
Perhaps a MAC expert can comment / help.
Clearly the expected file/subfolder seems to be in your Plugins folder.
Perhaps it's a permissions issue preventing SketchUp seeing/reading them ?
Perhaps a MAC-guy can explain how to check the Plugins folder's permissions and ensure the reset trickles down to all its contents too...Fredo's RBZs are all signed and current, so it should report properly and show its version etc...
For the avoidance of doubt please get the current RBZ and reinstall in.
Restart SketchUp and see what happens...
https://sketchucation.com/pluginstore?pln=LibFredo6 -
I installed the latest version of - LibFredo6 - v10.9a - 02 jul 20.
SketchUp's extension manager shows it as UNSIGNED.
All of my other plug-ins are all marked SIGNED.Is it normal for LibFredo6 - v10.9a - 02 jul 20 to be marked as UNSIGNED?
If not, what is the process required to change its state from UNSIGNED to SIGNED?In advance, thank you for your response.
Look at LibFredo6 not top_Libfredo.
It doesn't matter if top_LibFredo isn't signed as long as you leave the loading permissions set to allow it to load.
It should look like this in Extension Manager.
[attachment=0:1y5ttorh]<!-- ia0 -->Screenshot - 7_24_2020 , 2_36_37 PM.png<!-- ia0 -->[/attachment:1y5ttorh]โโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโ
Thank you for your prompt response, Dave. Greatly appreciated.
@tig said:
This is weird.
https://sketchucation.com/pluginstore?pln=LibFredo6Well, this is weird. I've just retried all the steps (I swear I did the same things as last time) and it worked!
Thanks - these will be very helpful tools for my interior design work. -
NEW RELEASE: LibFredo6 v11.0a - 19 Aug 20
LibFredo6 11.0a provide bug fixing, cosmetic adjustments and technical evolution to a number of my plugins, in particular:
- FredoSpline
- FredoGuides
- FredoGhost
- FredoCorner
- FredoPortrait
After updating Fredolib (today, latest version) the file mentioned above is systematically blocked by my antivirus and no plugin is loaded.
The start of the error report
Erreur de chargement du fichier Fredo6_!LibFredo6.rb
Error: #<LoadError: 5: Acc\xE8s refus\xE9. - C:/Users/fosse/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU20/bin_LibFredo6.so>
C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:inrequire' C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in
require'
c:/users/xxxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:622:inload_binary' c:/users/xxxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:257:in
startup'
C:/Users/xxxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:61:inprocess' C:/Users/xxxxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in
module:LibFredo6_Loader'
C:/Users/xxxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!Si possible รฉchangeons sur le forum fr, merci
Zooen
RE,
Bon en redรฉmarrant l'ordi tout fonctionne. Donc pas d'explication pour moi. Souvent le fait de redรฉmarrer l'ordi corrige les dysfonctionnements lors de mises ร jour de logiciels, mais je n'y avais pas pensรฉ.
Bonne fin de journรฉe, Zooen
After upgrading LibFredo6 v11.0a๏ผI can not use "ctrl"key to ctrl "toggle JointPushPull create starting face "in"Joint Push Pull Interactive v4.4e"
If it is a bug,hope to fix it.
