    Oval house
    31 Posts 6 Posters 13.4k Views 6 Watching
    • Bryan KB Offline
      A full house this time.
      The trucks are temporary and only used for scale.
      • Mike AmosM Online
        Interesting design, reminds me of something I have seen on a design program somewhere. πŸ‘
        • Bryan KB Offline
          Thanks.
          An oval house design is certainly nothing new. Many designers have already explored this concept. I just found it interesting. πŸ˜‰
          In case anyone is wondering what the lines of the flat face are, they are centerlines and the shorter line is the floor line. These are what I will use to lay out the interior.
          • Bryan KB Offline
            Updates.
            • Bryan KB Offline
              I am working on the internal floor plan so the next update will be a while.
              • Bryan KB Offline
                2 more exterior views in the meantime.
                • HornOxxH Offline
                  HornOxx
                  always great to see πŸ‘ these "step by step steps" (?! πŸ˜‰ ) - are these actually 4 apartments which meet together in the middle?
                  never trust a skinny cook
                  • Bryan KB Offline
                    Thanks.
                    Nope. Single house.
                    • N Offline
                      nlipovac
                      It is looking interesting.
                      Subscribed for updates. πŸ‘ β˜€
                      • Bryan KB Offline
                        Thanks nlipovac.
                        Some more updates. Intersected models and then cleaned out all the interior lines and faces.
                        • Mike AmosM Online
                          Looking good mate, when can I move in? πŸ˜†
                          • Bryan KB Offline
                            Thanks.
                            When? Right after I start all over again. πŸ˜†
                            The model is made wrong. Overall too small for the floorplan and also the hidden geometry doesn't line up. This created intersection issues. Wrong number of segments in the ovals.
                            Oops. πŸ˜†
                            So I will start again and post the updates in this thread. No problem. The rework will go faster. Same design. Just fixed.
                              shawb
                              Perhaps this might help?
                              Create the first leg as circular. Copy rotate. Intersect. Remove internal faces. Select all and scale about centre to flatten to oval.
                              Although this could also be done with Solid tools (Pro or plugin) it seemed to be just as quick with Intersect.
                              Rotate & copy
                              Intersect & remove internal faces
                              Scale about centre
                              • Bryan KB Offline
                                Thanks shawb. I've already figured out the issue and will have the rebuild done tonight. That's how I knew it was wrong. πŸ˜‰
                                Cheers. πŸ‘
                                BTW, the correct number of segments to make a perfect lineup of centerlines is 180 segments in a circle. 45 segments per 1/4 arc. (90 / 2 = 45)
                                I overlooked this.
                                  shawb
                                  Will look forward to seeing the progress.
                                  • Bryan KB Offline
                                    Got it right this time.
                                    • HornOxxH Offline
                                      HornOxx
                                      ... completely detached from your design content topic Bryan - I always love these "simple" native SkUp graphics! There never is a single reason to press any render button!
                                      πŸ‘
                                      • Bryan KB Offline
                                        Main rework finished. It is now a two story house and far bigger on the inside.
                                        3rd pic is showing hidden lines.
                                        On to the details!
                                        • Bryan KB Offline
                                          πŸ‘
                                          Yeah, the original programming team absolutely picked the right palette for everything. It is definitely one of the things I like best about SketchUp.
                                          • Bryan KB Offline
                                            Almost finished with the rework.
                                            It was not easy separating the two halves. Not hard, just tedious with straggling lines grouped with the wrong halves.
