    Oval house
    31 Posts 6 Posters 13.8k Views 6 Watching
    • Bryan KB
      Thanks.
      Nope. Single house.
      • N
        nlipovac
        It is looking interesting.
        Subscribed for updates. πŸ‘ β˜€
        • Bryan KB
          Thanks nlipovac.
          Some more updates. Intersected models and then cleaned out all the interior lines and faces.
            Looking good mate, when can I move in? πŸ˜†
            • Bryan KB
              Thanks.
              When? Right after I start all over again. πŸ˜†
              The model is made wrong. Overall too small for the floorplan and also the hidden geometry doesn't line up. This created intersection issues. Wrong number of segments in the ovals.
              Oops. πŸ˜†
              So I will start again and post the updates in this thread. No problem. The rework will go faster. Same design. Just fixed.
                shawb
                Perhaps this might help?
                Create the first leg as circular. Copy rotate. Intersect. Remove internal faces. Select all and scale about centre to flatten to oval.
                Although this could also be done with Solid tools (Pro or plugin) it seemed to be just as quick with Intersect.
                Rotate & copy
                Intersect & remove internal faces
                Scale about centre
                • Bryan KB
                  Thanks shawb. I've already figured out the issue and will have the rebuild done tonight. That's how I knew it was wrong. πŸ˜‰
                  Cheers. πŸ‘
                  BTW, the correct number of segments to make a perfect lineup of centerlines is 180 segments in a circle. 45 segments per 1/4 arc. (90 / 2 = 45)
                  I overlooked this.
                    shawb
                    Will look forward to seeing the progress.
                    • Bryan KB
                      Got it right this time.
                      • HornOxxH
                        HornOxx
                        ... completely detached from your design content topic Bryan - I always love these "simple" native SkUp graphics! There never is a single reason to press any render button!
                        πŸ‘
                        never trust a skinny cook
                        • Bryan KB
                          Main rework finished. It is now a two story house and far bigger on the inside.
                          3rd pic is showing hidden lines.
                          On to the details!
                          • Bryan KB
                            πŸ‘
                            Yeah, the original programming team absolutely picked the right palette for everything. It is definitely one of the things I like best about SketchUp.
                            • Bryan KB
                              Almost finished with the rework.
                              It was not easy separating the two halves. Not hard, just tedious with straggling lines grouped with the wrong halves.
                              • HornOxxH
                                HornOxx
                                @bryan k said:
                                ...the original programming team absolutely picked the right palette for everything. It is definitely one of the things I like best about SketchUp.
                                better it cannot be formulated - at least in this aspect SkUp is unbeatable πŸ‘
                                • Bryan KB
                                  Working on the stair detail.
                                  • Bryan KB
                                    Working on garage detail.
                                    • Bryan KB
                                      More stair detail.
                                        shawb
                                        Always tempting to hit the Render button - just because you have one! Agree there is a lot of SU to be explored and utilised 'just out of the box'.
                                        Project looking good, especially with the bigger size and two levels.
                                        • Bryan KB
                                          Thanks shawb.
                                          • david_hD
                                            david_h
                                            Seems very Stanley Tigerman-ish. Make sure that the pick-ups dont have campers on the back. Low clearance doors. πŸ’š
