    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 713.7k Views 151 Watching
    • fredo6F
      NEW RELEASE: FredoCorner v1.7d - 18 Feb 20
      Requirement: LibFredo6 9.1b
      FredoCorner 1.7d for extenson of validity.
      Please note that, in the current version of FredoCorner:
      • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
      • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
      • Terminal corners (that is ending on a single edge) may present issues and bugs
      • No documentation yet, so watch the videos that I will publish.
      Please report issues, questions and any feedback in the present thread
      Home Page of FredoCorner for information and Download.
      Main post of this FredoCorner thread.
      • DikoJihazD
        DikoJihaz
        It's a great plagin indeed, I used it for a short period of time. But now I can't get it work at all ((( I installed the latest versions of both LibFredo6 and FredoCorner plugins. The FredoCorner toolbar shows up but when I try to click on it nothing happens ((( I reinstalled SU and plugins, but still the problem is there (( Please, help me make it work!!! Thank you in advance for all your help and guidance!
          What version of SketchUp are you using? Your profile indicates a version that doesn't exist and that could be the cause.
          • DikoJihazD
            DikoJihaz
            Dave, I use SketchUp 2018 Pro version. It has to be compatible with FredoCorner, at least the notation to the plugin says that.
            • fredo6F
              FredoCorner works on SU2018.
              Can you open the Ruby console before you launch FredoCorner. Thanks.
              • shake1S
                shake1
                Please, tell me why?
                Frame 2x2cm, try offsen 0,2cm
                Frame 2x2 offset 0.2.skp
                • fredo6F
                  Possibly, the model is too small. Try to scale it up (and then scale it down).
                  Also, it would help to post the model.
                  • shake1S
                    shake1
                    Hi, I posted the model again, and gif
                    • fredo6F
                      There seems to be a bug in FredoCorner. Not easy to identify.
                      I'll have a closer look.
                      In the meantime, I suggest you use RoundCorner, which will do the job with no issue.
                      • E
                        Einstein
                        Hi!
                        Are there chances of fixing the bug that a simple bevel cuts along the new faces in two?
                        Cheers!
                        • fredo6F
                          @einstein said:
                          Hi!
                          Cheers!
                          There are chances....
                          • fredo6F
                            NEW RELEASE: FredoCorner v1.8a - 26 Apr 20
                            FredoCorner 1.8a is a major release
                            • Disabled the possibility to round new corners in the same session. When corners are generated, you have the option to modify the parameters ('Apply Change') or to Exit (Double-Click).
                            • Correction for the Bevel tool at triangulated corners. Bevel are now made of a single face, possibly triangulated, except when the bordering faces do not have the same material.
                            • E
                              Einstein
                              Thank you so much! I needed this change a lot 😄
                              Your fantastic tools are like air to me.
                              • C
                                comsasa
                                FredoCorner v1.8a & LibFredo6 v10.5a User.
                                I want the edge color to appear as the sketchup default.
                                At the moment of using the Fredocorner brown, magenta, red and violet materials appear in the material window.
                                I don't want this to appear. What should I do?
                                  First show an example of what you are seeing.
                                  What version of SketchUp are you using. Your profile says "2019 Free/Make" but there is no such version.
                                  • fredo6F
                                    NEW RELEASE: FredoCorner v1.8b - 28 May 20
                                    FredoCorner 1.8b is a maintenance release fixing an issue with improper coloring of edges
                                    • fredo6F
                                      Sorry for that. I use colors for debugging purpose and apparently I left them in the published version.
                                      This is fixed in FredoCorner v1.8b
                                      • fredo6F
                                        NEW RELEASE: FredoCorner v1.9a - 19 Jun 20
                                        Requirement: LibFredo6 10.7a
                                        FredoCorner 1.9a is a maintenance release
                                        • fixing an issue with reselection of edges after a Repair - Edit
                                        • Exit via a single click
                                          sehuz
                                          Hello. Great job with this amazing tool Fredo !
                                          I'v just installed today and test it with the direct link for Twinmotion, sadly the beveling doesn't appear, and also it shows issues on the geometry.
                                          But exporting the model to Twinmotion it works great.
                                          • fredo6F
                                            What is this "direct link for Twinmotion"?
                                            Did you generate the geometry or just activate the Preview mode (whihc is just drawing, not generating geometry)?
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
