    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 713.7k Views 151 Watching
    • F
      FlygFartyg
      Cant open sketchup when this is in the folder. It crashes Sketchup as soon as i start it. When i remove FredoCorner from the extensions folder Sketchup is able to run again. Wierd
      • N
        nebin asharaf
        I Donno why it's showing this comment, its not a group, nor a component...
        Any one can help?
        • N
          nebin asharaf
          Yes its done
          Its rectified.
          "EDGE PROF. FILTER " WAS NOT SELECTED
          • fredo6F
            NEW RELEASE: FredoCorner v1.7d - 18 Feb 20
            Requirement: LibFredo6 9.1b
            FredoCorner 1.7d for extenson of validity.
            Please note that, in the current version of FredoCorner:
            • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
            • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
            • Terminal corners (that is ending on a single edge) may present issues and bugs
            • No documentation yet, so watch the videos that I will publish.
            Please report issues, questions and any feedback in the present thread
            Home Page of FredoCorner for information and Download.
            Main post of this FredoCorner thread.
            • DikoJihazD
              DikoJihaz
              It's a great plagin indeed, I used it for a short period of time. But now I can't get it work at all ((( I installed the latest versions of both LibFredo6 and FredoCorner plugins. The FredoCorner toolbar shows up but when I try to click on it nothing happens ((( I reinstalled SU and plugins, but still the problem is there (( Please, help me make it work!!! Thank you in advance for all your help and guidance!
                What version of SketchUp are you using? Your profile indicates a version that doesn't exist and that could be the cause.
                • DikoJihazD
                  DikoJihaz
                  Dave, I use SketchUp 2018 Pro version. It has to be compatible with FredoCorner, at least the notation to the plugin says that.
                  • fredo6F
                    FredoCorner works on SU2018.
                    Can you open the Ruby console before you launch FredoCorner. Thanks.
                    • shake1S
                      shake1
                      Please, tell me why?
                      Frame 2x2cm, try offsen 0,2cm
                      Frame 2x2 offset 0.2.skp
                      • fredo6F
                        Possibly, the model is too small. Try to scale it up (and then scale it down).
                        Also, it would help to post the model.
                        • shake1S
                          shake1
                          Hi, I posted the model again, and gif
                          • fredo6F
                            There seems to be a bug in FredoCorner. Not easy to identify.
                            I'll have a closer look.
                            In the meantime, I suggest you use RoundCorner, which will do the job with no issue.
                            • E
                              Einstein
                              Hi!
                              Are there chances of fixing the bug that a simple bevel cuts along the new faces in two?
                              Cheers!
                              • fredo6F
                                @einstein said:
                                Hi!
                                Cheers!
                                There are chances....
                                • fredo6F
                                  NEW RELEASE: FredoCorner v1.8a - 26 Apr 20
                                  FredoCorner 1.8a is a major release
                                  • Disabled the possibility to round new corners in the same session. When corners are generated, you have the option to modify the parameters ('Apply Change') or to Exit (Double-Click).
                                  • Correction for the Bevel tool at triangulated corners. Bevel are now made of a single face, possibly triangulated, except when the bordering faces do not have the same material.
                                  • E
                                    Einstein
                                    Thank you so much! I needed this change a lot 😄
                                    Your fantastic tools are like air to me.
                                    • C
                                      comsasa
                                      FredoCorner v1.8a & LibFredo6 v10.5a User.
                                      I want the edge color to appear as the sketchup default.
                                      At the moment of using the Fredocorner brown, magenta, red and violet materials appear in the material window.
                                      I don't want this to appear. What should I do?
                                        First show an example of what you are seeing.
                                        What version of SketchUp are you using. Your profile says "2019 Free/Make" but there is no such version.
                                        • fredo6F
                                          NEW RELEASE: FredoCorner v1.8b - 28 May 20
                                          FredoCorner 1.8b is a maintenance release fixing an issue with improper coloring of edges
                                          • fredo6F
                                            Sorry for that. I use colors for debugging purpose and apparently I left them in the published version.
                                            This is fixed in FredoCorner v1.8b
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
