    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • fredo6F
      This seems to be a limitation of FredoCorner. I can reproduce it on my computer.
      The message is not informative, because, when there is a problem in the geometry, FredoCorner assumes that it could come from an offset which is too large. I know where the error happens, but this seems to be an issue in the heart of the algorithm, which is quite complex for this type of geometry. So I put your model in the stack of models I have already for when I'll dig into FredoCorner deep core to see how to make it more robust.
      At a first glance, I am scratching my head on what could be the correct result with a selection of only 3 edges at this 6-edge corner, convex / concave.
      It works fine however if you select the 6 edges.
        mikedub
        HI, today I just installed latest FredoCorner 1.7c and the Library 9.5c (Fredo6_!LibFredo6) folder and ruby files in the proper location – User > Library > Application Support > SketchUp > Plugins.
        The Extension Manager says they are installed and active. And I see it in the Sketchup menu. But (after making a cube and selecting it, to test) when I click on the FredoCorner menu icon, or choose it from the menu, nothing happens. The FredoCorner menu does not come up at all.
        I tried uninstalling and reinstalling the plugins, quitting and restarting Sketchup a few times. Still nothing.
        Please help!
        Cheers,
        Mike
        • fredo6F
          Could you open the Ruby console to see if there are errors displayed.
          • Mim86M
            Mim86
            This is fabulous, I have been going nuts trying to fudge fillets on my models. Now I can do it easily. I have added the extension, although it is telling me I need LibFredo6 9.1b. Which I can't find anywhere. Thanks in advance for any help here.
            Mim
            • fredo6F
              @mim86 said:
              ...although it is telling me I need LibFredo6 9.1b.
              Just take the latest version of LibFredo6, currently v9.5g.
              • F
                FlygFartyg
                Cant open sketchup when this is in the folder. It crashes Sketchup as soon as i start it. When i remove FredoCorner from the extensions folder Sketchup is able to run again. Wierd
                • N
                  nebin asharaf
                  I Donno why it's showing this comment, its not a group, nor a component...
                  Any one can help?
                  • N
                    nebin asharaf
                    Yes its done
                    Its rectified.
                    "EDGE PROF. FILTER " WAS NOT SELECTED
                    • fredo6F
                      NEW RELEASE: FredoCorner v1.7d - 18 Feb 20
                      Requirement: LibFredo6 9.1b
                      FredoCorner 1.7d for extenson of validity.
                      Please note that, in the current version of FredoCorner:
                      • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                      • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                      • Terminal corners (that is ending on a single edge) may present issues and bugs
                      • No documentation yet, so watch the videos that I will publish.
                      Please report issues, questions and any feedback in the present thread
                      Home Page of FredoCorner for information and Download.
                      Main post of this FredoCorner thread.
                      • DikoJihazD
                        DikoJihaz
                        It's a great plagin indeed, I used it for a short period of time. But now I can't get it work at all ((( I installed the latest versions of both LibFredo6 and FredoCorner plugins. The FredoCorner toolbar shows up but when I try to click on it nothing happens ((( I reinstalled SU and plugins, but still the problem is there (( Please, help me make it work!!! Thank you in advance for all your help and guidance!
                          What version of SketchUp are you using? Your profile indicates a version that doesn't exist and that could be the cause.
                          • DikoJihazD
                            DikoJihaz
                            Dave, I use SketchUp 2018 Pro version. It has to be compatible with FredoCorner, at least the notation to the plugin says that.
                            • fredo6F
                              FredoCorner works on SU2018.
                              Can you open the Ruby console before you launch FredoCorner. Thanks.
                              • shake1S
                                shake1
                                Please, tell me why?
                                Frame 2x2cm, try offsen 0,2cm
                                Frame 2x2 offset 0.2.skp
                                • fredo6F
                                  Possibly, the model is too small. Try to scale it up (and then scale it down).
                                  Also, it would help to post the model.
                                  • shake1S
                                    shake1
                                    Hi, I posted the model again, and gif
                                    • fredo6F
                                      There seems to be a bug in FredoCorner. Not easy to identify.
                                      I'll have a closer look.
                                      In the meantime, I suggest you use RoundCorner, which will do the job with no issue.
                                      • E
                                        Einstein
                                        Hi!
                                        Are there chances of fixing the bug that a simple bevel cuts along the new faces in two?
                                        Cheers!
                                        • fredo6F
                                          @einstein said:
                                          Hi!
                                          Cheers!
                                          There are chances....
                                          • fredo6F
                                            NEW RELEASE: FredoCorner v1.8a - 26 Apr 20
                                            FredoCorner 1.8a is a major release
                                            • Disabled the possibility to round new corners in the same session. When corners are generated, you have the option to modify the parameters ('Apply Change') or to Exit (Double-Click).
                                            • Correction for the Bevel tool at triangulated corners. Bevel are now made of a single face, possibly triangulated, except when the bordering faces do not have the same material.
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
