    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 662.3k Views 151 Watching
    • Mim86M Offline
      Mim86
      This is fabulous, I have been going nuts trying to fudge fillets on my models. Now I can do it easily. I have added the extension, although it is telling me I need LibFredo6 9.1b. Which I can't find anywhere. Thanks in advance for any help here.
      Mim
      • fredo6F Offline
        @mim86 said:
        ...although it is telling me I need LibFredo6 9.1b.
        Just take the latest version of LibFredo6, currently v9.5g.
        • F Offline
          FlygFartyg
          Cant open sketchup when this is in the folder. It crashes Sketchup as soon as i start it. When i remove FredoCorner from the extensions folder Sketchup is able to run again. Wierd
          • N Offline
            nebin asharaf
            I Donno why it's showing this comment, its not a group, nor a component...
            Any one can help?
            • N Offline
              nebin asharaf
              Yes its done
              Its rectified.
              "EDGE PROF. FILTER " WAS NOT SELECTED
              • fredo6F Offline
                NEW RELEASE: FredoCorner v1.7d - 18 Feb 20
                Requirement: LibFredo6 9.1b
                FredoCorner 1.7d for extenson of validity.
                Please note that, in the current version of FredoCorner:
                • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                • Terminal corners (that is ending on a single edge) may present issues and bugs
                • No documentation yet, so watch the videos that I will publish.
                Please report issues, questions and any feedback in the present thread
                Home Page of FredoCorner for information and Download.
                Main post of this FredoCorner thread.
                • DikoJihazD Offline
                  DikoJihaz
                  It's a great plagin indeed, I used it for a short period of time. But now I can't get it work at all ((( I installed the latest versions of both LibFredo6 and FredoCorner plugins. The FredoCorner toolbar shows up but when I try to click on it nothing happens ((( I reinstalled SU and plugins, but still the problem is there (( Please, help me make it work!!! Thank you in advance for all your help and guidance!
                    What version of SketchUp are you using? Your profile indicates a version that doesn't exist and that could be the cause.
                      DikoJihaz
                      Dave, I use SketchUp 2018 Pro version. It has to be compatible with FredoCorner, at least the notation to the plugin says that.
                      • fredo6F Offline
                        FredoCorner works on SU2018.
                        Can you open the Ruby console before you launch FredoCorner. Thanks.
                        • shake1S Offline
                          shake1
                          Please, tell me why?
                          Frame 2x2cm, try offsen 0,2cm
                          Frame 2x2 offset 0.2.skp
                          • fredo6F Offline
                            Possibly, the model is too small. Try to scale it up (and then scale it down).
                            Also, it would help to post the model.
                            • shake1S Offline
                              shake1
                              Hi, I posted the model again, and gif
                              • fredo6F Offline
                                There seems to be a bug in FredoCorner. Not easy to identify.
                                I'll have a closer look.
                                In the meantime, I suggest you use RoundCorner, which will do the job with no issue.
                                • E Offline
                                  Einstein
                                  Hi!
                                  Are there chances of fixing the bug that a simple bevel cuts along the new faces in two?
                                  Cheers!
                                  • fredo6F Offline
                                    @einstein said:
                                    Hi!
                                    Cheers!
                                    There are chances....
                                    • fredo6F Offline
                                      NEW RELEASE: FredoCorner v1.8a - 26 Apr 20
                                      FredoCorner 1.8a is a major release
                                      • Disabled the possibility to round new corners in the same session. When corners are generated, you have the option to modify the parameters ('Apply Change') or to Exit (Double-Click).
                                      • Correction for the Bevel tool at triangulated corners. Bevel are now made of a single face, possibly triangulated, except when the bordering faces do not have the same material.
                                      • E Offline
                                        Einstein
                                        Thank you so much! I needed this change a lot πŸ˜„
                                        Your fantastic tools are like air to me.
                                          comsasa
                                          FredoCorner v1.8a & LibFredo6 v10.5a User.
                                          I want the edge color to appear as the sketchup default.
                                          At the moment of using the Fredocorner brown, magenta, red and violet materials appear in the material window.
                                          I don't want this to appear. What should I do?
                                            First show an example of what you are seeing.
                                            What version of SketchUp are you using. Your profile says "2019 Free/Make" but there is no such version.
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
