    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • fredo6F
      @dikojihaz said:
      Dave, I use SketchUp 2018 Pro version. It has to be compatible with FredoCorner, at least the notation to the plugin says that.
      FredoCorner works on SU2018.
      Can you open the Ruby console before you launch FredoCorner. Thanks.
      • shake1S
        shake1
        Please, tell me why?
        Frame 2x2cm, try offsen 0,2cm
        Frame 2x2 offset 0.2.skp
        • fredo6F
          Possibly, the model is too small. Try to scale it up (and then scale it down).
          Also, it would help to post the model.
          • shake1S
            shake1
            Hi, I posted the model again, and gif
            • fredo6F
              There seems to be a bug in FredoCorner. Not easy to identify.
              I'll have a closer look.
              In the meantime, I suggest you use RoundCorner, which will do the job with no issue.
              • E
                Einstein
                Hi!
                Are there chances of fixing the bug that a simple bevel cuts along the new faces in two?
                Cheers!
                • fredo6F
                  @einstein said:
                  Hi!
                  Cheers!
                  There are chances....
                  • fredo6F
                    NEW RELEASE: FredoCorner v1.8a - 26 Apr 20
                    Requirement: LibFredo6 9.1b
                    FredoCorner 1.8a is a major release
                    • Disabled the possibility to round new corners in the same session. When corners are generated, you have the option to modify the parameters ('Apply Change') or to Exit (Double-Click).
                    • Correction for the Bevel tool at triangulated corners. Bevel are now made of a single face, possibly triangulated, except when the bordering faces do not have the same material.
                    Please note that, in the current version of FredoCorner:
                    • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                    • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                    • Terminal corners (that is ending on a single edge) may present issues and bugs
                    • No documentation yet, so watch the videos that I will publish.
                    Please report issues, questions and any feedback in the present thread
                    Home Page of FredoCorner for information and Download.
                    Main post of this FredoCorner thread.
                    • E
                      Einstein
                      Thank you so much! I needed this change a lot 😄
                      Your fantastic tools are like air to me.
                      • C
                        comsasa
                        FredoCorner v1.8a & LibFredo6 v10.5a User.
                        I want the edge color to appear as the sketchup default.
                        At the moment of using the Fredocorner brown, magenta, red and violet materials appear in the material window.
                        I don't want this to appear. What should I do?
                          First show an example of what you are seeing.
                          What version of SketchUp are you using. Your profile says "2019 Free/Make" but there is no such version.
                          • fredo6F
                            NEW RELEASE: FredoCorner v1.8b - 28 May 20
                            FredoCorner 1.8b is a maintenance release fixing an issue with improper coloring of edges
                            • fredo6F
                              Sorry for that. I use colors for debugging purpose and apparently I left them in the published version.
                              This is fixed in FredoCorner v1.8b
                              • fredo6F
                                NEW RELEASE: FredoCorner v1.9a - 19 Jun 20
                                Requirement: LibFredo6 10.7a
                                FredoCorner 1.9a is a maintenance release
                                • fixing an issue with reselection of edges after a Repair - Edit
                                • Exit via a single click
                                  sehuz
                                  Hello. Great job with this amazing tool Fredo !
                                  I'v just installed today and test it with the direct link for Twinmotion, sadly the beveling doesn't appear, and also it shows issues on the geometry.
                                  But exporting the model to Twinmotion it works great.
                                  • fredo6F
                                    What is this "direct link for Twinmotion"?
                                    Did you generate the geometry or just activate the Preview mode (whihc is just drawing, not generating geometry)?
                                    • fredo6F
                                      NEW RELEASE: FredoCorner v2.0a - 19 Aug 20
                                      Requirement: LibFredo6 11.0a
                                      FredoCorner 2.0a is a maintenance release
                                      • Improvement of Orbit/Pan on Windows for Preview mode
                                      • Extension of validity
                                        rv1974
                                        Fredo, could you make the offset faces stay selected after command is executed please? Just like you did in JPP. It'd help tremendously to do some nice things with this separated selection.
                                        P.S. You are one step 😄 from making long awaited Groove maker. All it takes is to add is to add 'ignore hard\open edges' option***** in pre-selected geometry and integrate merge coplanar offset faces and JPP inwards.
                                        *- In his video, Ahmed solves this ignoring problem by drawing initial groove lines on separate tag.
                                          Or you have another trick 😉
                                          Make 2 same volumes at the same place !
                                          Fractalize one then Exploded View it
                                          you have your grooves! 💚
                                          https://i.postimg.cc/BbJx0qzz/CadRays2.jpg
                                          • V
                                            vbbartlett
                                            I have a file that breaks, I am attaching it in hopes that you can use it to improve the plugin, which is awesome btw. It is a tooth of a gear. I have removed the rest of the gear as it is just too many verts.
                                            fredoerror.skp
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
