    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 63.3k Views 17 Watching
      I'm getting the same message Ken shows. I made sure that I have the latest versions of both FredoGuides and LibFredo6 but I still get it.
        adorian
        HELP Fredo, whenever I click the right mouse I get this window; and uninstall the plugin but keeps coming.
        I tried everything, including installing the new library but the window keeps coming!
        • fredo6F Offline
          NEW RELEASE: FredoGuides v1.1e - 22 Jan 20
          Requirement: LibFredo6 9.5
          FredoGuides v1.1e extends the validity.
          Home Page of FredoGuides[/color][/b] for information and Download.
          Main post of this FredoGuides thread.
          • Didier BurD Offline
            Didier Bur
            Thanks Fredo, Problem solved.
            P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
            DB
            • fredo6F Offline
              Precisely, these extensions may become paid in the future... It's a minor inconvenience, since they are free today. Also, a good way to keep the installed base on recent versions of the script.
              • JClementsJ Offline
                JClements
                Before I updated I had the same issue.
                I installed the update via the SketchUcation extension. However, I had to close SU and reopen it before the update would work.
                • fredo6F Offline
                  This is true for most plugins, because a ne version may have to update the menu and also the part that loads when Sketchup starts.
                  • kenK Offline
                    ken
                    When ever I right click on any object, I get the attached error message.
                    Thank you Fredo, the new install solved the problem.
                    • fredo6F Offline
                      NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
                      FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
                      **Home Page of FredoGuides** for information and Download.
                        penumbra
                        I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
                        • fredo6F Offline
                          If you can reproduce it, I'll be interested in the file.
                          Also, if you can leave the Ruby console opened when deleting guides...
                          • fredo6F Offline
                            NEW RELEASE: FredoGuides v1.3a - 21 May 20
                            Requirement: LibFredo6 9.5k
                            FredoGuides v1.3a extends the validity.
                            • zivotinjaZ Offline
                              zivotinja
                              I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
                              Thank you
                              • fredo6F Offline
                                To uninstall, please delete both the Fredo6_FredoGuides.rb file and the Fredo6_FredoGuides subfolder.
                                Did you try however to upgrade to the new version?
                                  zivotinja
                                  So all elements are removed from the plugins folder. However the toolbar still shows. ??! 🤢 😮
                                    zivotinja
                                    FYI
                                    First Image
                                    Second Image
                                      zivotinja
                                      I have uninstalled and restarted. However, the toolbar and error message still appear
                                        zivotinja
                                        Error Message. I cannot use right mouse button any more
                                        error
                                        • fredo6F Offline
                                          Since you restarted Sketchup, there must be another place where Sketchup take FredoGuides from.
                                          Otherwise, it would be magic....
                                          • fredo6F Offline
                                            NEW RELEASE: FredoGuides v1.4a - 25 May 20
                                            Requirements
                                            • LibFredo6: v10.5a
                                            FredoGuides v1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                                            • 1 / 3
