    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 65.4k Views 17 Watching
    • fredo6F
      NEW RELEASE: FredoGuides v1.1e - 22 Jan 20
      Requirement: LibFredo6 9.5
      FredoGuides v1.1e extends the validity.
      Home Page of FredoGuides[/color][/b] for information and Download.
      Main post of this FredoGuides thread.
      • Didier BurD
        Didier Bur
        Thanks Fredo, Problem solved.
        P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
        DB
        • fredo6F
          Precisely, these extensions may become paid in the future... It's a minor inconvenience, since they are free today. Also, a good way to keep the installed base on recent versions of the script.
          • JClementsJ
            JClements
            Before I updated I had the same issue.
            I installed the update via the SketchUcation extension. However, I had to close SU and reopen it before the update would work.
            • fredo6F
              This is true for most plugins, because a ne version may have to update the menu and also the part that loads when Sketchup starts.
              • kenK
                ken
                When ever I right click on any object, I get the attached error message.
                Thank you Fredo, the new install solved the problem.
                • fredo6F
                  NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
                  FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
                  **Home Page of FredoGuides** for information and Download.
                  • P
                    penumbra
                    I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
                    • fredo6F
                      If you can reproduce it, I'll be interested in the file.
                      Also, if you can leave the Ruby console opened when deleting guides...
                      • fredo6F
                        NEW RELEASE: FredoGuides v1.3a - 21 May 20
                        Requirement: LibFredo6 9.5k
                        FredoGuides v1.3a extends the validity.
                        • zivotinjaZ
                          zivotinja
                          I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
                          Thank you
                          • fredo6F
                            To uninstall, please delete both the Fredo6_FredoGuides.rb file and the Fredo6_FredoGuides subfolder.
                            Did you try however to upgrade to the new version?
                            • zivotinjaZ
                              zivotinja
                              So all elements are removed from the plugins folder. However the toolbar still shows. ??! 🤢 😮
                              • zivotinjaZ
                                zivotinja
                                FYI
                                First Image
                                Second Image
                                • zivotinjaZ
                                  zivotinja
                                  I have uninstalled and restarted. However, the toolbar and error message still appear
                                  • zivotinjaZ
                                    zivotinja
                                    Error Message. I cannot use right mouse button any more
                                    error
                                    • fredo6F
                                      Since you restarted Sketchup, there must be another place where Sketchup take FredoGuides from.
                                      Otherwise, it would be magic....
                                      • fredo6F
                                        NEW RELEASE: FredoGuides v1.4a - 25 May 20
                                        Requirements
                                        • LibFredo6: v10.5a
                                        FredoGuides v1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                                        • fredo6F
                                          NEW RELEASE: FredoGuides v1.5a - 19 Aug 20
                                          Requirements
                                          • LibFredo6: v11.0a
                                          FredoGuides v1.5a is a maintenance release for bug fixing, cosmetic adjustments and extension of validity
                                          • SJS66S
                                            SJS66
                                            I just posted about FredoGuides not updating in SU but I also have to say, this topic has to have one of the most confusing posts I've ever seen. Talk about taking around in circles. I'll have to search 'my posts' to find where I just posted, or maybe I just need a kit kat....lol.
                                            • 2 / 3
