    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 62.4k Views 17 Watching
    • fredo6F Offline
      NEW RELEASE: FredoGuides v1.1d - 05 Jan 20
      Requirement: LibFredo6 9.5
      FredoGuides v1.1d includes the Spanish translation by Oxer.
      Home Page of FredoGuides[/color][/b] for information and Download.
      Main post of this FredoGuides thread.
        I'm getting the same message Ken shows. I made sure that I have the latest versions of both FredoGuides and LibFredo6 but I still get it.
          adorian
          HELP Fredo, whenever I click the right mouse I get this window; and uninstall the plugin but keeps coming.
          I tried everything, including installing the new library but the window keeps coming!
          • fredo6F Offline
            NEW RELEASE: FredoGuides v1.1e - 22 Jan 20
            FredoGuides v1.1e extends the validity.
            • Didier BurD Offline
              Didier Bur
              Thanks Fredo, Problem solved.
              P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
              DB
              • fredo6F Offline
                Precisely, these extensions may become paid in the future... It's a minor inconvenience, since they are free today. Also, a good way to keep the installed base on recent versions of the script.
                • JClementsJ Offline
                  JClements
                  Before I updated I had the same issue.
                  I installed the update via the SketchUcation extension. However, I had to close SU and reopen it before the update would work.
                  • fredo6F Offline
                    This is true for most plugins, because a ne version may have to update the menu and also the part that loads when Sketchup starts.
                    • kenK Offline
                      ken
                      When ever I right click on any object, I get the attached error message.
                      Thank you Fredo, the new install solved the problem.
                      • fredo6F Offline
                        NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
                        FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
                        **Home Page of FredoGuides** for information and Download.
                          penumbra
                          I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
                          • fredo6F Offline
                            If you can reproduce it, I'll be interested in the file.
                            Also, if you can leave the Ruby console opened when deleting guides...
                            • fredo6F Offline
                              NEW RELEASE: FredoGuides v1.3a - 21 May 20
                              Requirement: LibFredo6 9.5k
                              FredoGuides v1.3a extends the validity.
                              • zivotinjaZ Offline
                                zivotinja
                                I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
                                Thank you
                                • fredo6F Offline
                                  To uninstall, please delete both the Fredo6_FredoGuides.rb file and the Fredo6_FredoGuides subfolder.
                                  Did you try however to upgrade to the new version?
                                    zivotinja
                                    So all elements are removed from the plugins folder. However the toolbar still shows. ??! 🤢 😮
                                      zivotinja
                                      FYI
                                      First Image
                                      Second Image
                                        zivotinja
                                        I have uninstalled and restarted. However, the toolbar and error message still appear
                                          zivotinja
                                          Error Message. I cannot use right mouse button any more
                                          error
                                          • fredo6F Offline
                                            Since you restarted Sketchup, there must be another place where Sketchup take FredoGuides from.
                                            Otherwise, it would be magic....
                                            • 1 / 3
