    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 65.4k Views 17 Watching
    • kenK
      ken
      When ever I right click on any object, I get the attached error message.
      Thank you Fredo, the new install solved the problem.
      • fredo6F
        NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
        Requirement: LibFredo6 9.5
        FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
        **Home Page of FredoGuides** for information and Download.
        Main post of this FredoGuides thread.
        • P
          penumbra
          I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
          • fredo6F
            If you can reproduce it, I'll be interested in the file.
            Also, if you can leave the Ruby console opened when deleting guides...
            • fredo6F
              NEW RELEASE: FredoGuides v1.3a - 21 May 20
              Requirement: LibFredo6 9.5k
              FredoGuides v1.3a extends the validity.
              • zivotinjaZ
                zivotinja
                I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
                Thank you
                • fredo6F
                  To uninstall, please delete both the Fredo6_FredoGuides.rb file and the Fredo6_FredoGuides subfolder.
                  Did you try however to upgrade to the new version?
                  • zivotinjaZ
                    zivotinja
                    So all elements are removed from the plugins folder. However the toolbar still shows. ??! 🤢 😮
                    • zivotinjaZ
                      zivotinja
                      FYI
                      First Image
                      Second Image
                      • zivotinjaZ
                        zivotinja
                        I have uninstalled and restarted. However, the toolbar and error message still appear
                        • zivotinjaZ
                          zivotinja
                          Error Message. I cannot use right mouse button any more
                          error
                          • fredo6F
                            Since you restarted Sketchup, there must be another place where Sketchup take FredoGuides from.
                            Otherwise, it would be magic....
                            • fredo6F
                              NEW RELEASE: FredoGuides v1.4a - 25 May 20
                              Requirements
                              • LibFredo6: v10.5a
                              FredoGuides v1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                              • fredo6F
                                NEW RELEASE: FredoGuides v1.5a - 19 Aug 20
                                Requirements
                                • LibFredo6: v11.0a
                                FredoGuides v1.5a is a maintenance release for bug fixing, cosmetic adjustments and extension of validity
                                • SJS66S
                                  SJS66
                                  I just posted about FredoGuides not updating in SU but I also have to say, this topic has to have one of the most confusing posts I've ever seen. Talk about taking around in circles. I'll have to search 'my posts' to find where I just posted, or maybe I just need a kit kat....lol.
                                    You started a new thread here: https://sketchucation.com/forums/viewtopic.php?f=80&t=72568&p=660727#p660727 You didn't put your post in this thread.
                                    Do have the latest release of LibFredo6?
                                    • fredo6F
                                      NEW RELEASE: FredoGuides v1.6a - 20 Nov 20
                                      Requirements
                                      • LibFredo6: v11.0a
                                      FredoGuides v1.5a is a maintenance release for extension of validity
                                      • fredo6F
                                        NEW RELEASE: FredoGuides v1.7a - 06 Jan 21
                                        Requirements
                                        • LibFredo6: v11.0a
                                        FredoGuides v1.7a is a maintenance release for extension of validity
                                        • fredo6F
                                          NEW RELEASE: FredoGuides v1.8a - 27 Jan 21
                                          Requirements
                                          • LibFredo6: v11.0a
                                          FredoGuides v1.8a is a maintenance release for extension of validity
                                          • SJS66S
                                            SJS66
                                            I'm getting an error with FredoGuides v1.8a. If I try to use the toolbar, SU 2021 keeps telling me it's out of date but Fredo6 Plugins Update Check says everything is up to date!
                                            I uninstalled then downloaded the latest version & manually installed using Extension Manager but still getting same message.
                                            I swear it was working fine the other day.
                                            • 2 / 3
