    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 64.9k Views 17 Watching
    • fredo6F
      @nini007 said:
      Ce qui serait utile c'est de pouvoir mettre certain guide dans un groupe ou composant et pouvoir changer la couleur des guides uniquement ceux qui sont dans un groupe ou composant et pouvoir avoir plusieurs couleurs selon l'importance du guide.
      Unfortunately, Sketchup does only support a SINGLE color for ALL guides...
      • OxerO
        Oxer
        Hi and Happy New Year!!
        The Spanish Language file:
        FredoGuides_ES.lang.zip
        • fredo6F
          Many thanks. I integrate in the next version.
          • fredo6F
            NEW RELEASE: FredoGuides v1.1d - 05 Jan 20
            Requirement: LibFredo6 9.5
            FredoGuides v1.1d includes the Spanish translation by Oxer.
            Home Page of FredoGuides[/color][/b] for information and Download.
            Main post of this FredoGuides thread.
              I'm getting the same message Ken shows. I made sure that I have the latest versions of both FredoGuides and LibFredo6 but I still get it.
                adorian
                HELP Fredo, whenever I click the right mouse I get this window; and uninstall the plugin but keeps coming.
                I tried everything, including installing the new library but the window keeps coming!
                • fredo6F
                  NEW RELEASE: FredoGuides v1.1e - 22 Jan 20
                  FredoGuides v1.1e extends the validity.
                  • Didier BurD
                    Didier Bur
                    Thanks Fredo, Problem solved.
                    P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
                    DB
                    • fredo6F
                      Precisely, these extensions may become paid in the future... It's a minor inconvenience, since they are free today. Also, a good way to keep the installed base on recent versions of the script.
                      • JClementsJ
                        JClements
                        Before I updated I had the same issue.
                        I installed the update via the SketchUcation extension. However, I had to close SU and reopen it before the update would work.
                        • fredo6F
                          This is true for most plugins, because a ne version may have to update the menu and also the part that loads when Sketchup starts.
                          • kenK
                            ken
                            When ever I right click on any object, I get the attached error message.
                            Thank you Fredo, the new install solved the problem.
                            • fredo6F
                              NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
                              FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
                              **Home Page of FredoGuides** for information and Download.
                              • P
                                penumbra
                                I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
                                • fredo6F
                                  If you can reproduce it, I'll be interested in the file.
                                  Also, if you can leave the Ruby console opened when deleting guides...
                                  • fredo6F
                                    NEW RELEASE: FredoGuides v1.3a - 21 May 20
                                    Requirement: LibFredo6 9.5k
                                    FredoGuides v1.3a extends the validity.
                                    • zivotinjaZ
                                      zivotinja
                                      I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
                                      Thank you
                                      • fredo6F
                                        To uninstall, please delete both the Fredo6_FredoGuides.rb file and the Fredo6_FredoGuides subfolder.
                                        Did you try however to upgrade to the new version?
                                        • zivotinjaZ
                                          zivotinja
                                          So all elements are removed from the plugins folder. However the toolbar still shows. ??! 🤢 😮
                                          • zivotinjaZ
                                            zivotinja
                                            FYI
                                            First Image
                                            Second Image
                                            • 1 / 3
