    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 64.1k Views 17 Watching
      sitthikorn
      Hi, Fredo Thank you for your create this extension.
      I would like to feedback for FreoGuides like this...
      when I make a marking guide inside the component and click protect it then I save component and reload it places to the model. The Protection can not protect the guide when I click delete guides (Edit>delete guides). That I think it should protect the guide in components after save as together.
      Thank you
      Sitthikorn N.
      • fredo6F
        Not very clear to me. Could you post the model so that I understand.
        • fredo6F
          NEW RELEASE: FredoGuides v1.1b - 25 Dec 19
          Requirement: LibFredo6 9.5
          FredoGuides v1.1b fixes a serious bug preventing to protect guides if done right after opening Sketchup. So it is advised to migrate to this version
          Home Page of FredoGuides[/color][/b] for information and Download.
          Main post of this FredoGuides thread.
          • fredo6F
            NEW RELEASE: FredoGuides v1.1c - 25 Dec 19
            FredoGuides v1.1c fixes another serious bug preventing to protect guides if done right after opening a Sketchup file containing protected guidelines. So it is advised to migrate to this version
            • N
              nini007
              Bonjour Fredo,
              Ce plugin est formidable et d'une utilité primordiale à couplé avec celui de D. Bur "Projections".
              Je n'arrive pas à changer la couleur des guides, est-ce un bogue ?!?
              Ce qui serait utile c'est de pouvoir mettre certain guide dans un groupe ou composant et pouvoir changer la couleur des guides uniquement ceux qui sont dans un groupe ou composant et pouvoir avoir plusieurs couleurs selon l'importance du guide.
              Bravo pour tous ses plugins qui simplifient la vie, vos plugins sont incontournables.
              Meilleures salutations
              • fredo6F
                Unfortunately, Sketchup does only support a SINGLE color for ALL guides...
                • OxerO
                  Oxer
                  Hi and Happy New Year!!
                  The Spanish Language file:
                  FredoGuides_ES.lang.zip
                  • fredo6F
                    Many thanks. I integrate in the next version.
                    • fredo6F
                      NEW RELEASE: FredoGuides v1.1d - 05 Jan 20
                      FredoGuides v1.1d includes the Spanish translation by Oxer.
                        I'm getting the same message Ken shows. I made sure that I have the latest versions of both FredoGuides and LibFredo6 but I still get it.
                          adorian
                          HELP Fredo, whenever I click the right mouse I get this window; and uninstall the plugin but keeps coming.
                          I tried everything, including installing the new library but the window keeps coming!
                          • fredo6F
                            NEW RELEASE: FredoGuides v1.1e - 22 Jan 20
                            FredoGuides v1.1e extends the validity.
                            • Didier BurD
                              Didier Bur
                              Thanks Fredo, Problem solved.
                              P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
                              DB
                              • fredo6F
                                Precisely, these extensions may become paid in the future... It's a minor inconvenience, since they are free today. Also, a good way to keep the installed base on recent versions of the script.
                                • JClementsJ
                                  JClements
                                  Before I updated I had the same issue.
                                  I installed the update via the SketchUcation extension. However, I had to close SU and reopen it before the update would work.
                                  • fredo6F
                                    This is true for most plugins, because a ne version may have to update the menu and also the part that loads when Sketchup starts.
                                    • kenK
                                      ken
                                      When ever I right click on any object, I get the attached error message.
                                      Thank you Fredo, the new install solved the problem.
                                      • fredo6F
                                        NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
                                        FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
                                        **Home Page of FredoGuides** for information and Download.
                                        • P
                                          penumbra
                                          I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
                                          • fredo6F
                                            If you can reproduce it, I'll be interested in the file.
                                            Also, if you can leave the Ruby console opened when deleting guides...
                                            • 1 / 3
