    Follow me into different radius
    30 Posts 4 Posters 6.6k Views 4 Watching
      Leggy
      hi im getting this message
        Leggy
        here's the dwg
        may help
        • fredo6F Offline
          For Curviloft to operate correctly, you need to select only the external contours, not the inner corner edges. Watch the short video by Box again.
            Leggy
            Aha ok thanks for that ill try again on Monday
            • BoxB Offline
              For a bit of clarity, in my gif you see me select all of it and show that it doesn't work as it highlights too many edges, then I hold down shift to deselect the corner faces. You could also activate the tool with nothing selected and just click on the edges you need.
                Leggy
                hi I followed your example and got this, any ideas
                thanks so much for your time
                  Why don't you upload the SKP file so we can see what you started with?
                    Leggy
                    here you are
                    curviloft test.skp
                      Does the white one look more like what you want?
                      curviloft test.skp
                        Leggy
                        exactly, is it to do with the order you pick the lines?
                          No. The bottom arc has 24 segments so I divided the straight lines on the sides and top so there is a total of 24 segments up each side (including the segments in the arcs at the top.
                            Leggy
                            how did you do that?
                              Do what? Divide the edges? I right clicked on an edge, selected Divide and then entered the correct number.
                                Leggy
                                Clever , the problem with the video is the curser leaves the screen so you can’t see what he clicked
                                  Which video are you referring to?
                                    Leggy
                                    The one from box
                                      Leggy
                                      The one from box
                                        The only things I saw where the cursor wasn't visible was when he made a group after context clicking on the selected geometry and then when he moved the cursor to bring the Entity Info panel up to show that it's a solid group.
                                        • 2 / 2
